Possible to adjust ISO sensitivity on each pixel in CMOS image sensors?
Started by Frank ●September 5, 2005
Is it possible to design some CMOS sensors which can select a lower
ISO sensitivity value in hot areas and higher ISO on shadow areas? My
pictures tend to have overexposed areas.
It is possible to make different pixels have different sensitivity (Fuji does
this) but the pixel sensitivity is set at the time of manufacturing and can't be
altered on a picture-by-picture basis.  So there is no way to change the pixel's
sensitivity to match your particular picture.
Let me also address your underlying question.  First of all, it is important to
differentiate between overexposure and too much contrast (or too large a dynamic
range).  If your problem is really just that parts of the picture are
overexposed, you could adjust the exposure downward to compensate (underexpose
slightly).  I know my camera tends to overexpose when set to "normal", so a
slight decrease using the exposure compensation often helps.
On the other hand, if you end up with pixels that are both 100% white
(overexposed or "blown out highlights") and 100% black (underexposed or "block
up shadows"), then the problem is that the scene has too great a contrast range
for your camera's sensor to handle.  (Use a histogram to see what is happening.)
Some cameras have adjustable contrast range, so then you can simply decrease the
contrast to help deal with this.  Also, higher end cameras such as digital SLRs
tend to have wider and more adjustable dynamic range, so you are more likely to
capture the scene's entire brightness range in your exposure.  Another technique
that is sometimes used is to make 2 exposures, one for the highlights and one
for the shadows, and then combine then in software.  This is obviously limited
to landscapes and other unchanging subjects and probably requires a tripod.
Another tip is to use a flash, fill light, or reflector to add light to the
shadows, thereby decreasing the entire scene's contrast range.  This is
generally only possible when the shadows are physically located close to the
camera--e.g. a flash won't help much with a shadowy mountain range 500 yards
away!  Finally, in landscape work where the sky or sun is visible, a "split
neutral density filter" is often used to darken one area (usually the sky) while
leaving the rest unaffected, again decreasing the total contrast range to better
fit within the camera's limitations.
If none of these are an option for you, you just have to decide if you would
rather capture the highlights and loose some shadows or vice versa.  That is an
artistic decision based on the subject matter and what kind of image you are
trying to achieve.
Jon Harris
SPAM blocker in place:
Remove 99 (but leave 7) to reply
"Frank" <Francis.invalid@hotmail.com> wrote in message
news:431bdacb@news.starhub.net.sg...
> Is it possible to design some CMOS sensors which can select a lower > ISO sensitivity value in hot areas and higher ISO on shadow areas? My > pictures tend to have overexposed areas.
It could be the dynamic range that affected my images. I was shooting
portrait
beside the window and intended to have clear background outside the window.
However, on a P&S camera, I got was clear portrait and a white background
with a spot metering on the face.
Is my senario a dynamic range problem or partially overexposure problem? Is
it likely to adjust either ISO or dynamic range or every pixel by software
before
shutter release?
"Jon Harris" <jon99_harris7@hotmail.com> wrote in message
news:TBRSe.12733$Sx4.12076@trnddc06...
does
can't be
pixel's
> sensitivity to match your particular picture. > > Let me also address your underlying question. First of all, it is
important to
dynamic
> range). If your problem is really just that parts of the picture are > overexposed, you could adjust the exposure downward to compensate
(underexpose
a
> slight decrease using the exposure compensation often helps. > > On the other hand, if you end up with pixels that are both 100% white > (overexposed or "blown out highlights") and 100% black (underexposed or
"block
range
happening.)
decrease the
SLRs
likely to
technique
one
limited
tripod.
the
> shadows, thereby decreasing the entire scene's contrast range. This is > generally only possible when the shadows are physically located close to
the
yards
"split
while
better
> fit within the camera's limitations. > > If none of these are an option for you, you just have to decide if you
would
is an
are
> trying to achieve. > > -- > Jon Harris > SPAM blocker in place: > Remove 99 (but leave 7) to reply > > "Frank" <Francis.invalid@hotmail.com> wrote in message > news:431bdacb@news.starhub.net.sg... > > Is it possible to design some CMOS sensors which can select a lower > > ISO sensitivity value in hot areas and higher ISO on shadow areas? My > > pictures tend to have overexposed areas. > >
Frank wrote:
> > It could be the dynamic range that affected my images. I was shooting > portrait > beside the window and intended to have clear background outside the window.
