(This question is coming from an OFDM perspective but is obviously not confined to OFDM) If you are computing the peak to average power ratio (PAPR) of a block of data, do you include the peak in computing the average power? For example, do you compare the peak power with the average of all the rest? Or do you compare the peak with the whole block including itself? I am pretty sure that it is the latter, judging by some papers I have read, but I would just like to see if there is a consensus on this here in comp.dsp. Slainte Porterboy
Started by ●September 13, 2005
Reply by ●September 13, 20052005-09-13
<porterboy76@yahoo.com> wrote in message news:1126594755.866583.128220@f14g2000cwb.googlegroups.com...> (This question is coming from an OFDM perspective but is obviously not > confined to OFDM) > > If you are computing the peak to average power ratio (PAPR) of a block > of data, do you include the peak in computing the average power? For > example, do you compare the peak power with the average of all the > rest? Or do you compare the peak with the whole block including itself? > > I am pretty sure that it is the latter, judging by some papers I have > read, but I would just like to see if there is a consensus on this here > in comp.dsp.In cellular, we use the latter. It is relatively easy to have an instrument find the long term average and the peaks. It takes more effort, to recalculate the average after omitting the peaks, plus a question arises as to how much of the peak do you leave out. So just find the peak and the long term average and then their ratio. This is how I've seen it done for AMPS, iDEN, TDMA, GSM, and CDMA protocols. Clay
porterboy76@yahoo.com wrote:> example, do you compare the peak power with the average of all the > rest? Or do you compare the peak with the whole block including itself?As Clay said, the latter is definitely right. However, I rather wonder why the former can be a measure for PAPR. Average power represent the average of all signal powers not of some specific powers. Do you have any example where the average is calculated except some conditional cases. -James GOLD
<porterboy76@yahoo.com> wrote in message news:1126594755.866583.128220@f14g2000cwb.googlegroups.com...> (This question is coming from an OFDM perspective but is obviously not > confined to OFDM) > > If you are computing the peak to average power ratio (PAPR) of a block > of data, do you include the peak in computing the average power? For > example, do you compare the peak power with the average of all the > rest? Or do you compare the peak with the whole block including itself? > > I am pretty sure that it is the latter, judging by some papers I have > read, but I would just like to see if there is a consensus on this here > in comp.dsp. > > Slainte > Porterboy >Definitely the latter, however, make sure that your measurement techniques are in-line with the reason why you care about peak power in the first place. For instance, say I am detecting peak power across a 50 ohm resistor by measuring the voltage with an ultra fast ADC (>1GHz full power bandwidth) and I have a huge voltage spike in just one of my samples. Should this be considered the peak? The spike could be as short as 1ns and not likely cause a change in temperature of the resistor, and probably wouldn't even show up on FCC test equipment. Hope you see where I'm going with this. The nice thing about DSP is that you can filter the data and pick the appropriate measurement algorithm. Thomas
Clay S. Turner wrote:> <porterboy76@yahoo.com> wrote in message > news:1126594755.866583.128220@f14g2000cwb.googlegroups.com... > > (This question is coming from an OFDM perspective but is obviously not > > confined to OFDM) > > > > If you are computing the peak to average power ratio (PAPR) of a block > > of data, do you include the peak in computing the average power? For > > example, do you compare the peak power with the average of all the > > rest? Or do you compare the peak with the whole block including itself? > > > > I am pretty sure that it is the latter, judging by some papers I have > > read, but I would just like to see if there is a consensus on this here > > in comp.dsp. > > > In cellular, we use the latter. It is relatively easy to have an instrument > find the long term average and the peaks. It takes more effort, to > recalculate the average after omitting the peaks, plus a question arises as > to how much of the peak do you leave out. > > So just find the peak and the long term average and then their ratio. This > is how I've seen it done for AMPS, iDEN, TDMA, GSM, and CDMA protocols. > > > > ClayI've seen peak RF power measured with a spectrum analyzer set with span = RBW and peak hold turned on. The trace will drift upward and little upticks will appear in it. The highest one is the peak power. I can remember feeding big signals into a microphone jack and tweaking an audio compressor to constrain the peak power to FCC limits. The average power is inclusive of everything. John
Reply by ●September 14, 20052005-09-14
Hi James, I am using a peak detector (in time) as a synchronisation algorithm. My definition of a peak in this algorithm is when the instantaneous power exceeds the rolling average power by a given factor. So either approach will work for me, provided I define the given "factor" correctly. The reason I asked the question is that when I eventually have to explain my algorithm, I would like to use a definition of PAPR that wont raise eyebrows. It's a small thing really, but I find it better not to give the cynics a foothold. Slainte Porterboy
