Stephan M. Bernsee wrote:> On 2004-08-10 20:24:25 +0200, Mark Borgerding <mark@borgerding.net> said: > >> Stephan M. Bernsee wrote: >> >>> On 2004-08-10 11:59:01 +0200, santosh.nath@ntlworld.com (santosh >>> nath) said: >>> >>>> Hi, >>>> >>>> Word "Quantum" is going global from the den of physics. >>>> >>>> "Quantum" cryptograhy - seems to be toughest,deepest and nearly >>>> unbreakable > > > I think you quoted me saying that - just for the record, I didn't.Agreed.> I'm curious: how do you decode it then? >A quantum encrypted message is transmitted as a series of photons with various polarizations. According to the Heisenberg uncertainty principle, the exact polarity of the photons cannot be measured. It can be very coarsely measured by determining if the photon got through. If it did, then the photon polarity was close enough to the filter's to allow the photon to pass. There is only one chance at detecting each photon. Once the coarse detection is done, the photon is gone. The sender sends a stream of photons. The receiver detects them with some random sequence of polarities. Afterward, the receiver tells the sender what polarities he was using. Half the bits of the message are lost. But that is ok. --- Mark
Classical to Quantum!
Started by ●August 10, 2004
Reply by ●August 10, 20042004-08-10
Reply by ●August 11, 20042004-08-11
Mark Borgerding <mark@borgerding.net> wrote in message news:<UccSc.152343$fv.45753@fe2.columbus.rr.com>...> Stephan M. Bernsee wrote: > > On 2004-08-10 20:24:25 +0200, Mark Borgerding <mark@borgerding.net> said: > > > >> Stephan M. Bernsee wrote: > >> > >>> On 2004-08-10 11:59:01 +0200, santosh.nath@ntlworld.com (santosh > >>> nath) said: > >>> > >>>> Hi, > >>>> > >>>> Word "Quantum" is going global from the den of physics. > >>>> > >>>> "Quantum" cryptograhy - seems to be toughest,deepest and nearly > >>>> unbreakable > > > > > > I think you quoted me saying that - just for the record, I didn't. > > Agreed. > > > I'm curious: how do you decode it then? > > > > A quantum encrypted message is transmitted as a series of photons with > various polarizations. > > According to the Heisenberg uncertainty principle, the exact polarity of > the photons cannot be measured. It can be very coarsely measured by > determining if the photon got through. If it did, then the photon > polarity was close enough to the filter's to allow the photon to pass. > > There is only one chance at detecting each photon. Once the coarse > detection is done, the photon is gone. > > The sender sends a stream of photons. The receiver detects them with > some random sequence of polarities. > > Afterward, the receiver tells the sender what polarities he was using. > Half the bits of the message are lost. But that is ok.... and how is this different from, say, telepathy? Rune
Rune Allnor wrote:> Mark Borgerding <mark@borgerding.net> wrote in message news:<UccSc.152343$fv.45753@fe2.columbus.rr.com>... >> >>A quantum encrypted message is transmitted as a series of photons with >>various polarizations. >> >>According to the Heisenberg uncertainty principle, the exact polarity of >>the photons cannot be measured. It can be very coarsely measured by >>determining if the photon got through. If it did, then the photon >>polarity was close enough to the filter's to allow the photon to pass. >> >>There is only one chance at detecting each photon. Once the coarse >>detection is done, the photon is gone. >> >>The sender sends a stream of photons. The receiver detects them with >>some random sequence of polarities. >> >>Afterward, the receiver tells the sender what polarities he was using. >>Half the bits of the message are lost. But that is ok. > > > ... and how is this different from, say, telepathy? > > RuneLOL! Sorry. I should've said the reason it is ok. After the stream is transmitted, the sender and receiver can agree which polaritie schemes were used. Then they both know which bits were received okay. Those bits are then used a to form a one-time pad, which is another provably secure crypto method. -- Mark