That's dynamic range that's causing the problem. There is a solution to this that involves taking two pictures, one exposed correctly for the portrait (with the window overexposed) and one exposed for the window (with the portrait underexposed). You can then select each pixel from the "best" image, either manually or automatically, to make a composite. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
Frank wrote:
> It could be the dynamic range that affected my images. I was shooting > portrait > beside the window and intended to have clear background outside the window. > However, on a P&S camera, I got was clear portrait and a white background > with a spot metering on the face. > > Is my senario a dynamic range problem or partially overexposure problem? Is > it likely to adjust either ISO or dynamic range or every pixel by software > before > shutter release?
With emulsion, and to a smaller extent with most digital sensors, the dynamic range of the original recorded data -- negative, pixel values -- is greater than what can be reproduced in the display. With film, the dynamic range is compressed when printing by "dodging" and "burning in" particular areas. With digital images, software can do similar operations. Photoshop (costly) and Gimp (free) are two programs that allow such manipulation. Of course, once the sensor saturates white or black, there are no data left to manipulate. ... Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Mark Robinson wrote:
> Frank wrote: > >>It could be the dynamic range that affected my images. I was shooting >>portrait >>beside the window and intended to have clear background outside the window. > > > That's dynamic range that's causing the problem. There is a solution > to this that involves taking two pictures, one exposed correctly for > the portrait (with the window overexposed) and one exposed for the > window (with the portrait underexposed). You can then select each pixel > from the "best" image, either manually or automatically, to make > a composite.
Sometimes, fill flash is the simplest way. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
news:431bf59c$1@news.starhub.net.sg...
> It could be the dynamic range that affected my images. I was shooting > portrait > beside the window and intended to have clear background outside the > window. > However, on a P&S camera, I got was clear portrait and a white background > with a spot metering on the face. > > Is my senario a dynamic range problem or partially overexposure problem? > Is > it likely to adjust either ISO or dynamic range or every pixel by software > before > shutter release? >
Hello Frank, Yes as the others said, you have an DR problem. And Jerry's suggestion is the simplest. Set the camera to properly expose the background, and then use a fill flash to bring the rest of the subject into proper exposure. You may have to set the camera on manual. There are methods for handling very high contrast scenes (such as combining shots taken with two different exposures), but if compressed to the typical 4/5 F-stop range for printing or viewing, they tend to look kind of weird. Usually for portraiture, you want soft light so if you have the person by the window, you can add a reflector just behind them putting some of the window's light back onto their face. This will be less harsh that a simple flash. Or you can add a diffuser to the flash or fire it into a reflector. These methods all work to reduce the pointance of the light. Light sources with high pointances tend to exaggerate skin imperfections. Clay
Indeed, but this is comp.dsp after all :-) Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
news:bfadnagI9v14yYHeRVn-2Q@rcn.net...
> Frank wrote: >> It could be the dynamic range that affected my images. I was shooting >> portrait >> beside the window and intended to have clear background outside the window. >> However, on a P&S camera, I got was clear portrait and a white background >> with a spot metering on the face. >> >> Is my senario a dynamic range problem or partially overexposure problem? Is >> it likely to adjust either ISO or dynamic range or every pixel by software >> before >> shutter release? > > With emulsion, and to a smaller extent with most digital sensors, the dynamic > range of the original recorded data -- negative, pixel values -- > is greater than what can be reproduced in the display. With film, the dynamic > range is compressed when printing by "dodging" and "burning in" particular > areas. With digital images, software can do similar operations. Photoshop > (costly) and Gimp (free) are two programs that allow such manipulation. Of > course, once the sensor saturates white or black, there are no data left to > manipulate.
I agree with you about film, but in my experience, this has not been a problem with digital images. My monitor (when properly adjusted) can display the full range of brightness in a standard image file. And on-line photo printing sites handle images that contain the full 0-255 brightness range of JPEG files just fine. In fact, if you do submit a photo with limited contrast, many will stretch the tonal range to fill out the dynamic range (the better ones make this an option).
