Hi I have a question about LPC-analysis. I have a frame of 256 speech samples which I assume is the output of an IIR-filter and I do LPC-analysis of the frame to obtain the coefficients of the IIR-filter. I want to do a comparison of the non-parametric power spectrum (by use of FFT) and the model-based power spectrum to see how well they fit, but I am not sure if I have done it right. So I am hoping that there are some experts out there who could check out my code for possible errors and tell me whether or not I have done it correctly? Here is the code: clc close all clear % load speech [x,Fs]=wavread('1_s'); x=x'; % take a speech segment N=1000; x=x(1,5000+N:5255+N); % do LPC-analysis [a,e]=lpc(x,10); a=real(a); % find non-parametric power spectrum Sxx=abs(fft(x)).^2; Sxx=Sxx./256; % find model-based power spectrum for f=0:255 z=exp(-j*2*pi*f/256); num=e; den=256*abs(a(1)+a(2)*z^-1+a(3)*z^-2+a(4)*z^-3+a(5)*z^-4+a(6)*z^-5+a(7)*z^-6+a(8)*z^-7+a(9)*z^-8+a(10)*z^-9+a(11)*z^-10).^2; u(f+1)=num/den; end % plot results plot(u) hold plot(Sxx,'r--') hold Thanks in advance :o)
Question: linear predictive coding, spectral estimation
Started by ●September 28, 2005
Reply by ●September 28, 20052005-09-28
Lars Hansen wrote:> Hi > > I have a question about LPC-analysis. > > I have a frame of 256 speech samples which I assume is the output of an > IIR-filter and I do LPC-analysis of the frame to obtain the coefficients of > the IIR-filter. > > I want to do a comparison of the non-parametric power spectrum (by use of > FFT) and the model-based power spectrum to see how well they fit, but I am > not sure if I have done it right. > > So I am hoping that there are some experts out there who could check out my > code for possible errors and tell me whether or not I have done it > correctly? > > Here is the code:[-- code snipped --] It is not up to me to say whether what you have done it correct or not, but plotting the spectra can be done very easily. Assume you have the data vector x and filter coefficient vectors a and b available. What you do, then, is this: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% N = length(x); X = fft(x,N); A = fft(a,N); B = fft(b,N); H = B./A; fv= [0:N-1]/N*fs; plot(fv,abs(X),'b',fv,abs(H),'r') %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% and that should be it, except for some normalization factor. Rune
Thanks, but the thing I was interested in is how the lpc-based power spectrum should be calculated so it is comparable with the non-parametric power spectrum (that is: so the lpc-based power spectrum is a smooth approximation of the non-parametric power spectrum) -- preferably without use of matlab-functions so I can see what's going on :o)
Lars Hansen wrote:> Thanks, but the thing I was interested in is how the lpc-based power > spectrum should be calculated so it is comparable with the non-parametric > power spectrum (that is: so the lpc-based power spectrum is a smooth > approximation of the non-parametric power spectrum) -- preferably without > use of matlab-functions so I can see what's going on :o)Isn't that what I showed? I only used the FFT, which hardly is matlab-specific. The one remaining problem is a normalization factor that could be computed from the signal energy. Rune
