Hi all, I would like to design a digital modulator using, say, M-QAM. For speed and simplicity, I am planning on using an FPGA development board that includes 160MSPS DACs. To avoid using extra hardware and interfacing to other boards, I would like to generate a digital carrier in the FPGA, then convert it to analog using the on-board DACs. My question is a general one: How many samples per carrier cycle are required in order to get a good analog (sinusoidal) signal at the output of my DAC? Since I can only process the digital data at 160MSPS with my DAC, I would be limited to a carrier frequency of 160/n MHz, where n=camples per carrier cycle (and hence I would like to know how to choose n!). Thanks in advance.
DAC requirement for carrier generation
Started by ●September 28, 2005
Reply by ●September 29, 20052005-09-29
Snowball <sdris@softlab.ntua.gr> wrote:> I would like to design a digital modulator using, say, > M-QAM. For speed and simplicity, I am planning on using an FPGA > development board that includes 160MSPS DACs. To avoid using > extra hardware and interfacing to other boards, I would like > to generate a digital carrier in the FPGA, then convert it to > analog using the on-board DACs.> My question is a general one: How many samples per carrier > cycle are required in order to get a good analog (sinusoidal) > signal at the output of my DAC? Since I can only process the > digital data at 160MSPS with my DAC, I would be limited to > a carrier frequency of 160/n MHz, where n=camples per carrier > cycle (and hence I would like to know how to choose n!).The answer is "it depends", and the only way to determing this is simulation or implementation, but I've seen n as low as four work. You will of course need a reconstruction filter after the DAC. Incidentally, this problem comes up in what is known as a "low IF" system. Steve
"Snowball" <sdris@softlab.ntua.gr> wrote in message news:dhef1f$r2t$1@sunnews.cern.ch...> Hi all, > > I would like to design a digital modulator using, say, M-QAM. For speed > and > simplicity, I am planning on using an FPGA development board that includes > 160MSPS DACs. To avoid using extra hardware and interfacing to other > boards, > I would like to generate a digital carrier in the FPGA, then convert it to > analog using the on-board DACs. > > My question is a general one: How many samples per carrier cycle are > required in order to get a good analog (sinusoidal) signal at the output > of > my DAC? Since I can only process the digital data at 160MSPS with my DAC, > I > would be limited to a carrier frequency of 160/n MHz, where n=camples per > carrier cycle (and hence I would like to know how to choose n!). > > Thanks in advance. > > >Sampling Frequency needs to be greater then the 2 * the highest frequency you are generating. so for 160MSPS, the a sinusoidal would need to be < 80MHz. if you have a modulated carrier there with a bandwidth of say 2 MHZ, then your fc would need to be < 79MHz so that the highest frequency is < 80MHz. (fc + bw/2) < fs/2 fc = center frequency bw = bandwidth fs = sampling frequency cheers, Paul Solomon
Paul Solomon <psolomon@tpg.com.au> wrote:>Sampling Frequency needs to be greater then the 2 * the highest frequency >you are generating. > >so for 160MSPS, the a sinusoidal would need to be < 80MHz. > >if you have a modulated carrier there with a bandwidth of say 2 MHZ, then >your fc would need to be < 79MHz so that the highest frequency is < 80MHz. >(fc + bw/2) < fs/2 > >fc = center frequency >bw = bandwidth >fs = sampling frequency >Great theoretical answer. But you'd have real trouble isolating such a 79 MHz signal from its alias at 81 MHz. The real question is, could you get by at Fs/3 for the center frequency? Or must it be lower still? Steve
Steve Pope wrote:>Paul Solomon <psolomon@tpg.com.au> wrote: > > > >>Sampling Frequency needs to be greater then the 2 * the highest frequency >>you are generating. >> >>so for 160MSPS, the a sinusoidal would need to be < 80MHz. >> >>if you have a modulated carrier there with a bandwidth of say 2 MHZ, then >>your fc would need to be < 79MHz so that the highest frequency is < 80MHz. >>(fc + bw/2) < fs/2 >> >>fc = center frequency >>bw = bandwidth >>fs = sampling frequency >> >> >> > >Great theoretical answer. But you'd have real trouble isolating >such a 79 MHz signal from its alias at 81 MHz. > >The real question is, could you get by at Fs/3 for the center >frequency? Or must it be lower still? > >Steve > >I'm not sure it even makes theoretical sense, considering the sinc rolloff that close to the end of the band (or do theoretician's DACs output dirac pulses :-) ). Fs/3 can be workable, but a lot depends on the spur performance of the DAC, and a hundred other messy details. Regards, Steve
Steve Underwood <steveu@dis.org> wrote:>Steve Pope wrote:>>The real question is, could you get by at Fs/3 for the center >>frequency? Or must it be lower still?>I'm not sure it even makes theoretical sense, considering the sinc >rolloff that close to the end of the band (or do theoretician's DACs >output dirac pulses :-) ).The sinc rolloff is only 3 dB at Fs/2 so it's not a deal-killer.>Fs/3 can be workable, but a lot depends on the spur performance of the >DAC, and a hundred other messy details.Yep. S.
Steve Pope skrev:> Steve Underwood <steveu@dis.org> wrote: > > >Steve Pope wrote: > > >>The real question is, could you get by at Fs/3 for the center > >>frequency? Or must it be lower still? > > >I'm not sure it even makes theoretical sense, considering the sinc > >rolloff that close to the end of the band (or do theoretician's DACs > >output dirac pulses :-) ). > > The sinc rolloff is only 3 dB at Fs/2 so it's not a deal-killer. > > >Fs/3 can be workable, but a lot depends on the spur performance of the > >DAC, and a hundred other messy details. > > Yep. > > S.Analog devices has an app-note on doing an FM transmitter using a dsp and a 125MHz DDS, its' programmed for something like 30MHz so that with the 125MHz Fs the first alias lands and 95MHz i.e. in the normal FM band -Lasse
