I am trying to start to use the DSP/BIOS for my application. I have a non-BIOS application that loads fine on the target with my custom .cmd file. But when I try to write a very simple program using DSP/BIOS, I see the following error when I try to "Load Program" Data Verification failed at address 0xFF80 Please verify target memory and memory map. I have looked at the .cmd file and the memory map etc but I do not see anything obviously wrong. I would really appreciate it if anybody has any pointers as to what else I can look at. I will really appreciate any help. TIA This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Failed to load program on target board
Started by ●September 20, 2005
Reply by ●September 20, 20052005-09-20
I too have run into this, very annoying, error message. Off the top of my head, I know of two things that cause this message. The first possibility that comes to mind is attempting to place initialized data in an area other than RAM (asssuming you are working with an emulator). The second possibility, I have run into this one personally, is attempting to load a program into FLASH using the "Load Program" command. This command will successfully load a program only into RAM memory. I would suggest that a good way to start figuring out the problem is to back up a step and see if one of TI's sample projects for the BIOS works correctly. BIOS applications generate a number of files that must be included in the project including a linker CMD file. If you need to specify additional linker commands, simply include the additional CMD files. Once you are able to get a "known good" sample program working, you can start making changes, one at a time, until you figure out where the problem is occuring. Based on your description, without knowledge of your application, the memory map, target processor, development environment, etc, I suspect that there is a strong possibility that one or more BIOS required files are missing. Again, the sample projects are helpfull here. You should be able to find a link to them under the product page for your processor on TI's website.
