SNR computation in SRC
Started by Govind ●September 23, 2005
Hi All,
I would appreciate if you could help me in following..
I have written a simple matlab code for converting sampling rate from 8KHz
to 16KHz. Now I have to measure it's SNR. For this I converted both the
signals to frequency domain (taking their FFTs) and then computed
signal-to-noise ratio (sum of squared input spectral samples devided by
sum of squared difference between the output spectral samples and the
input spectral samples). With this method I am getting SNR not more than
50-60dB (even for very high filter lengths). Can you please tell me what's
wrong with my method (I have seen posting mentioning that SNR should go as
high as 140dB)? Or please suggest correct method.
Thank you in advance.
Govind
This message was sent using the Comp.DSP web interface on
www.DSPRelated.com
in article urKdnY7SWfelqaneRVn-gw@giganews.com, Govind at
govind_s@conceptemsys.com wrote on 09/23/2005 12:58:
> I have written a simple matlab code for converting sampling rate from 8KHz > to 16KHz. Now I have to measure it's SNR. For this I converted both the > signals to frequency domain (taking their FFTs) and then computed > signal-to-noise ratio (sum of squared input spectral samples devided by > sum of squared difference between the output spectral samples and the > input spectral samples). With this method I am getting SNR not more than > 50-60dB (even for very high filter lengths). Can you please tell me what's > wrong with my method
not a particular good method to compute SNR. try upsampling a collection of known sine waves from 8 to 16kHz. then generate the exact same sine waves (from the same math) but at the 16 kHz rate. make sure you have your timing lined up because your SRC will have some delay. then subtract to get a difference (or error or "noise) signal and use that in your SNR computation.
> (I have seen posting mentioning that SNR should go as high as 140dB)?
how long is your impulse response of your LPF? to get 140, you will need about a 64 tap FIR. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
For SRC, the SNR is strongly dependent on what the signal is.  For example, for
your case of 8->16kHz, a 20 Hz signal is probably going to yield a much better
SNR that a 3.9kHz signal.
When I evaluate an SRC algorithm, I typically look at the interpolation filter
in the frequency domain and measure the stop-band attenuation.  The attenuation
is directly related to the level of the alias component that will be generated.
So if your filter has at least 100 dB attenuation from 4khz to 8kHz, then you
should get a SNR of at least 100 dB.
Jon Harris
SPAM blocker in place:
Remove 99 (but leave 7) to reply
"Govind" <govind_s@conceptemsys.com> wrote in message
news:urKdnY7SWfelqaneRVn-gw@giganews.com...
> Hi All, > > I would appreciate if you could help me in following.. > > I have written a simple matlab code for converting sampling rate from 8KHz > to 16KHz. Now I have to measure it's SNR. For this I converted both the > signals to frequency domain (taking their FFTs) and then computed > signal-to-noise ratio (sum of squared input spectral samples devided by > sum of squared difference between the output spectral samples and the > input spectral samples). With this method I am getting SNR not more than > 50-60dB (even for very high filter lengths). Can you please tell me what's > wrong with my method (I have seen posting mentioning that SNR should go as > high as 140dB)? Or please suggest correct method. > > Thank you in advance. > > Govind > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
I outline a slightly different method in some slides here: http://www.mega-nerd.com/tmp/secret_rabbit_code.pdf This method works pretty well. I use it in the test suite for Secret Rabbit COde: http://www.mega-nerd.com/SRC/ Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ "Python addresses true pseudocode's two major failings: that it isn't standardized, and it isn't executable." - Grant R. Griffin in comp.dsp
Thanks for the reply,
I have tried with upto 1000 number of LPF filter taps. I really would like
to try out method you've suggested. But is it possible that the code will
give different SNR for different frequencies. If yes, then how do I
represent total SNR of the system.
Govind
>in article urKdnY7SWfelqaneRVn-gw@giganews.com, Govind at >govind_s@conceptemsys.com wrote on 09/23/2005 12:58: > >> I have written a simple matlab code for converting sampling rate from
8KHz
the
>> signals to frequency domain (taking their FFTs) and then computed >> signal-to-noise ratio (sum of squared input spectral samples devided
by
>> sum of squared difference between the output spectral samples and the >> input spectral samples). With this method I am getting SNR not more
than
what's
>> wrong with my method > >not a particular good method to compute SNR. try upsampling a collection
of
waves
timing
>lined up because your SRC will have some delay. then subtract to get a >difference (or error or "noise) signal and use that in your SNR
computation.