Mark Borgerding <mark@borgerding.net> wrote in message news:<411912d9$1@news.xetron.com>...> Stephan M. Bernsee wrote: > > On 2004-08-10 11:59:01 +0200, santosh.nath@ntlworld.com (santosh nath) > > said: > > > >> Hi, > >> > >> Word "Quantum" is going global from the den of physics. > >> > >> "Quantum" cryptograhy - seems to be toughest,deepest and nearly > >> unbreakable > > There's no "nearly" about it. QC uses the spin of photons to make a > message that cannot be intercepted and retransmitted. Anyone who reads > the message destroys it in the process.I don't understand this. Mind you, I know nothing about Quantum Cryptography than has been mentioned in this thread, so please bear with my perhaps all too obvious ignorance of this field... Now, in my naive mind, secure communication is first and foremost a matter of "communication", i.e. transmitting some piece of information from point A to point B. Only after having achieved that, does the qualifier "secure" apply. So to me, the receiver needs to get a copy of the message, or the system has failed. "Secure" systems aim to achieve this in the presence of an evesdropper, somebody who listens in on the message. It follows that cryptography is a method to protect the information of the message from being understood by the evesdropper. If you agree with me in these premises, what I have learned about Quantum Cryptography (QC) in this thread makes little sense. If somebody, either the intended receiver or the evesdropper, intecepts the message, the message is destroyed. If it so happens that it is the evesdropper who recieves the message, the message is lost what the intended receiver is concerned, and the communication system fails in its basic premise. The use of QC actually appears to supply a malicious interferent with a perfect means to block the communications channel. It follows that QC is only useful in systems that a priori are perfectly protected from unauthorized evesdropping, which by definition makes QC (or any form of cryptography, for that matter) obsolete in the first place. It's late afternoon and I've been in a too hot office for too long today, so I can't find the obvious flaw in my reasoning. Could somebody help me see it? Rune
Stephan M. Bernsee wrote:> On 2004-08-10 18:32:35 +0200, Stan Pawlukiewicz <spam@spam.mitre.org> said: > >> Stephan M. Bernsee wrote: >> >>> >>> Stan: did you really need to quote the whole text for that one >>> sentence? That's pretty uneconomic... ;-) >> >> >> I was busy. > > > Yeah, me too - reading it! ;-)Compare it to the effort of reading the Oppenheim paper.
On 2004-08-11 16:44:27 +0200, Stan Pawlukiewicz <spam@spam.mitre.org> said:> Stephan M. Bernsee wrote: >> On 2004-08-10 18:32:35 +0200, Stan Pawlukiewicz <spam@spam.mitre.org> said: >> >>> Stephan M. Bernsee wrote: >>> >>>> >>>> Stan: did you really need to quote the whole text for that one >>>> sentence? That's pretty uneconomic... ;-) >>> >>> >>> I was busy. >> >> >> Yeah, me too - reading it! ;-) > > Compare it to the effort of reading the Oppenheim paper.I see. Thanks for saving me the time :-) -- Stephan M. Bernsee http://www.dspdimension.com
Rune Allnor wrote:> Mark Borgerding <mark@borgerding.net> wrote in message news:<411912d9$1@news.xetron.com>......>>There's no "nearly" about it. QC uses the spin of photons to make a >>message that cannot be intercepted and retransmitted. Anyone who reads >>the message destroys it in the process. > > > I don't understand this. Mind you, I know nothing about Quantum > Cryptography than has been mentioned in this thread, so please bear with > my perhaps all too obvious ignorance of this field... > > Now, in my naive mind, secure communication is first and foremost a matter > of "communication", i.e. transmitting some piece of information from point > A to point B. Only after having achieved that, does the qualifier "secure" > apply. So to me, the receiver needs to get a copy of the message, or the > system has failed. > > "Secure" systems aim to achieve this in the presence of an evesdropper, > somebody who listens in on the message. It follows that cryptography > is a method to protect the information of the message from being > understood by the evesdropper. > > If you agree with me in these premises, what I have learned about > Quantum Cryptography (QC) in this thread makes little sense. > > If somebody, either the intended receiver or the evesdropper, intecepts > the message, the message is destroyed. If it so happens that it is the > evesdropper who recieves the message, the message is lost what the > intended receiver is concerned, and the communication system fails in > its basic premise. The use of QC actually appears to supply a malicious > interferent with a perfect means to block the communications channel. > > It follows that QC is only useful in systems that a priori are perfectly > protected from unauthorized evesdropping, which by definition makes QC > (or any form of cryptography, for that matter) obsolete in the first > place. > > It's late afternoon and I've been in a too hot office for too long > today, so I can't find the obvious flaw in my reasoning. > > Could somebody help me see it? > > RuneThe actual message is encrypted with a one-time pad. That is known to be secure. QC is the means used to distribute the pad; only one receiver can get a copy of it for quantum reasons. The remaining difficulty, whose solution I can only guess at, is the need for it to be useful only to the intended recipient. Jerry -- ... the worst possible design that just meets the specification - almost a definition of practical engineering. .. Chris Bore ������������������������������������������������������������������������
