Windowed-sinc function
Started by Michel Rouzic August 31, 2005
I read chapter 16 from dspguide.com, and from that I did a
windowed-sinc function, calculated by this :
for (i=0; i<*M/2; i++)
	h[i]=sin(2*pi*fc*(i-*M/2))/(i-*M/2);
	h[*M-i-1]=h[i];
h[*M/2]=2*pi*fc;
the problem is, the central bin (h[*M/2]) seems to be a little less
than a billion times too big compared to the rest of the kernel, and
then, the rest of the kernel doesn't seem to have the right shape for a
low-pass FIR filter kernel. see anything that ain't right about it?
btw, here, pi=atan(1.0)*4.0, fc is the cutoff frequency expressed as a
fraction of the sampling frequency, and *M is the length of the kernel
to be generated, an always is an odd number.
Michel Rouzic wrote:
> I read chapter 16 from dspguide.com, and from that I did a > windowed-sinc function, calculated by this : > > for (i=0; i<*M/2; i++) > { > h[i]=sin(2*pi*fc*(i-*M/2))/(i-*M/2); > h[*M-i-1]=h[i]; > } > h[*M/2]=2*pi*fc; > > the problem is, the central bin (h[*M/2]) seems to be a little less > than a billion times too big compared to the rest of the kernel, and > then, the rest of the kernel doesn't seem to have the right shape for a > low-pass FIR filter kernel. see anything that ain't right about it? > > btw, here, pi=atan(1.0)*4.0, fc is the cutoff frequency expressed as a > fraction of the sampling frequency, and *M is the length of the kernel > to be generated, an always is an odd number.
Look to your indexing. Is there a divide-by-almost-zero problem? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
This is a variation of sinc(x)=sin(x)/x for x==0. You need to apply L'Hopital's rule on the expression, and see what value the expression should have for i== *M/2, and set it explicitly. By the way, you are programming in C, right? This *M/2 construct seems a bit odd. You *could* risk that the compiler divides the value in the pointer M by 2 before de-referencing it... It will look better (and probably run faster) if you make some local variable Mm = (*M)/2 before this loop. Rune
"Michel Rouzic" <Michel0528@yahoo.fr> wrote in message
news:1125479097.536311.73010@g47g2000cwa.googlegroups.com...
>I read chapter 16 from dspguide.com, and from that I did a > windowed-sinc function, calculated by this : > > for (i=0; i<*M/2; i++) > { > h[i]=sin(2*pi*fc*(i-*M/2))/(i-*M/2); > h[*M-i-1]=h[i]; > } > h[*M/2]=2*pi*fc; > > the problem is, the central bin (h[*M/2]) seems to be a little less > than a billion times too big compared to the rest of the kernel, and > then, the rest of the kernel doesn't seem to have the right shape for a > low-pass FIR filter kernel. see anything that ain't right about it? > > btw, here, pi=atan(1.0)*4.0, fc is the cutoff frequency expressed as a > fraction of the sampling frequency, and *M is the length of the kernel > to be generated, an always is an odd number. >
Is not 2*pi*fc included in the denominator "x" for sinx/x ???
I don't think you have the right normalization (the right multiplicative constant) for the argument of sin. Imagine that fc happens to be 44100 Hz (or 8000, or 48000, or any other *integer* value). (i-*M/2) is always an integer, so you end up computing sin (2*pi*k), with k an integer value, which gives you all zeros as the result. Ok, so perhaps fc is not exactly an integer -- or it is, but the internal floating-point representation does not allow you to *exactly* represent that integer number. Then, you're getting basically "random" numbers if fc is sufficiently large -- 2*pi times a large number, you're basically getting whatever the "remainder" is -- i.e., 2*pi*K modulo 2*pi Seems like you'd have to double check your "normalization" multiplic. coefficients. HTH, Carlos --
"Michel Rouzic" schrieb
> I read chapter 16 from dspguide.com, > [...] > btw, here, pi=atan(1.0)*4.0, >
the standard math library offers a constant for that, M_PI, IIRC. no need to calculate.
> fc is the cutoff frequency expressed as a fraction of > the sampling frequency, >
dspguide has it as a fraction of Nyquist, so 0<=fc<0.5, yours will be 0<=fc<1.0
> and *M is the length of the kernel to be generated, > an always is an odd number. >
dspguide's examples are unfortunately in BASIC (no quite suited to production code, they are also rather meant for illustration), and there the index goes (translated into C) for (i=0; i<=M; i++) instead of the C-like for (i=0; i<M; i++) Maybe this helps. Martin
Martin Blume wrote:
> "Michel Rouzic" schrieb > >>I read chapter 16 from dspguide.com, >>[...] >>btw, here, pi=atan(1.0)*4.0, >> > > the standard math library offers a constant for that, > M_PI, IIRC. no need to calculate.
No it doesn't (unless they added it in C99, which I somewhat doubt it). M_PI is a non-standard extension in Borland compilers (not sure if others as well), NOT a stdandard C library feature. Carlos --
That depends on the compiler since it is not part of the C standard. GCC includes it, but others do not. I include this in my headers when needed: #ifndef M_PI #define M_PI (3.1415926535897932384626433832795) #endif -- Phil Frisbie, Jr. Hawk Software http://www.hawksoft.com
I ran into the same problem when trying to create a windowed sinc FIR generator and referencing chapter 16 of dspguide.com. Try: h[i] = sin(2*pi*fc*(i-M/2))/(pi*(i-M/2)); and h[M/2] = 2*fc I posted source code a few months back on the musicdsp.org source code archive for generating a windowed sinc FIR filter in response to a conversation there. Have a look there for more details..
Jerry Avins wrote:
> Michel Rouzic wrote: > > I read chapter 16 from dspguide.com, and from that I did a > > windowed-sinc function, calculated by this : > > > > for (i=3D0; i<*M/2; i++) > > { > > h[i]=3Dsin(2*pi*fc*(i-*M/2))/(i-*M/2); > > h[*M-i-1]=3Dh[i]; > > } > > h[*M/2]=3D2*pi*fc; > > > > the problem is, the central bin (h[*M/2]) seems to be a little less > > than a billion times too big compared to the rest of the kernel, and > > then, the rest of the kernel doesn't seem to have the right shape for a > > low-pass FIR filter kernel. see anything that ain't right about it? > > > > btw, here, pi=3Datan(1.0)*4.0, fc is the cutoff frequency expressed as a > > fraction of the sampling frequency, and *M is the length of the kernel > > to be generated, an always is an odd number. > > Look to your indexing. Is there a divide-by-almost-zero problem? > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF I don't think so (idk). What are you thinking about?
