Hi all, I heard that MPEG2 and MPEG1 use same compression methods. MPEG2's MP@LL and MPEG1 are all 4:2:0, 352*288*30. But MPEG2's MP@LL is 4Mbit/s and MPEG1 is 1.5Mbit/s. Why they have different bit rates? And if I want to do 352*288*30 video compression. Shall I choose MPEG2 or MPEG1?? Any suggestions will be appreciated! Best regards, Davy
MPEG2 MP@LL and MPEG1?
Started by ●September 4, 2005
Reply by ●September 4, 20052005-09-04
Davy wrote:> Hi all, > > I heard that MPEG2 and MPEG1 use same compression methods. > > MPEG2's MP@LL and MPEG1 are all 4:2:0, 352*288*30. But MPEG2's MP@LL is > 4Mbit/s and MPEG1 is 1.5Mbit/s. Why they have different bit rates? > > And if I want to do 352*288*30 video compression. Shall I choose MPEG2 > or MPEG1??You've got a few things confused. First of all, MPEG can use any bitrate you want, so that's why the bitrates are different in your samples. Secondarly, 352x288@30 isn't typical; I think you're thinking of VCD PAL which is 352x288 @ 25fps. If that's your target, VCD PAL MPEG-1 would give you the most compatibility across platforms.
Hi Jim, Thank you for your help! Do you mean when I use the same compression parameter to generate MPEG1 or MPEG2, the compression ratio will be the same? My target is PC. And can MPEG1 be expanded to 720*480*30? All the best, Davy
Reply by ●September 5, 20052005-09-05
"Davy" <zhushenli@gmail.com> a �crit dans le message de news: 1125844327.579957.139370@g47g2000cwa.googlegroups.com... | Hi all, | | I heard that MPEG2 and MPEG1 use same compression methods. | | MPEG2's MP@LL and MPEG1 are all 4:2:0, 352*288*30. But MPEG2's MP@LL is | 4Mbit/s and MPEG1 is 1.5Mbit/s. Why they have different bit rates? 4 Mbit/s is probably the maximum bitrate allowed in MP@LL. You can't compare it to the 1.5 Mbit/s of mpeg1 | | And if I want to do 352*288*30 video compression. Shall I choose MPEG2 | or MPEG1?? Mpeg2 because it is more powerfull than mpeg1 | Any suggestions will be appreciated! | | Best regards, | Davy |
Davy wrote:> Do you mean when I use the same compression parameter to generate MPEG1 > or MPEG2, the compression ratio will be the same?I'm saying that MPEG encoders by nature usually allow either quality-based encoding (constant quality throughout the file), or bitrate-based encoding (constant bitrate/size per second throughout the file), or both. So it doesn't matter what size you're working with, if you want a file that doesn't chew up more than 150KB/s then that's what you set the bitrate to. Of course, larger bitrates result in larger files, but the larger the file is the better it looks.> My target is PC. And can MPEG1 be expanded to 720*480*30?MPEG-1 can indeed be encoded at 720x480 but if you're working with interlaced material you should be using MPEG-2. MPEG-1 has no provisions for working with interlaced source material and the output is worse.