> >> (I have seen posting mentioning that SNR should go as high as 140dB)? > >how long is your impulse response of your LPF? to get 140, you will
need
>about a 64 tap FIR. > > >-- > >r b-j rbj@audioimagination.com > >"Imagination is more important than knowledge." > > >
This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Thanks to all for your kind replies.
I have one more query. How much should the transition bandwidth of LPF be
for say 8KHz<=>16KHz and 8KHz<=>44.1KHz? I was suggested to keep the
passband cut off at 3.5KHz, because of speech bandwidth (20Hz to 3.4KHz).
But I doubt it would give me good result, since I want to use the SRC for
Audio and not only for Speech.
Govind
>Govind wrote: >> >> Hi All, >> >> I would appreciate if you could help me in following.. >> >> I have written a simple matlab code for converting sampling rate from
8KHz
the
by
than
what's
as
>> high as 140dB)? Or please suggest correct method. > >I outline a slightly different method in some slides here: > > http://www.mega-nerd.com/tmp/secret_rabbit_code.pdf > >This method works pretty well. I use it in the test suite for Secret >Rabbit COde: > > http://www.mega-nerd.com/SRC/ > >Erik >-- >+-----------------------------------------------------------+ > Erik de Castro Lopo >+-----------------------------------------------------------+ >"Python addresses true pseudocode's two major failings: that it >isn't standardized, and it isn't executable." >- Grant R. Griffin in comp.dsp >
>>>>> "Govind" == Govind <govind_s@conceptemsys.com> writes:
Govind> Hi All, Govind> I would appreciate if you could help me in following.. Govind> I have written a simple matlab code for converting sampling rate from 8KHz Govind> to 16KHz. Now I have to measure it's SNR. For this I converted both the Govind> signals to frequency domain (taking their FFTs) and then computed Govind> signal-to-noise ratio (sum of squared input spectral samples devided by Govind> sum of squared difference between the output spectral samples and the Govind> input spectral samples). With this method I am getting SNR not more than Govind> 50-60dB (even for very high filter lengths). Can you please tell me what's Govind> wrong with my method (I have seen posting mentioning that SNR should go as Govind> high as 140dB)? Or please suggest correct method. Single precision float round-off error? Ray
Yes, I would imagine that the result will be different for different input
frequencies.  Your low pass filter probably has some "stop band ripple" such
that certain frequencies are attenuated more than others.  Usually, FIR low pass
filters have nulls of essentially infinite attenuation (see for example the
graphs here http://www.filter-solutions.com/FIR.html for an idea of what I'm
talking about).  If you happen to pick an input frequency that lands on a null,
you will have much better results than otherwise.
So then, how to specify SNR?  Either pick several frequencies and give the
results for each, average them, or pick the worst case value.  If you plot your
LPF's frequency response, you should be able to figure out the worst case.
Due to these very issues, I recommended using the LPF's frequency response to
evaluate the "quality" of your interpolation scheme (stop-band attenuation is
the main parameter), rather than SNR computed as an error signal.  The hardware
sample rate conversion chips usually use stop-band attenuation and pass-band
frequency as figures of merit.
Jon Harris
news:W6mdnZmdof3RFareRVn-gA@giganews.com...
