Hi, I have been trying to solve the problem Roots of the polynomial 038 from mipt.ru (el judge). I have failed to do so. I tried to search on the net but found about contour integrals for routh-hurwitz criterion. So it is difficult to code. Can you please tell me how to solve the problem for degree 20 ? and how to approach the problem for degree 4. Please do tell me the pseudo code and references. Thanks, Terry temper_3243@yahoo.com
Roots of a polynomial
Started by ●August 29, 2005
Reply by ●August 29, 20052005-08-29
In article <1125293735.090133.226570@g14g2000cwa.googlegroups.com>, <temper3243@gmail.com> wrote:> Hi, > I have been trying to solve the problem Roots of the polynomial 038 > from mipt.ru (el judge). I have failed to do so. I tried to search on > the net but found about contour integrals for routh-hurwitz criterion. > So it is difficult to code. > > Can you please tell me how to solve the problem for degree 20 ? and > how to approach the problem for degree 4. > > Please do tell me the pseudo code and references.First of all, I don't have any idea what you're talking about. Give a proper URL if you want an answer. Second, you have posted THE SAME TEXT in two different posts, once to sci.math and once to comp.dsp, sci.eng.control, and sci.math.num-analysis. The one to three newsgroups is in approved form, and doesn't increase bandwith. The one to sci.math DID increase bandwidth. I can guess what you mean from context, and it's not difficult to code. All you have to do is estimate the derivative of f'(z)/f(z) on a contour (all you need is an upper bound on the absolute value, so you have a Lipschitz constant on the contour), then take a fine enough grid on the parameterization of the contour so as to be able to recognize the discretization of the integral as being close enough to an integral multiple of 2 pi i. This yields the degree of the mapping, which is the count of roots. Perfectly routine. --Ron Bruck
temper3243@gmail.com wrote:> Hi, > I have been trying to solve the problem Roots of the polynomial 038 > from mipt.ru (el judge). I have failed to do so. I tried to search on > the net but found about contour integrals for routh-hurwitz criterion. > So it is difficult to code. > > Can you please tell me how to solve the problem for degree 20 ? and > how to approach the problem for degree 4. > > Please do tell me the pseudo code and references. > > > Thanks, > Terry > temper_3243@yahoo.com >The book "Numerical Recipes in C" has a polynomial root finder. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"Tim Wescott" schrieb> > The book "Numerical Recipes in C" has a > polynomial root finder. >I keep finding on the web references that are saying that this book is less than optimal. What's the opinion here? Any other good books about numerical methods that can be recommended? Regards Martin
Martin Blume wrote:> "Tim Wescott" schrieb > >> >>The book "Numerical Recipes in C" has a >>polynomial root finder. >> > > I keep finding on the web references that are saying > that this book is less than optimal. What's the > opinion here? Any other good books about numerical > methods that can be recommended?If you mean by "less than optimal" that a clever programmer can write a more efficient algorithm, that is often true. It is rarely true that the routines don't perform as claimed. Avoiding NR because the code could perhaps be improved is like choosing to walk because the bicycle you've been offered is less than best. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>>>>> "Jerry" == Jerry Avins <jya@ieee.org> writes:Jerry> Martin Blume wrote: >> "Tim Wescott" schrieb >> >>> The book "Numerical Recipes in C" has a polynomial root finder. >>> >> I keep finding on the web references that are saying >> that this book is less than optimal. What's the opinion here? Any >> other good books about numerical methods that can be recommended? Jerry> If you mean by "less than optimal" that a clever programmer can write Jerry> a more efficient algorithm, that is often true. It is rarely true that Jerry> the routines don't perform as claimed. Avoiding NR because the code Jerry> could perhaps be improved is like choosing to walk because the bicycle Jerry> you've been offered is less than best. In this particular case, I think they usually mean the NR code is not serious numerical code. It might work for simple cases, but it may be very wrong for other cases. It may not even be all that accurate even for the simple cases. Ray
Raymond Toy wrote:> In this particular case, I think they usually mean the NR code is not > serious numerical code. It might work for simple cases, but it may be > very wrong for other cases. It may not even be all that accurate even > for the simple cases. >In a nutshell, it is often not optimized for correctness. ;-) -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Nothing is ever so bad that it can't get worse. - Calvin
