Broken quadrature encoder circuit on TI F281x DSPs?
Started by Chris Carlen ●August 24, 2005
On Thu, 25 Aug 2005 16:32:52 -0300, Ricardo
<spamgoeshere1978@yahoo.com> wrote:
>Dave Hansen escreveu: >> On Thu, 25 Aug 2005 10:17:05 -0700, Chris Carlen >> <crcarleRemoveThis@BOGUSsandia.gov> wrote: ><snip> >>> N-1 N 0 1 2 3 4 5 ... >>> ______ ______ ______ ______ >>>B: ______ ______ ______ ______ >>> ___ ______ ______ ______ ___ >>>A: ______ ______ ______ ______ >>> ______ >>>Z: __________________ ________________________ >> >> >This looks right here.
The quote looks right here, too, though my original post had one more space on each of the upper lines (and the numbers line). I'm not sure where that space went. Or where it came from, assuming the OP was correct. Regards, -=Dave -- Change is inevitable, progress is not.
jmeyer@nowhere.net wrote:
>>Read over United States Patent 4300039, then we'll correspond further. >> >>Jerry > > > Dear Jerry, > It is seldom necessary to quote an entire message filled with timing > diagrams and diatribes simply to add a one line reply.
Jim, Seldom, certainly. In this case, there was a purpose. I doubted that those diagrams represented what the OP wanted to show, so I thought it would be well for him to see them as they appeared in my reader. I missed the diatribe. What I saw was a rather lengthy tale of woe. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Thu, 25 Aug 2005 07:51:59 -0700, Chris Carlen
<crcarleRemoveThis@BOGUSsandia.gov> wroth:
>jmeyer@nowhere.net wrote: >> Dear Jerry, >> It is seldom necessary to quote an entire message filled with timing >> diagrams and diatribes simply to add a one line reply. > > >Interesting combination huh, "timing diagrams and diatribes." > >:-D
I only calls 'em like I sees 'em. Jim
> >So things like this look right: > > N-1 N 0 1 2 3 4 5 ... > ______ ______ ______ ______ >B: ______ ______ ______ ______ > ___ ______ ______ ______ ___ >A: ______ ______ ______ ______ > ______ >Z: __________________ ________________________ > >The edges of B and Z waveforms line up vertically, and the numbers above >are centered within 1/4 cycles of the waveform. >
The only way to resolve this problem is to post screen captures of what *we* see when we look at your message. I've started the ball rolling by posting "Diatribe.jpg" to ABSE. O wad some power the giftie gie us To see oursel's as ithers see us! It wad frae monie a blunder free us. And foolish notion; What airs in dress and gait wad lea'e us, And ev'n devotion! (R. Burns) Jim
On Thu, 25 Aug 2005 18:28:31 GMT, "Jona Vark" <noemail@all.com> wroth:
>How petty.. it si a QUADRATURE encoder. The waveforms are all the same.. If >you've seen one. >
It si? Jim
Chris Carlen wrote:
> Jerry Avins wrote: > >> Read over United States Patent 4300039, then we'll correspond further. >> >> Jerry > > > > Thanks for the input Jerry. > > I am aware of such methods. I wish to avoid building my own quadrature > decode hardware. I could do it if I want, and would probably do it with > a state machine in a FPGA that I plan to have nearby the DSP for misc. > logic tasks.
Instead of a state machine, you can use a flip-flop and 2 XORs. If the tracks can interrupt when going positive and negative, that can all be software, with the "flip-flop" being the LSB of the counter.
> But the reason I want to rely on the F281x QEP circuitry is that I will > be using the compare match function as well. Also period interrupts. Of > course, all this can be done as well with the PLD, but if I can make the > DSP's circuitry work, then that's the most straightforward path.
I don't know the QEP effects.
> It turns out that while I think they did blow it in terms of the most > sensible implementation, I can get working results with just a minor > external hardware trick.
Have you considered what happens when vibration moves the counting track back and forth across a transition without actually causing any net rotation?
> If I simply can guarantee that the Z rising edge occurs after the > condition A=B=1 is satisfied, as well as setting the counter period to > the encoder's max count, then actually I can't ever get an extra count. > The only deficiency is that it can only sync to absolute position in > one direction. But that is fortunately not a bog problem in this > application.