Rune Allnor wrote: ...> If somebody, either the intended receiver or the evesdropper, intecepts > the message, the message is destroyed. If it so happens that it is the > evesdropper who recieves the message, the message is lost what the > intended receiver is concerned, and the communication system fails in > its basic premise. The use of QC actually appears to supply a malicious > interferent with a perfect means to block the communications channel.If you maliciously want to block communication, you can always just cut the cable of any communication channel (you know what I mean). As an eavesdropper, you gain much more if you can listen in on a secret conversation. But the information you gain is only useful if the communicating parties believe they are not being listened to. Otherwise you might even gain negative information (to use Lem's wordings), ie. the parties, knowing you are listening, might try to mislead you with disinformation. The idea of QC is this: Alice wants to send Bob some random bits (this is useful for setting up private keys between Alice and Bob for classical symmetric crypto or, as Mark suggested, for setting up a one time pad). She uses a quantum box to do this. Bob's box spits out the bits and lights either a red or a green light, depending on whether Eve was listening or not. If the light was red (this also happens with an arbitrarily small positive probability even if Eve did not intercept the message), Bob asks Alice to send some new bits. They keep doing this until either they share a set of proven secret random bits, or they get tired (at which time Eve has successfully blocked communication, or they have to send Scotty to fix the quantum cable). Regards, Andor
Reply by ●August 12, 20042004-08-12
Andor Bariska <an2or@nospam.net> wrote in message news:<411a39c2$1@pfaff2.ethz.ch>...> Rune Allnor wrote: > ... > > If somebody, either the intended receiver or the evesdropper, intecepts > > the message, the message is destroyed. If it so happens that it is the > > evesdropper who recieves the message, the message is lost what the > > intended receiver is concerned, and the communication system fails in > > its basic premise. The use of QC actually appears to supply a malicious > > interferent with a perfect means to block the communications channel. > > If you maliciously want to block communication, you can always just cut > the cable of any communication channel (you know what I mean).Actually, I don't. If we are talking about an optic fiber, yes, I agree with you. But we could be talking about some sort of radio or other type of wireless channel? If so, blocking useful transmission between A and B becomes amatter of destroying the various tranceivers, which may be a very difficult task.> As an eavesdropper, you gain much more if you can listen in on a secret > conversation. But the information you gain is only useful if the > communicating parties believe they are not being listened to. Otherwise > you might even gain negative information (to use Lem's wordings), ie. > the parties, knowing you are listening, might try to mislead you with > disinformation.Sure. But I get the impression that QC is intended as ameans to releave oneself from such worries?> The idea of QC is this: Alice wants to send Bob some random bits (this > is useful for setting up private keys between Alice and Bob for > classical symmetric crypto or, as Mark suggested, for setting up a one > time pad). She uses a quantum box to do this. Bob's box spits out the > bits and lights either a red or a green light, depending on whether Eve > was listening or not. If the light was red (this also happens with an > arbitrarily small positive probability even if Eve did not intercept the > message), Bob asks Alice to send some new bits. They keep doing this > until either they share a set of proven secret random bits, or they get > tired (at which time Eve has