Broken quadrature encoder circuit on TI F281x DSPs?
Started by Chris Carlen ●August 24, 2005
Tony Williams wrote:
(snip)
> Below is the diagram from your original post. I put it into > a hex editor. All "s" chars below are where there was a 20H > (space char) and the 0A char is your newline. I've also > added a blank line between waveform pairs of lines. > > ssssssssss______ssssss______ssssss______ssssss______0A > B:s______ssssss______ssssss______ssssss______0A > > ssss___ssssss______ssssss______ssssss______ssssss___0A > A:ssss______ssssss______ssssss______ssssss______0A > > ssssssssssssssssssssss______0A > Z:s__________________ssssss________________________0A > > You will see that on all lines where the first character > is a space, then an extra space has been added. I think > this was done by your newsreader when you generated the > post. AFAIK this is a characteristic of some newsreaders. > > Conversely when reading your post, some newsreaders will > drop the extra space (when it is the first char on a line), > whereas others will not.
It came out fine on Netscape 7.1. -- glen
On Thu, 25 Aug 2005 19:29:11 +0000, Jonathan Kirwan wrote:
> On Thu, 25 Aug 2005 17:52:23 GMT, iddw@hotmail.com (Dave Hansen) > wrote: > >>On Thu, 25 Aug 2005 10:17:05 -0700, Chris Carlen >><crcarleRemoveThis@BOGUSsandia.gov> wrote: >> >>[...] >>>So things like this look right: >>> >>> N-1 N 0 1 2 3 4 5 ... >>> ______ ______ ______ ______ >>>B: ______ ______ ______ ______ >>> ___ ______ ______ ______ ___ >>>A: ______ ______ ______ ______ >>> ______ >>>Z: __________________ ________________________ >> >>Almost, but not quite lined up when it got here. It looks like either >>the upper lines gained a space, or the lower ones lost one. If I make >>a minor correction, I get: >> >>> N-1 N 0 1 2 3 4 5 ... >>> ______ ______ ______ ______ >>>B: ______ ______ ______ ______ >>> ___ ______ ______ ______ ___ >>>A: ______ ______ ______ ______ >>> ______ >>>Z: __________________ ________________________ > > Exactly correct. Now it looks right. You've identified the issue, I > think. > >>Which at least appears correct on my system. FWIW, if I were drawing >>it, I'd put in the vertical markers, and try to line the numbers up on >>them, e.g. >> >>> N-1 N 0 1 2 3 4 5 ... >>> _____ _____ _____ ______ >>>B: _____| |_____| |_____| |_____| >>> __ _____ _____ _____ ___ >>>A: |_____| |_____| |_____| |_____| >>> _____ >>>Z: _________________| |________________________ >>> >> >>This would have made it easier for me to follow, anyway... > > Neat. I like it much better, too. > > Jon
<AOL> Me, Too! </AOL> %-} Rich
