Hello Forum, With reference to FM Gardners article "Interpolation In Digital Modems---PART1: Fundamentals", I have a query regarding the term JITTER. Under the heading "Interpolation Jitter" the author states that " Athough the kth interpolation is computed FOR a time kTi=(mk+uk)Ts, the interpolant is actually delivered coincident with a clock tick no earlier than (mk+1)Ts. Therefore the output exhibits a timing jitter with peak to peak fluctuations of Ts....." Those of you familiar with Gardners Interpolation based Timing Recovery, would quickly remember that the input signal is sampled at Ts while interpolator output is at Ti. There are other units like TED and NCO working within the feedback loop to adjust the timing. 1)Can anybody clarify at what rate (Fs=1/Ts or Fi=1/TI) the interpolator is actually running? I mean if there were to be a hardware interpolator, which of Fs or Fi would be its master clock? 2)How do we say that there is "jitter" in output clock if it is "fixed" (Fs or Fi)? "the interpolant is actually delivered coincident with a clock tick no earlier than (mk+1)Ts" suggests me that the master clock of interpolator is Fs=1/Ts, which is obviously jitter free? Rider This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Started by ●October 3, 2005
Reply by ●October 3, 20052005-10-03
rider wrote:> Hello Forum, > > With reference to FM Gardners article "Interpolation In Digital > Modems---PART1: Fundamentals", I have a query regarding the term JITTER. > > Under the heading "Interpolation Jitter" the author states that " Athough > the kth interpolation is computed FOR a time kTi=(mk+uk)Ts, the > interpolant is actually delivered coincident with a clock tick no earlier > than (mk+1)Ts. Therefore the output exhibits a timing jitter with peak to > peak fluctuations of Ts....." > > Those of you familiar with Gardners Interpolation based Timing Recovery, > would quickly remember that the input signal is sampled at Ts while > interpolator output is at Ti. There are other units like TED and NCO > working within the feedback loop to adjust the timing. > > 1)Can anybody clarify at what rate (Fs=1/Ts or Fi=1/TI) the interpolator > is actually running? I mean if there were to be a hardware interpolator, > which of Fs or Fi would be its master clock?I think it is easiest to think of the Gardner structure as a fractional decimator with output rate set by the period of an NCO. The NCO is updated on every input sample. When it wraps, an output sample is produced. Let's say we have a 16-bit unsigned, downcounting NCO and wish to decimate by 3. Then on each input sample we subtract 65536/3 from the NCO. So a typical series of NCO values would look like: 0 43691 --> interpolate an output sample 21845 0 43691 --> interpolate an output sample 21845 0 43691 --> interpolate an output sample So you see that the interpolator executes at the *output* rate on average.> > 2)How do we say that there is "jitter" in output clock if it is "fixed" > (Fs or Fi)? "the interpolant is actually delivered coincident with a clock > tick no earlier than (mk+1)Ts" suggests me that the master clock of > interpolator is Fs=1/Ts, which is obviously jitter free?This is just a manifestation of the fact that you only interpolate an output on input clock edges. On average, the number of output samples/sec is correct, but they are "bursty" in that they are not produced at a constant rate. If you stuck all of the output samples in a FIFO, then clocked them out using an output clock that ultimately controls the decimation rate (NCO period) via a feedback loop, then that output clock will jitter with respect to the input clock by Ts. John
