Hi, I work with an 24bit evaluation-adc-board from AKM. The board sends the data in 32bits to the DSP. I can choose whether I would justify the 24bits at the MSB or the LSB of the 32bit word which is send to the DSP. Now my question: what`s the difference and what makes more sense. The DSP can both formats. Markus
AD converter
Started by ●September 5, 2005
Reply by ●September 5, 20052005-09-05
Markus wrote:> Hi, > > I work with an 24bit evaluation-adc-board from AKM. The board sends the > data in 32bits to the DSP. I can choose whether I would justify the > 24bits at the MSB or the LSB of the 32bit word which is send to the > DSP. Now my question: what`s the difference and what makes more sense. > The DSP can both formats. > > Markus >The difference should be obvious and what makes sense depends on you. Early in a design project I like having things left justified because I can change the ADC resolution without changing the meaning of the word. There are other reasons that left-justifying everything makes sense, but it really boils down to personal preference. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Is your DSP a 32-bit fixed point processor? If so, the way you justify controls whether you have 8 bits of "headroom" (also called guard bits) for the signal to grow during processing or 8 bits extra at the end to deal with round-off during processing. Based on what type of processing you are doing, it might make sense to choose one or the other. If you are planning on mixing a lot of signals together so that result may grow, the former may be a better choice. Some type of compromise might be the best bet. I haven't done much 32-bit fixed-point processing, but I would imagine you would leave a few guard bits at the top to avoid overflow and use the rest for additional precision at the low end. If you are using a floating-point DSP or aren't doing any significant processing, then it's a moot point and you can choose whichever is easiest or you like best. Some people light LSB-justifying so that the digital word put out by the ADC is exactly what ends up in the DSP (although I guess you still have to deal with sign-extending for negative values). -- Jon Harris SPAM blocker in place: Remove 99 (but leave 7) to reply "Markus" <Markus.Schweikhardt@web.de> wrote in message news:1125948240.082138.139480@z14g2000cwz.googlegroups.com...> Hi, > > I work with an 24bit evaluation-adc-board from AKM. The board sends the > data in 32bits to the DSP. I can choose whether I would justify the > 24bits at the MSB or the LSB of the 32bit word which is send to the > DSP. Now my question: what`s the difference and what makes more sense. > The DSP can both formats. > > Markus >
"Jon Harris" <jon99_harris7@hotmail.com> wrote in news:K83Te.20215$cy4.1003@trnddc05:> Is your DSP a 32-bit fixed point processor? If so, the way you > justify controls whether you have 8 bits of "headroom" (also called > guard bits) for the signal to grow during processing or 8 bits extra > at the end to deal with round-off during processing. Based on what > type of processing you are doing, it might make sense to choose one or > the other. If you are planning on mixing a lot of signals together so > that result may grow, the former may be a better choice. > > Some type of compromise might be the best bet. I haven't done much > 32-bit fixed-point processing, but I would imagine you would leave a > few guard bits at the top to avoid overflow and use the rest for > additional precision at the low end. > > If you are using a floating-point DSP or aren't doing any significant > processing, then it's a moot point and you can choose whichever is > easiest or you like best. Some people light LSB-justifying so that > the digital word put out by the ADC is exactly what ends up in the DSP > (although I guess you still have to deal with sign-extending for > negative values). >Most of the time, MSB first is used. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
