Hello All, Can anyone please help me in writing a C code for dividing a 32 bit fixed point number by another 32 bit number? I already have a code which works fine for 16 bit (div_s) but it can not be converted to 32 bit. So please give me some source code or algorithm for implementing 32 bit division. Thanks and Regards, bd. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
32 bit fixed point division
Started by ●September 28, 2005
Reply by ●September 28, 20052005-09-28
#include <stdint.h>
uint64_t Divide32(uint32_t y, uint32_t x)
uint16_t n;
uint64_t answer;
uint64_t remainder;
uint64_t divisor;
answer = 0;
remainder = x;
divisor = (uint64_t)y << 32;
for (n = 0; n < 32; n++)
divisor = divisor >> 1;
if (remainder >= divisor)
remainder -= divisor;
answer |= (uint64_t)1 << (63 - n);
remainder = remainder << 1;
answer |= (uint64_t)1 << (31 - n);
return answer;
bsdap wrote:> Can anyone please help me in writing a C code for dividing a 32 bit fixed > point number by another 32 bit number? I already have a code which works > fine for 16 bit (div_s) but it can not be converted to 32 bit. > So please give me some source code or algorithm for implementing 32 bit > division.Is performance or accuracy important? And if the former and you do not need an exact result, does your target processor have a fast multiply? -- rhn
Reply by ●September 29, 20052005-09-29
>bsdap wrote: >> Can anyone please help me in writing a C code for dividing a 32 bitfixed>> point number by another 32 bit number? I already have a code whichworks>> fine for 16 bit (div_s) but it can not be converted to 32 bit. >> So please give me some source code or algorithm for implementing 32bit>> division. > >Is performance or accuracy important? And if the former and you do >not need an exact result, does your target processor have a fast >multiply? > > >-- >rhn > >Thanks for your reply, I am intending to make this routine platform independent. And, yes,the accuracy is most important for me. Can you please suggest me some idea for this? Thank you once again, Regards, bd This message was sent using the Comp.DSP web interface on www.DSPRelated.com
>#include <stdint.h> > >uint64_t Divide32(uint32_t y, uint32_t x) >{ > uint16_t n; > uint64_t answer; > uint64_t remainder; > uint64_t divisor; > > answer = 0; > remainder = x; > divisor = (uint64_t)y << 32; > > for (n = 0; n < 32; n++) > { > divisor = divisor >> 1; > if (remainder >= divisor) > { > remainder -= divisor; > answer |= (uint64_t)1 << (63 - n); > } > } > > for (n = 0; n < 32; n++) > { > remainder = remainder << 1; > if (remainder >= divisor) > { > remainder -= divisor; > answer |= (uint64_t)1 << (31 - n); > } > } > > return answer; >} > >Hi Randy, Thank you very much for this wonderful code. It minimised my problem to a great extent. Thanks again, Regards bd. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Regarding the posted code was it originally written for the ARM? It looks familiar. Plus: does anybody knows any portable for fixed-point arithmetic with functions like sin,cos, sqrt, pow etc. I have collected a few codes from here and there but i prefer something moe adequate. -kavi
Reply by ●September 30, 20052005-09-30
>>#include <stdint.h> >> >>uint64_t Divide32(uint32_t y, uint32_t x) >>{ >> uint16_t n; >> uint64_t answer; >> uint64_t remainder; >> uint64_t divisor; >> >> answer = 0; >> remainder = x; >> divisor = (uint64_t)y << 32; >> >> for (n = 0; n < 32; n++) >> { >> divisor = divisor >> 1; >> if (remainder >= divisor) >> { >> remainder -= divisor; >> answer |= (uint64_t)1 << (63 - n); >> } >> } >> >> for (n = 0; n < 32; n++) >> { >> remainder = remainder << 1; >> if (remainder >= divisor) >> { >> remainder -= divisor; >> answer |= (uint64_t)1 << (31 - n); >> } >> } >> >> return answer; >>} >> >> > >Hi Randy, >Thank you very much for this wonderful code. It minimised my problem toa>great extent. > >Thanks again, > >Regards >bd. > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >Hay, can anyone please give a code for 32 bit fixed point division which would work for a 32 bit DSP processor. It looks like this code will not work, as it involves working with a 64 bit integer. Thanks and Regards, SB. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
sbhavikb wrote:> >> uint64_t remainder;...> >> remainder = remainder << 1;...> Hay, can anyone please give a code for 32 bit fixed point division which > would work for a 32 bit DSP processor. It looks like this code will not > work, as it involves working with a 64 bit integer.These operations on large unsigned integers can be broken down into operations on sets of smaller integers. For instance, a left shift on a uint64 can be broken down into shifting two 32-bit integers, plus copying the former MSB of one into the resulting LSB of the other. See any textbook on binary arithmetic or multi-precision arithmetic. So the earlier posted code will work just fine, with simple modifications, not only for 32-bit processors, but for 16-bit and 8-bit CPU's as well. And if you want a potentially faster multi-precision integer division routine, look into non-restoring algorithms, which can save on some comparison cycles. IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
"rhnlogic@yahoo.com" <rhnlogic@yahoo.com> writes:> [...] > So the earlier posted code will work just fine, with simple > modifications, not only for 32-bit processors, but for 16-bit and > 8-bit CPU's as well.Why not perfectly as is? In other words, what portability issues do you see? It seems that as long as we are talking ISO 99 C so that the stdint library is available, we have everything we need. -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> "rhnlogic@yahoo.com" <rhnlogic@yahoo.com> writes: > > [...] > > So the earlier posted code will work just fine, with simple > > modifications, not only for 32-bit processors, but for 16-bit and > > 8-bit CPU's as well. > > Why not perfectly as is? In other words, what portability issues > do you see? It seems that as long as we are talking ISO 99 C so > that the stdint library is available, we have everything we need.Guess my age is showing. I worked too many years on systems where one could not assume that either the system or the compiler and its libraries would transparently support 64-bit operations. In fact, in my junior engineer days, I remember having to develop library support code for certain *16-bit* arithmetic operations (maybe for Z80's and/or 6502's). Maybe the OP is working on an antique DSP? (More likely, they just didn't check the C compiler manual...) IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