Almost any time you have both the primary light souce (outdoors in this case) and the object being lit by that source (face in this case) both in the same exposure, you are asking for dynamic range problems. The light source is typically many times brighter than the object reflecting the light so it is difficult to capture both completely. Other common examples are a portrait by lamp-light that includes the lamp or an outdoor picture that includes the sun.
> Is my senario a dynamic range problem or partially overexposure problem? Is > it likely to adjust either ISO or dynamic range or every pixel by software > before shutter release?
I'll say it again--it is not possible. Think about what would be required. Adjusting "by software" implies that the digital image data is already present. But "before shutter release" means that you haven't captured it yet. So there is a chicken and egg problem. You might think you could make 2 expsosures in rapid succession, using the first one to control the pixel sensitivity of the second. But this would require that the image was absolutely constant between the 2 exposures and would most likely have problems with sharp edges where it transitions from light to dark. Not to mention that sensors aren't built with the capability to adjust individual pixel sensitivty on the fly! A much simpler solution is to create sensors with wider dynamic range, which is increasingly happening. In the meantime, you are left with the options I listed in my first reply and others have expanded on: 1) use fill light or flash, 2) use a reflector, 3) take 2 exposures and combine in software or 4) use a split neutral density filter. In your case, #1 or #2 sound like the best options. Simply turning on a bright light in the room may be enough to do the trick.
> "Jon Harris" <jon99_harris7@hotmail.com> wrote in message > news:TBRSe.12733$Sx4.12076@trnddc06... >> It is possible to make different pixels have different sensitivity (Fuji > does >> this) but the pixel sensitivity is set at the time of manufacturing and > can't be >> altered on a picture-by-picture basis. So there is no way to change the > pixel's >> sensitivity to match your particular picture. >> >> Let me also address your underlying question. First of all, it is > important to >> differentiate between overexposure and too much contrast (or too large a > dynamic >> range). If your problem is really just that parts of the picture are >> overexposed, you could adjust the exposure downward to compensate > (underexpose >> slightly). I know my camera tends to overexpose when set to "normal", so > a >> slight decrease using the exposure compensation often helps. >> >> On the other hand, if you end up with pixels that are both 100% white >> (overexposed or "blown out highlights") and 100% black (underexposed or > "block >> up shadows"), then the problem is that the scene has too great a contrast > range >> for your camera's sensor to handle. (Use a histogram to see what is > happening.) >> Some cameras have adjustable contrast range, so then you can simply > decrease the >> contrast to help deal with this. Also, higher end cameras such as digital > SLRs >> tend to have wider and more adjustable dynamic range, so you are more > likely to >> capture the scene's entire brightness range in your exposure. Another > technique >> that is sometimes used is to make 2 exposures, one for the highlights and > one >> for the shadows, and then combine then in software. This is obviously > limited >> to landscapes and other unchanging subjects and probably requires a > tripod. >> Another tip is to use a flash, fill light, or reflector to add light to > the >> shadows, thereby decreasing the entire scene's contrast range. This is >> generally only possible when the shadows are physically located close to > the >> camera--e.g. a flash won't help much with a shadowy mountain range 500 > yards >> away! Finally, in landscape work where the sky or sun is visible, a > "split >> neutral density filter" is often used to darken one area (usually the sky) > while >> leaving the rest unaffected, again decreasing the total contrast range to > better >> fit within the camera's limitations. >> >> If none of these are an option for you, you just have to decide if you > would >> rather capture the highlights and loose some shadows or vice versa. That > is an >> artistic decision based on the subject matter and what kind of image you > are >> trying to achieve. >> >> -- >> Jon Harris >> SPAM blocker in place: >> Remove 99 (but leave 7) to reply >> >> "Frank" <Francis.invalid@hotmail.com> wrote in message >> news:431bdacb@news.starhub.net.sg... >> > Is it possible to design some CMOS sensors which can select a lower >> > ISO sensitivity value in hot areas and higher ISO on shadow areas? My >> > pictures tend to have overexposed areas.
