Hi, there! I'm new on this board, and maybe I'm veryy close to rules, so sorry in advance! My question, despite its simplicity, is rather head breaking: I'm trying to understand and quantify the consequence of phase noise, due to a VCO, when injected in a mixer. As I think this phase noise could be assimilated as a coloured noise, so a gaussian SPD, I don't really imagine what could happen going through mixing process: a white noise?? Then, is it possible to quantify the consequence of this phase noise on the mixer's sensibility? Sure you could teach me some, and it'll be very kindfull. Thanks in advance! Mike PS: sorry for my unperfect english!
VCO Phase noise: consequence for mixing...
Started by ●August 31, 2005
Reply by ●August 31, 20052005-08-31
Chromatik wrote:> Hi, there! > I'm new on this board, and maybe I'm veryy close to rules, so sorry in > advance! > My question, despite its simplicity, is rather head breaking: I'm > trying to understand and quantify the consequence of phase noise, due > to a VCO, when injected in a mixer. > As I think this phase noise could be assimilated as a coloured noise, > so a gaussian SPD, I don't really imagine what could happen going > through mixing process: a white noise?? > Then, is it possible to quantify the consequence of this phase noise on > the mixer's sensibility? > > Sure you could teach me some, and it'll be very kindfull. > Thanks in advance! > > Mike > > PS: sorry for my unperfect english! >Your English is good enough. Your question is technically outside the topics of this newsgroup, but may not be a perfect fit for any (sci.electronics.design may have been a good one to cross-post to). Phase noise (and frequency drift) at the mixer LO port translates to phase noise (and frequency drift) at the mixer IF port. This has the potential to cause two problems with your IF: your intended signal will have phase noise, etc., and unintended signals will be phase modulated. Calculating the effect on your intended signal should be easy to calculate. Less obvious is that if your desired signal is weak and there is a high-power signal that should end up outside of the passband of the IF the phase modulation could put that high-powered mixing product right in the middle of your IF, drowning out your desired signal. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●September 1, 20052005-09-01
Hi, and thanks, Mr Wescott, for your advice (cross posting in this other group) , and your help. Hopefully transistors works in a way that they produce the less PN and drift as I can, but as the signal is low, the resulting signal suffers from unsollicited modulations. Now, it's time to go to the correct board :) Thanks again, Regards Mike