> Thanks for the reply, > > I have tried with upto 1000 number of LPF filter taps. I really would like > to try out method you've suggested. But is it possible that the code will > give different SNR for different frequencies. If yes, then how do I > represent total SNR of the system. > > Govind > > >>in article urKdnY7SWfelqaneRVn-gw@giganews.com, Govind at >>govind_s@conceptemsys.com wrote on 09/23/2005 12:58: >> >>> I have written a simple matlab code for converting sampling rate from > 8KHz >>> to 16KHz. Now I have to measure it's SNR. For this I converted both > the >>> signals to frequency domain (taking their FFTs) and then computed >>> signal-to-noise ratio (sum of squared input spectral samples devided > by >>> sum of squared difference between the output spectral samples and the >>> input spectral samples). With this method I am getting SNR not more > than >>> 50-60dB (even for very high filter lengths). Can you please tell me > what's >>> wrong with my method >> >>not a particular good method to compute SNR. try upsampling a collection > of >>known sine waves from 8 to 16kHz. then generate the exact same sine > waves >>(from the same math) but at the 16 kHz rate. make sure you have your > timing >>lined up because your SRC will have some delay. then subtract to get a >>difference (or error or "noise) signal and use that in your SNR > computation. >> >>> (I have seen posting mentioning that SNR should go as high as 140dB)? >> >>how long is your impulse response of your LPF? to get 140, you will > need >>about a 64 tap FIR. >> >> >>-- >> >>r b-j rbj@audioimagination.com >> >>"Imagination is more important than knowledge." >> >> >> > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
This is a fundamental trade-off that you must decide for yourself.  For the same
filter length, the wider the transition band (and hence narrower the transition
band), the less stop-band attenuation you will achieve.  You need to decide
which is more important.  Of course, if you can make your filter arbitrarily
long, you may be able to achieve both goals.  The ideal in for example
8->44.1kHz you be a 4kHz bandwidth and infinite attenuation above 4kHz.  Of
course, this is not practically achievable.
Also, who told you that the "speech bandwidth" is 20Hz to 3.4kHz?  Sometimes the
upper limit of telephone audio is specified at 3.4 kHz (or 3.3 or 3 or 3.5...),
but if you have ever talked on the phone, you know that you lose a whole lot of
high frequencies.  It is easy (for me) to hear the difference in speech even
when filtering out frequencies above 8 kHz.
Jon Harris
news:Lp-dndrU7fmuEarenZ2dnUVZ_tOdnZ2d@giganews.com...
> Thanks to all for your kind replies. > > I have one more query. How much should the transition bandwidth of LPF be > for say 8KHz<=>16KHz and 8KHz<=>44.1KHz? I was suggested to keep the > passband cut off at 3.5KHz, because of speech bandwidth (20Hz to 3.4KHz). > But I doubt it would give me good result, since I want to use the SRC for > Audio and not only for Speech. > > Govind > > >>Govind wrote: >>> >>> Hi All, >>> >>> I would appreciate if you could help me in following.. >>> >>> I have written a simple matlab code for converting sampling rate from > 8KHz >>> to 16KHz. Now I have to measure it's SNR. For this I converted both > the >>> signals to frequency domain (taking their FFTs) and then computed >>> signal-to-noise ratio (sum of squared input spectral samples devided > by >>> sum of squared difference between the output spectral samples and the >>> input spectral samples). With this method I am getting SNR not more > than >>> 50-60dB (even for very high filter lengths). Can you please tell me > what's >>> wrong with my method (I have seen posting mentioning that SNR should go > as >>> high as 140dB)? Or please suggest correct method. >> >>I outline a slightly different method in some slides here: >> >> http://www.mega-nerd.com/tmp/secret_rabbit_code.pdf >> >>This method works pretty well. I use it in the test suite for Secret >>Rabbit COde: >> >> http://www.mega-nerd.com/SRC/ >> >>Erik >>-- >>+-----------------------------------------------------------+ >> Erik de Castro Lopo >>+-----------------------------------------------------------+ >>"Python addresses true pseudocode's two major failings: that it >>isn't standardized, and it isn't executable." >>- Grant R. Griffin in comp.dsp >> > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Hi r b-j,
I am trying to compute SNR with the method you've suggested. This time I
am trying upconversion of a signal from 8KHz to 44.1KHz. I have
implemented a four stage SRC code in matlab (with ratios 3/2, 3/2, 7/5 and
7/4 with filter taps 414, 54, 84 and 70 respectively using remez
algorithm). I multiply the output by a factor of 441 (3*3*7*7) in time
domain to compensate for interpolation stage losses. The frequency
response seems to be good. But still I am getting SNR not more than 30-40
DB. I am sure that I am not making a mistake in taking the delay into
account.
Ray had suggested to check 'Single precision float round-off error'. But I
am using simple matlab floating point variables, which are by default
double-precision. (Ray, please correct me if I am failing to understand
your point.)
Please help me out, I am very eager to see 100+DB SNR!
Thank you
Govind
8KHz
the
by
than
what's
of
waves
timing
computation.
need