I think you can resolve the ambiguity by looking at transitions of all tracks at both ends if the Z pulse. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Jim Granville wrote:
> Not sure I'd call Nov 10 1981 'new' ? > XOR based quad solutions have been around a very long time : > You need either a pulse generator ( hard in an ASIC, or FPGA) > or some FF's, and a faster clock, to do effectively the same thing. > In today's digital fabric, the FF's are cheaper, and simulate > correctly, and avoid issues with clock domain crossing... > to .
The only pulses are generated by the encoder. I don't know what you mean. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
John Woodgate wrote:
> The diagram seemed to make sense to me when displayed in Courier New. So > I have no reason to assume that the OP used a proportional font. YMMV, I > suppose.
It could have been worse. A dash is a dash, so there was only a little displacement between successive lines. But consider his labeling: N-1 N 0 1 2 3 4 5 ... ______ ______ ______ ______ B: ______ ______ ______ ______ I suppose he meant something like N-1 N 0 1 2 3 4 5 ... ______ ______ ______ ______ B: ______ ______ ______ ______ Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
In article <dekueh01n4s@news2.newsguy.com>,
> N-1 N 0 1 2 3 4 5 ... > ______ ______ ______ ______ > B: ______ ______ ______ ______ > ___ ______ ______ ______ ___ > A: ______ ______ ______ ______ > ______ > Z: __________________ ________________________
> The edges of B and Z waveforms line up vertically, and the > numbers above are centered within 1/4 cycles of the waveform.
Below is the diagram from your original post. I put it into a hex editor. All "s" chars below are where there was a 20H (space char) and the 0A char is your newline. I've also added a blank line between waveform pairs of lines. ssssssssss______ssssss______ssssss______ssssss______0A B:s______ssssss______ssssss______ssssss______0A ssss___ssssss______ssssss______ssssss______ssssss___0A A:ssss______ssssss______ssssss______ssssss______0A ssssssssssssssssssssss______0A Z:s__________________ssssss________________________0A You will see that on all lines where the first character is a space, then an extra space has been added. I think this was done by your newsreader when you generated the post. AFAIK this is a characteristic of some newsreaders. Conversely when reading your post, some newsreaders will drop the extra space (when it is the first char on a line), whereas others will not. For example, in Turnpike (same newsreader as JW) your post lined up perfectly, whereas in this newsreader (Pluto) the one-space-offset is kept and displayed. I suspect this is why Fred Bloggs and Win Hill post ascii diagrams with dummy chars as the leading chars on each line. As a matter of interest, all my typed text here has a leading space on each line. Do you see that space or not? -- Tony Williams.
Tony Williams wrote:
> Below is the diagram from your original post. I put it into > a hex editor. All "s" chars below are where there was a 20H > (space char) and the 0A char is your newline. I've also > added a blank line between waveform pairs of lines. > > ssssssssss______ssssss______ssssss______ssssss______0A > B:s______ssssss______ssssss______ssssss______0A > > ssss___ssssss______ssssss______ssssss______ssssss___0A > A:ssss______ssssss______ssssss______ssssss______0A > > ssssssssssssssssssssss______0A > Z:s__________________ssssss________________________0A > > You will see that on all lines where the first character > is a space, then an extra space has been added. I think > this was done by your newsreader when you generated the > post. AFAIK this is a characteristic of some newsreaders. > > Conversely when reading your post, some newsreaders will > drop the extra space (when it is the first char on a line), > whereas others will not. > > For example, in Turnpike (same newsreader as JW) your post > lined up perfectly, whereas in this newsreader (Pluto) the > one-space-offset is kept and displayed. > > I suspect this is why Fred Bloggs and Win Hill post ascii > diagrams with dummy chars as the leading chars on each line. > > As a matter of interest, all my typed text here has a leading > space on each line. Do you see that space or not?
Yes, I see leading spaces on your text, not on your timing diagrams with spaces mapped to "s". I also see that the waveforms are not appearing to you as I see them. Interesting. It seems that spaces are not a reliable means of spacing ASCII diagrams in news posts. Unless as you mention about Win's posts, one puts a leading non-space char on each line? Thanks for the input. I was begining to think folks were going overboard in hashing the issue. But now I have learned something. Good day! -- _______________________________________________________________________ Christopher R. Carlen Principal Laser/Optical Technologist Sandia National Laboratories CA USA crcarleRemoveThis@BOGUSsandia.gov NOTE, delete texts: "RemoveThis" and "BOGUS" from email address to reply.