On Mon, 29 Aug 2005 15:20:14 -0400, Jerry Avins <jya@ieee.org> wrote:> Martin Blume wrote: >> "Tim Wescott" schrieb >> >>> >>>The book "Numerical Recipes in C" has a >>>polynomial root finder. >>> >> >> I keep finding on the web references that are saying >> that this book is less than optimal. What's the >> opinion here? Any other good books about numerical >> methods that can be recommended? > > If you mean by "less than optimal" that a clever programmer can write a > more efficient algorithm, that is often true. It is rarely true that the > routines don't perform as claimed. Avoiding NR because the code could > perhaps be improved is like choosing to walk because the bicycle you've > been offered is less than best. >I've never found an instance where NR's code was "wrong" but the examples are written more for teaching than for performance. There WERE well known problems with earlier editions of the book, all of which are noted in the notes. HOWEVER, NR has EXCELLENT cross references that point to NUMEROUS implementations, both free and commercial, of nearly all of the algorithms. Note the root finding is a tricky problem, as you're necessarily dealing with very small numbers. Back when the 'c40 was all the rage, we ran into quite a few problems when the guy implementing the root finding algorithm "knew" he had it right, but forgot that the 'c40 didn't, by default, didn't do things with enough accuracy for the kind of algorithm he was using. I sure learned a lot about numeric methods on That project.
Reply by ●August 30, 20052005-08-30
Jerry Avins wrote:> Martin Blume wrote: > >> "Tim Wescott" schrieb >> >>> The book "Numerical Recipes in C" has a polynomial root finder. >> >> I keep finding on the web references that are saying >> that this book is less than optimal. What's the opinion here? Any >> other good books about numerical methods that can be recommended? > > If you mean by "less than optimal" that a clever programmer can write a > more efficient algorithm, that is often true. It is rarely true that the > routines don't perform as claimed. Avoiding NR because the code could > perhaps be improved is like choosing to walk because the bicycle you've > been offered is less than best.Some of the algorithms have a few serious faults too. And the odd typo and quirky indexing from translation out of the original FORTRAN. But you get what you deserve if you don't cross check that the answer you get from a computer code is correct. The references given in the book are still OK, and much of their code only fails on difficult problems. If doesn't work for you then chase up a more advanced text. It is still a pretty good general intro for all its faults. There are much better standard libraries about. Regards, Martin Brown
Martin Brown wrote:> Jerry Avins wrote: > >> Martin Blume wrote: >> >>> "Tim Wescott" schrieb >>> >>>> The book "Numerical Recipes in C" has a polynomial root finder. >>> >>> >>> I keep finding on the web references that are saying >>> that this book is less than optimal. What's the opinion here? Any >>> other good books about numerical methods that can be recommended? >> >> >> If you mean by "less than optimal" that a clever programmer can write >> a more efficient algorithm, that is often true. It is rarely true that >> the routines don't perform as claimed. Avoiding NR because the code >> could perhaps be improved is like choosing to walk because the bicycle >> you've been offered is less than best. > > > Some of the algorithms have a few serious faults too. And the odd typo > and quirky indexing from translation out of the original FORTRAN. > > But you get what you deserve if you don't cross check that the answer > you get from a computer code is correct. > > The references given in the book are still OK, and much of their code > only fails on difficult problems. If doesn't work for you then chase up > a more advanced text. It is still a pretty good general intro for all > its faults. There are much better standard libraries about. > > Regards, > Martin BrownThe DSP group at Rice University have published Matlab code for solving high order polynomials. I believe last year they published a paper in the IEEE Signal Processing Magazine. Solving polynomials is a difficult problem due to the numerical sensitivity. Once you find some of the roots you have to deflate the order of the polynomial. It's a similar problem to finding Eigenvalues. So if you want the work you should probably be looking at the BLAS or LINPACK libraries. Cheers, David
