Hi, I am new to DSP and learning about sampling and related topics. I have read a book and visited online sites but still am having problems understanding : 1. Why do we need a filter (FIR) BEFORE we downmsample when we perform decimation. I understand why for upsampling we need the filtering part but am having problems with the downsampling filter. 2. I understand for a multirate system the filtering of both the interpolation and decimation can be made into one, using the filter with the lowest cutoff frquency as the only filter. However, How do we determine/choose the cutoff frquency for a each individual filter (assuming ideal LP FIR filter is used for both decimation and interpolation )? 3. I have read that: "oversampling helps reduce the order of anti-aliasingand reconstruction filter." But why/how? thanks so much!! This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Basic question on upsampling/downsampling
Started by ●August 29, 2005
Reply by ●August 30, 20052005-08-30
moe wrote:> Hi, I am new to DSP and learning about sampling and related topics. I have > read a book and visited online sites but still am having problems > understanding : > > 1. Why do we need a filter (FIR) BEFORE we downmsample when we perform > decimation. I understand why for upsampling we need the filtering part > but am having problems with the downsampling filter. >Downsampling causes aliasing, the filter is just an ordinary old anti-aliasing filter.> > 2. I understand for a multirate system the filtering of both the > interpolation and decimation can be made into one, using the filter with > the lowest cutoff frquency as the only filter. However, How do we > determine/choose the cutoff frquency for a each individual filter > (assuming ideal LP FIR filter is used for both decimation and > interpolation )?Aliasing again -- figure out how much you can stand and design your filter accordingly.> > 3. I have read that: "oversampling helps reduce the order of > anti-aliasingand reconstruction filter." But why/how? >Because it increases the Nyquist frequency, so the reconstruction filter cutoff can be higher. Note that if you oversample the data digitally you still need a high-order antialiasing filter; you just move the task into the digital domain where it's easier to control. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
IIRC, the answer to 2) should be the bandwidth is determined as LE the smaller of the bandwidths of the interpolation and decimation fiters. Dirk
moe wrote:> 1. Why do we need a filter (FIR) BEFORE we downmsample when we perform > decimation. I understand why for upsampling we need the filtering part > but am having problems with the downsampling filter.When you downsample, by definition, you reduce the sample rate. If the original signal has any frequency content at or above half the new lower sample rate, which it might at the original sample rate, then some low pass filtering is required in order to prevent aliasing. You actually might not need any filtering if the original signal happens to not have any frequency content high enough to cause aliasing problems, for example if the passband during a previous upsampling filter was low enough. All the above comments assume baseband content. IMHO. YMMV. -- rhn A.T. nicholson d.O.t C-o-M
