MPEG's coded_block_pattern problem?
Started by Davy September 11, 2005
Hi all,
I am reading MPEG-2's spec. It has a VLC coded_block_pattern_420. The
spec said we can get cbp from coded_block_pattern_420. But what's cbp's
function? Is it a important parameter?
Any suggestions will be appreciated!
Best regards,
Davy
And There is a further problem: I read the coded_block_pattern VLC
table.
The shortest VLC is 111 and cbp=60.
I can make an intelligent guess.
Usually cbp represents a six bit number were each bit stands for each
block(since this is a 420 ) thus a cbp = 60 ( => 1 1 1 1 0 0) thus it
may be found from many sequences that the chroma component (Cr Cb)
usually do not have any coefficients for coding (which I feel is
intutive) and only luma component are present. Further loss of chroma
would also not have much artifacts compared to loss of luma (Y).
Is it right?
Best regards,
Davy
"Davy" <zhushenli@gmail.com> a &#2013265929;crit dans le message de news: 1126592823.103230.103840@o13g2000cwo.googlegroups.com...
| table.
| Is it right?
yes
| Best regards,
| Davy
Hi ast,
Aha, I understand.
I read the table and find another related problem ;-)
VLC_length = 3 => cbp = 60;
VLC_length = 4 => cbp = 4,8,16,32;
VLC_length = 5 => cbp = 12,48,20,40...;
The probability of "4 block per microblock" is intuitively larger than
others.
Do you think the probability of "1 block per microblock" is larger
than "2 block per microblock" ?
Best regards,
Davy
"Davy" <zhushenli@gmail.com> a &#2013265929;crit dans le message de news: 1126612343.391773.51440@f14g2000cwb.googlegroups.com...
| Hi ast,
| Aha, I understand.
| others.
The smaller the vlc length, the higher the probability. So the probability of "1 block per
macroblock" is probably larger than "2 block per macroblock" even if it is not intuitive.
| Best regards,
| Davy
