Hi all ! I'm trying to design a digital graphical equalizer (8 bands), which can deal with many samlping frequency... so it should be able to equalize let say either in 48k, 44.1k, 22k, 32k... in the same way. So my question is ... do I have to design an equalizer for each sampling frequency or is there a good (and memory coefficent table saving) trick ? I'm think of maybe designing the filter for 48k and then place an upsampler filter before... but it's just a draft idea ... Txxs in advance for your help ! Fred.
multi sampling frequency filtering
Started by ●October 11, 2005
Reply by ●October 11, 20052005-10-11
I have done this several times before. What you can do is to design a table which keeps different filter coefficients. When sampling rate changes you use different set of coefficients. The filters can simply be IIR bandpass type. There are some other tricks you may have to use. For example decimation filter stage by stage will help you to deal with the low-frequency filters.