successfully blocked communication, or they > have to send Scotty to fix the quantum cable).OK... I'm not sure I understand everything here... now I am a bit confused abdout how safe it would be to rely on singular photons to communicate a message. Assume we are using a fiber cable and send these polarized random photons down the line (not worrying about eavesdropping). There is always the chance that this particular photon escapes out of the optical core of the cable, and is lost. It could also be scattered off some impurity in the cable, being lost that way. So B receives his random sequence of bits, not knowing that something is missing, and therefore not getting a useful sequence of numbers. My previous comparision to telepathy, which was intended as a joke, seems at first glance to be a bit too good for comfort: A series of random bits are received. Half of them are lost and one does not know which ones. When guessing a series of bits, one would expect half of the guessed bits to be correct and one doesn't know which ones. Yeah, right. I know when it's time to leave a subject... Rune
Rune Allnor wrote:> Andor Bariska wrote: > >>Rune Allnor wrote: >>... >> >>>If somebody, either the intended receiver or the evesdropper, intecepts >>>the message, the message is destroyed. If it so happens that it is the >>>evesdropper who recieves the message, the message is lost what the >>>intended receiver is concerned, and the communication system fails in >>>its basic premise. The use of QC actually appears to supply a malicious >>>interferent with a perfect means to block the communications channel. >> >>If you maliciously want to block communication, you can always just cut >>the cable of any communication channel (you know what I mean). > > > Actually, I don't.Well, cut the cable, shoot the satellite, bomb the base station, emp the computers, drown a radio reciever in white noise ... usually, in peace time, this is not an option. If you are company A and want to stop companies B and C from communicating, you don't go and blow up their telephone stations.>>As an eavesdropper, you gain much more if you can listen in on a secret >>conversation. But the information you gain is only useful if the >>communicating parties believe they are not being listened to. Otherwise >>you might even gain negative information (to use Lem's wordings), ie. >>the parties, knowing you are listening, might try to mislead you with >>disinformation. > > > Sure. But I get the impression that QC is intended as ameans to releave > oneself from such worries?Exactly.> > >>The idea of QC is this: Alice wants to send Bob some random bits (this >>is useful for setting up private keys between Alice and Bob for >>classical symmetric crypto or, as Mark suggested, for setting up a one >>time pad). She uses a quantum box to do this. Bob's box spits out the >>bits and lights either a red or a green light, depending on whether Eve >>was listening or not. If the light was red (this also happens with an >>arbitrarily small positive probability even if Eve did not intercept the >>message), Bob asks Alice to send some new bits. They keep doing this >>until either they share a set of proven secret random bits, or they get >>tired (at which time Eve has successfully blocked communication, or they >>have to send Scotty to fix the quantum cable). > > > OK... I'm not sure I understand everything here... now I am a bit confused > abdout how safe it would be to rely on singular photons to communicate > a message. Assume we are using a fiber cable and send these polarized > random photons down the line (not worrying about eavesdropping). There > is always the chance that this particular photon escapes out of the > optical core of the cable, and is lost. It could also be scattered off > some impurity in the cable, being lost that way. So B receives his random > sequence of bits, not knowing that something is missing, and therefore not > getting a useful sequence of numbers.You can view lost photons (bits) as bit errors. This and photon depolarization pose some problems for quantum communication - it is about equivalent to bit errors in classical communication. You can use quantum bit error correction codes in a similar manner as classical error correction codes to allow a certain maximum bit error rate and still guarantee reliable communication. In fact, quantum error correction is the main reason why the prospect of a quantum computer is at all possible.> Yeah, right. I know when it's time to leave a subject...If you wish ... :-)> > RuneRegards, Andor
