31 bit pseudo-random number gen in C, C++ & dsPIC assembly code
Started by Robin Whittle ●September 27, 2005
Carlos Moreno wrote:
> Bevan Weiss wrote: >> onyx49@juno.com wrote: >> >>> Are there measures of "randomness" or should I say "non-randomness"? >>> Or do people just hold there noses and say >>> "Ewww, this is a pseudo raandom number"? >>> >>> Dave >> >> >> The autocorrelation in this case would be it... >> If you perform the autocorrelation over a sufficient length of output >> from the PRNG then you would note that it has several spikes at the >> cyclic length of the PRNG (ie the length it starts to repeat at). >> This shows that it's not truly random. > > Is this the only defect that one usually finds in actual PRNGs?? > I'm surprised; I would have expected that the non-top-quality > PRNGs would exhibit some noticeable correlation between nearby > samples... Am I overestimating the complexity of the problem? > > Carlos > --
This will show in the autocorrelation as less initial fall off. The autocorrelation applies over a large number of outputs, and so won't show any detail concerning whether two or more adjacent samples were the same. However it will show if an excessive number are similar, as the floor from the autocorrelation will increase. You've got to think in terms of actual noise here. It's not totally uncommon to have the same measure of noise for two adjacent measurements. This doesn't give you any more information about what the next measurement will be however -- comp.lang.c.moderated - moderation address: clcm@plethora.net -- you must have an appropriate newsgroups line in your header for your mail to be seen, or the newsgroup name in square brackets in the subject line. Sorry.
Bevan Weiss wrote:
> onyx49@juno.com wrote: > > Are there measures of "randomness" or should I say "non-randomness"? > > Or do people just hold there noses and say > > "Ewww, this is a pseudo raandom number"? > > > > Dave > > The autocorrelation in this case would be it...
I think this raises a question: Assume we wanted to test whether the sequence {3, 1, 4, 1, 5, 9, 2, 6, ....} is uniformly and independently distributed (on the digits {0,1,...,9}). What are histograms (or any other statistical measures) and correlation tests going to tell us about this sequence? And what does this tell us about how well suited histograms and correlation tests are for measuring "randomness"? While we are at it, what exactly _is_ randomness? When trying to answer that last question, remember that _every_ sequence of digits has equal probability of having been emitted by a uniform iid source. If that is the case, how can we ever test whether any given sequence is indeed a realization of an iid uniform random process, or whether in fact it is a comletely deterministic sequence (as are generated by PRNGs, or as the one above)? And finally, even if we found a deterministic algorithm for generating any particular sequence under test, could we be sure that the sequence was in fact not a realization of a random process? After all, it has equal probability of appearance as any other sequence for which no deterministic generating algorithm exists (for example, the decimal digit sequence of an uncomputable number). -- comp.lang.c.moderated - moderation address: clcm@plethora.net -- you must have an appropriate newsgroups line in your header for your mail to be seen, or the newsgroup name in square brackets in the subject line. Sorry.
I wrote:
> And finally, even if we found a deterministic algorithm > for generating any particular sequence under test, could we be sure > that the sequence was in fact not a realization of a random process? > After all, it has equal probability of appearance as any other sequence > for which no deterministic generating algorithm exists (for example, > the decimal digit sequence of an uncomputable number).
Oddly, I wrote this post about a week ago, and only now has Google Groups passed it on. Anycase, about that last statement: while it is true that any sequence has equal probability under a iid uniform random process, the probability of there existing a deterministic algorithm which computes that sequence is, in fact, zero. This is because there are only countably infinity many computable numbers (or equivalently, computable digit sequences), but uncountably many uncomputable numbers. So if a deterministic rule were found, we could be _almost_ sure that the sequence was not random (we can't be completely sure, because the computable sequences might have zero probability, but that set is definitely not empty). So to answer my own question, a "randomness" test can only return an answer which is correct with probability one when it returns a negative, ie. when a deterministic rule for computing a given sequence is found. If no such rule is found, we can't really be sure. Regards, Andor
abariska@student.ethz.ch wrote:
> Assume we wanted to test whether the sequence {3, 1, 4, 1, 5, 9, 2, 6, > ....} is uniformly and independently distributed (on the digits > {0,1,...,9}). What are histograms (or any other statistical measures) > and correlation tests going to tell us about this sequence? And what > does this tell us about how well suited histograms and correlation > tests are for measuring "randomness"?
Last I heard, the digits of pi are not individually distributed significantly differently from uniform, according to the standard statistical tests.
There are several reasonable definitions, the main two families of which are (a) unpredictability and (b) compressibility. Chaitin's web site has leads to approach (b). Obviously the digits of pi are not very "random" according to view (b).
> ... how can we ever test whether any given sequence is indeed a > realization of an iid uniform random process, ...
That's not the right hypothesis to be testing. Theories of randomness is discussed in many works, including Knuth's AOCP (which should be in your technical library if not on your desktop). There is a net newsgroup sci.crypt.random-numbers where this discussion would be more appropriate. -- comp.lang.c.moderated - moderation address: clcm@plethora.net -- you must have an appropriate newsgroups line in your header for your mail to be seen, or the newsgroup name in square brackets in the subject line. Sorry.
