Hi, i am Sreenivas, i want to clarify from you, "Can the the symbol timing recovery be acheived by using interpolation filter method or not ?". Actuall i am working at 32MHz sampling rate, can i apply this method at this rate for symbol timing recovery or not. It is mentioned in "Interpolation in Digital Modems-Part-1 : Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it "interpolation is not and appropriate technique to be applied to wideband signals". if it is not suitable, why it is not suitable? and suggest what are other methods will give better results. if it is suitable, kindly suggest me some book or links where i can get good description of how to implement it in fpgas. Thankyou for your time and valuable suggestions in advance. Regards, Sreenivas
symbol timing recovery using interpolation filter method:suggestion
Started by ●October 4, 2005
Reply by ●October 4, 20052005-10-04
<asnivas223@gmail.com> wrote in message news:1128432149.209707.305820@f14g2000cwb.googlegroups.com...> Hi, > i am Sreenivas, i want to clarify from you, "Can the the symbol > timing recovery be acheived by using interpolation filter method or not > ?". Actuall i am working at 32MHz sampling rate, can i apply this > method at this rate for symbol timing recovery or not. > It is mentioned in "Interpolation in Digital Modems-Part-1 : > Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it > "interpolation is not and appropriate technique to be applied to > wideband signals". > if it is not suitable, why it is not suitable? and suggest what are > other methods will give better results. > if it is suitable, kindly suggest me some book or links where i can get > good description of how to implement it in fpgas. > > Thankyou for your time and valuable suggestions in advance. > > Regards, > SreenivasWhat kind of modulation are you trying to recover the symbol timing for? Your sample rate isn't as relevant as the bandwidth of the signal you are receiving. Cheers Bhaskar
asnivas223@gmail.com wrote:> It is mentioned in "Interpolation in Digital Modems-Part-1 : > Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it > "interpolation is not and appropriate technique to be applied to > wideband signals". > if it is not suitable, why it is not suitable?What do you mean by "wideband" in relation to your sampling rate? Sinc reconstruction methods of interpolation are usually only useful with signals that are band-limited before sampling. IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
rhnlogic@yahoo.com wrote:> asnivas223@gmail.com wrote: > >>It is mentioned in "Interpolation in Digital Modems-Part-1 : >>Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it >>"interpolation is not and appropriate technique to be applied to >>wideband signals". >>if it is not suitable, why it is not suitable? > > > What do you mean by "wideband" in relation to your sampling > rate? > > Sinc reconstruction methods of interpolation are usually only > useful with signals that are band-limited before sampling.Sampled signals are usually useful only if they were band limited before the sampling -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> rhnlogic@yahoo.com wrote: > > Sinc reconstruction methods of interpolation are usually only > > useful with signals that are band-limited before sampling. > > Sampled signals are usually useful only if they were band limited before > the samplingThis is a stronger statement than I'd be willing to make with respect to artificial modulation schemes. Consider cases with very redundant data encodings and using statistical data recovery. One might be able to get useful information out of a severely undersampled signal. But you wouldn't be able to reconstruct that signal. IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
rhnlogic@yahoo.com wrote:> Jerry Avins wrote: > >>rhnlogic@yahoo.com wrote: >> >>>Sinc reconstruction methods of interpolation are usually only >>>useful with signals that are band-limited before sampling. >> >>Sampled signals are usually useful only if they were band limited before >>the sampling > > > This is a stronger statement than I'd be willing to make with respect > to artificial modulation schemes. Consider cases with very redundant > data encodings and using statistical data recovery. One might be able > to get useful information out of a severely undersampled signal. > But you wouldn't be able to reconstruct that signal. > > > IMHO. YMMV.To save face, I'd classify that as "unusual". jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
