Hi all, I would like to know "the" right method to analytically calculate the Probability Density Function (PDF) of the output of a FIR filter whose input PDF is not gaussian (the indicator function for instance)... I learnt that when i was a student (long time ago) and i can't remember the way to make such calculation... :( Can anyone help ? Thanx in advance. A.Herbert
statistics of a linearly filtered (digital) signal
Started by ●August 4, 2004
Reply by ●August 4, 20042004-08-04
Arthur Herbert wrote:> Hi all, > I would like to know "the" right method to analytically calculate the > Probability Density Function (PDF) of the output of a FIR filter whose > input PDF is not gaussian (the indicator function for instance)... > I learnt that when i was a student (long time ago) and i can't remember > the way to make such calculation... :( > Can anyone help ? > Thanx in advance. > A.HerbertMethod A: Drag out your statistics book and get to work. Method B: Does it have a finite variance? If so, and if you're averaging enough samples in you filter, use the central limit theorem, which says that if you add enough non-Gaussian random variables together the result will be Gaussian. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
