Image data is all positive. So the FT of an image has a large DC component. But, are there other characteristic properties of an all-positive function? Similar, for example to the 'real-is-even' etc? Chris =========================== Chris Bore BORES Signal Processing www.bores.com
Characteristics of FFT of positive functions?
Started by ●October 11, 2005
Reply by ●October 11, 20052005-10-11
Chris Bore wrote:> Image data is all positive. > > So the FT of an image has a large DC component. > > But, are there other characteristic properties of an all-positive > function? Similar, for example to the 'real-is-even' etc?No, other than the general conjugate-symmetry that applies whenever you transform real data. The reason is that you can take *any* real array and make it all positive by adding a sufficiently large constant to every element of the array, and adding such a constant only affects the DC element. Cordially, Steven G. Johnson
