Classical to Quantum!
Started by santosh nath ●August 10, 2004
Rune Allnor wrote:
> My previous comparision to telepathy, which was intended as a joke, seems > at first glance to be a bit too good for comfort: A series of random bits > are received. Half of them are lost and one does not know which ones.
They DO know which ones. The two parties can share information after the transmission that allows them both to know which bits were received correctly.
Jerry Avins <jya@ieee.org> writes:
> The actual message is encrypted with a one-time pad. That is known to be > secure. QC is the means used to distribute the pad; only one receiver > can get a copy of it for quantum reasons. The remaining difficulty, > whose solution I can only guess at, is the need for it to be useful only > to the intended recipient. >
I'm late to this discussion, so disregard this if it's not what you are referring to... The receiver knows which bits have been correctly intercepted by the eavesdropper, and drops them from the OTP. I can't recall how that works, but I read a good description in The Code Book by Simon Singh. Cheers, Martin -- martin.j.thompson@trw.com TRW Conekt, Solihull, UK http://www.trw.com/conekt
Mark Borgerding <mark@borgerding.net> wrote in message news:<v4JSc.12165$Nl1.7872@fe1.columbus.rr.com>...
> Rune Allnor wrote: > > > My previous comparision to telepathy, which was intended as a joke, seems > > at first glance to be a bit too good for comfort: A series of random bits > > are received. Half of them are lost and one does not know which ones. > They DO know which ones. > > The two parties can share information after the transmission that allows > them both to know which bits were received correctly.
Uh, what? Do you mean that QC relies on a second line of transmission? That one first sends a message over a QC channel, and afterwards calls up by some other means and tells the receiver what was sent over the QC channel? Assume I send you a series of bits: M_sent = 1010101010101010101.... Soemthing goes wrong and one bit is lost dye to the physics of optical media (not eavesdropping) so you receive [use fixed-width font] M_bit_missing = 10101010100101010101.... ^ Glitch, bit missing all recieved bits correct How do you recover from that? Error correcting codes, as far as I remember from the basic intro course in coding theory, only deal with bits that are wrong but stil *present* in the data: M_bit_error = 1010101010100010101010101.... ^ Bit present but has wrong value Rune
Rune Allnor wrote:
> Mark Borgerding <mark@borgerding.net> wrote in message news:<v4JSc.12165$Nl1.7872@fe1.columbus.rr.com>... > >>Rune Allnor wrote: >> >> >>>My previous comparision to telepathy, which was intended as a joke, seems >>>at first glance to be a bit too good for comfort: A series of random bits >>>are received. Half of them are lost and one does not know which ones. >> >>They DO know which ones. >> >>The two parties can share information after the transmission that allows >>them both to know which bits were received correctly. > > > Uh, what? > > Do you mean that QC relies on a second line of transmission? That one > first sends a message over a QC channel, and afterwards calls up by > some other means and tells the receiver what was sent over the QC channel? > > Assume I send you a series of bits: > > M_sent = 1010101010101010101.... > > Soemthing goes wrong and one bit is lost dye to the physics of optical > media (not eavesdropping) so you receive [use fixed-width font] > > M_bit_missing = 10101010100101010101.... > ^ > Glitch, bit missing > all recieved bits correct > > How do you recover from that? Error correcting codes, as far as I > remember from the basic intro course in coding theory, only deal > with bits that are wrong but stil *present* in the data: > > M_bit_error = 1010101010100010101010101.... > ^ > Bit present but has > wrong value > > Rune
Assume there are no bits lost. Sender Alice and receiver Bob may use one of two polarity schemes A & B. The Bob can only correctly receive a bit when his polarity matches the polarity Alice used. This is the "quantum" part. Alice sends 1A 0A 1A 1B 1B 0B Bob randomly chooses a sequence of polarities for receiving that will be wrong half the time. So he receives the bits 1A 0B 1A 1B 0A 0B ^^ ^^ Bob then says "I was listening with ABABAB" Alice sent the msg with AAABBB, so two bits could not be received right. She can tell Bob which bits are unreliable without fear of anyone knowing the message. -- Mark
Assume you have a time slot for each bit (given bit rate). If the reciever does not detect a bit in a given stime slot, it inserts a zero (bit error).
Stan Pawlukiewicz wrote:
> Andor Bariska wrote: > >> santosh nath wrote:
>>> "Quantum" signal processing - new branch of DSP brings new dimension >>> in signal analysis >> >> >> >> Never heard of this. > > > There was an article in IEEE Signal Processing magazine by Oppenheim and > one of his students, whos name I should remember, a year or 2 back on > this topic.
Well, I got around to reading that article [1], thanks for the link Stan. It is basically a summary of Dr. Eldar's Ph.D. thesis, which was not available from her website (the link is dead), so I can only judge from the article (which went easy on the maths). I can't say that I'm overly enthusiastic about its contents. The main idea is to interpret signals as vectors and use projections of vectors in a Hilbert space onto sub-Hilbert spaces to process the signals. Because this is what happens during a quantum measurement operation, the whole thing is called "quantum signal processing" (QSP), although it has nothing to do with quantum information theory. This viewpoint is supposed to give a mathematical frame with which to analyze certain class of signal processing techniques. Dithered quantization is mentioned - there, the QSP viewpoint already fails (in my opinion) because only additive dither is considered (or so I understood), whereas noiseshaped feedback quantization cannot be interpreted in this framework ... It does have a nice introduction to the problem of quantum detection, though. And a pretty impressive references list. Any other opinions? Regards, Andor [1] Eldar, Y.C. and Oppenheim, A.V: "Quantum Signal Processing" IEEE Signal Processing Magazine, November 2002