asnivas223@gmail.com wrote:> Hi, > i am Sreenivas, i want to clarify from you, "Can the the symbol > timing recovery be acheived by using interpolation filter method or not > ?". Actuall i am working at 32MHz sampling rate, can i apply this > method at this rate for symbol timing recovery or not. > It is mentioned in "Interpolation in Digital Modems-Part-1 : > Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it > "interpolation is not and appropriate technique to be applied to > wideband signals". > if it is not suitable, why it is not suitable? and suggest what are > other methods will give better results. > if it is suitable, kindly suggest me some book or links where i can get > good description of how to implement it in fpgas. > > Thankyou for your time and valuable suggestions in advance. > > Regards, > SreenivasWideband is a relative term. What matters is how many samples per baud are available to estimate the value of a signal between sampling instants using a weighted average or curve fit based on the surrounding samples. Intuitively, the signal should not change much between sampling instants in order for the estimate to be good. As a practical matter, that will be the case if at least two samples per baud are available. John
Reply by ●October 5, 20052005-10-05
john wrote:> asnivas223@gmail.com wrote: > > Hi, > > i am Sreenivas, i want to clarify from you, "Can the the symbol > > timing recovery be acheived by using interpolation filter method or not > > ?". Actuall i am working at 32MHz sampling rate, can i apply this > > method at this rate for symbol timing recovery or not. > > It is mentioned in "Interpolation in Digital Modems-Part-1 : > > Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it > > "interpolation is not and appropriate technique to be applied to > > wideband signals". > > if it is not suitable, why it is not suitable? and suggest what are > > other methods will give better results. > > if it is suitable, kindly suggest me some book or links where i can get > > good description of how to implement it in fpgas. > > > > Thankyou for your time and valuable suggestions in advance. > > > > Regards, > > Sreenivas > > Wideband is a relative term. What matters is how many samples per baud > are available to estimate the value of a signal between sampling > instants using a weighted average or curve fit based on the surrounding > samples. Intuitively, the signal should not change much between > sampling instants in order for the estimate to be good. As a practical > matter, that will be the case if at least two samples per baud are > available. > > JohnHi thank you for the reply. Actually i'm looking at Non-Data-Aided(NDA) method of timing recovery in which i'm having only the incoming data and only. My data rate is fixed at 2Mbps. I'm basically looking at the method which is not using NCO or DPLL or PLL. I'd like to do it using interpolators. ---srinivas
As you will see from the Gardner paper, the interpolation phase is determined by the NCO value after a wrap occurs. Typically the NCO frequency and phase are adjusted by filtering the output of a timing error detector (TED) through a lead-lag loop filter, creating a second order PLL. The TED is normally chosen to give an error value proportional to the timing offset when a transition occurs and zero when no transition occurs (Gardner has a paper on this too). The only thing required to lock onto the timing is a reasonable density of transitions, not a particular bit pattern. So I would say this qualifies as NDA. John
On 4 Oct 2005 21:50:39 -0700, asnivas223@gmail.com wrote:> >john wrote: >> asnivas223@gmail.com wrote: >> > Hi, >> > i am Sreenivas, i want to clarify from you, "Can the the symbol >> > timing recovery be acheived by using interpolation filter method or not >> > ?". Actuall i am working at 32MHz sampling rate, can i apply this >> > method at this rate for symbol timing recovery or not. >> > It is mentioned in "Interpolation in Digital Modems-Part-1 : >> > Fundamentals" by Floyd M.Gardner, Fellow, IEEE.-1993. that it >> > "interpolation is not and appropriate technique to be applied to >> > wideband signals". >> > if it is not suitable, why it is not suitable? and suggest what are >> > other methods will give better results. >> > if it is suitable, kindly suggest me some book or links where i can get >> > good description of how to implement it in fpgas. >> > >> > Thankyou for your time and valuable suggestions in advance. >> > >> > Regards, >> > Sreenivas >> >> Wideband is a relative term. What matters is how many samples per baud >> are available to estimate the value of a signal between sampling >> instants using a weighted average or curve fit based on the surrounding >> samples. Intuitively, the signal should not change much between >> sampling instants in order for the estimate to be good. As a practical >> matter, that will be the case if at least two samples per baud are >> available. >> >> John > >Hi thank you for the reply. Actually i'm looking at Non-Data-Aided(NDA) >method of timing recovery in which i'm having only the incoming data >and only. My data rate is fixed at 2Mbps. I'm basically looking at the >method which is not using NCO or DPLL or PLL. I'd like to do it using >interpolators. >---srinivasHow do you plan to steer the interpolators? Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