Douglas A. Gwyn wrote:
> abariska@student.ethz.ch wrote: > > Assume we wanted to test whether the sequence {3, 1, 4, 1, 5, 9, 2, 6, > > ....} is uniformly and independently distributed (on the digits > > {0,1,...,9}). What are histograms (or any other statistical measures) > > and correlation tests going to tell us about this sequence? And what > > does this tell us about how well suited histograms and correlation > > tests are for measuring "randomness"? > > Last I heard, the digits of pi are not individually distributed > significantly differently from uniform, according to the standard > statistical tests.
That's why I started with this example: it is a computable sequence (ie. not random at all) which should pass the "standard statistical tests" for a iid uniform distributed random sequence (if you found a test which disproves this, you have a counter-example to the normality conjecture of pi).
> > While we are at it, what exactly _is_ randomness? > > There are several reasonable definitions, the main two families > of which are (a) unpredictability and (b) compressibility. > Chaitin's web site has leads to approach (b). Obviously the > digits of pi are not very "random" according to view (b).
And also in view (a)!
> > ... how can we ever test whether any given sequence is indeed a > > realization of an iid uniform random process, ... > > That's not the right hypothesis to be testing. > > Theories of randomness is discussed in many works, including > Knuth's AOCP (which should be in your technical library if not > on your desktop). > > There is a net newsgroup sci.crypt.random-numbers where this > discussion would be more appropriate.
I didn't have any cryptographic application in mind, rather a much more basic setup: Assume you are given a sequence of digits (ie. you can have any arbitrary but finite number of digits from that sequence). You know that the sequence was produced by either i) a uniform iid random digit generator or ii) a deterministic Turing machine. The random sequence decision question: does there exist a Turing machine that, given as input the finite segment of the sequence, can correctly determine the source (i or ii) with a probability of 1-delta, for any given delta > 0? (Much like the probabilistic prime number tests, except now for random and pseudo-random sequences.) The concept of a Turing machine is more general than a statistical test, as any statistical test can be computed by a Turing machine. So I'm not asking if there exists a statistical procedure to answer the decision question. Instead, I'm wondering if the answer to the random sequence decision quesion is at all decidable. I tried to answer part of that question in a follow up (to comp.dsp only), about a week ago. If the Turing machine somehow came up with a procdure to compute the given segment of the digit sequence, it could generate new digits and compare the new digits with digits from the sequence (remember, we are allowed as many digits from the sequence as we wish). With each matching digit, the probabiliy that the sequence is not computable with the found procedure goes down by an order of magnitude until it falls below delta. At this point, we have shown that the sequence was generated by a Turing machine with probability 1-delta (because an iid uniform digit generator issues a non-computable digit sequence with probability 1). Unfortunately, for this to work, one would have to go through all countably infinite many possible procedures to compute digit sequences. While waiting for the TM to halt, one never knows if the TM was still searching for a procedure, or if no such procedure existed. This approach doesn't work. Perhaps some other method exists to answer the decision question? Not having Knuth's books, I don't know if this topic is discussed there - it seems, Knuth would rather be interested in what is computable, and I have the feeling that the random sequence decision question is uncomputable. Regards, Andor -- comp.lang.c.moderated - moderation address: clcm@plethora.net -- you must have an appropriate newsgroups line in your header for your mail to be seen, or the newsgroup name in square brackets in the subject line. Sorry.
It seems that the long time for these posts to show up is due to the
moderating in "comp.lang.c.moderated", so I'm taking this cross-post
out.
> The random sequence decision question: does there exist a Turing > machine that, given as input the finite segment of the sequence, can > correctly determine the source (i or ii) with a probability of 1-delta, > for any given delta > 0?
The above should have read "given as input the (infinite) sequence, ..." because I don't want to limit the Turing machine in its access to the sequence. Anycase, it seems that there is no such Turing machine. Idea of proof: Assume there was, then you could feed it the input of a iid random digit generator. After the Turing machine has accessed a finite segment of the sequence (as it must if it is to decide the question in a finite number of steps), it reaches the conclusion that the sequence is from the random digit generator. If not (this happens with probability delta), I simply run the test again until it answers correctly. With probability 1 I only have to repeat the procedure a finite number of times. While it accessed the sequence, I jotted down every digit from the sequence that it read. So I have all finite digits which the Turing machine required to decide the question. Next, I simply construct another Turing machine that reads out the tabulated digits. Because the deciding Turing machine is deterministic, when faced with the output of the table-reading Turing machine, it will again reach the conclusion that the sequnce was from the random digit generator (and it won't require more than the tabulated digits for this decision ). So, if there was a Turing machine that could determine the correct answer with probabiliy 1-delta for any delta > 0, I could construct another Turing machine that resulted in a probability of error = 1, which is a contradiction. Therefore no such deciding Turing machine can exist. Regards, Andor
