Hi there, I am working with a C6713DSK, using CCS 3.1 (platinum edition) and I wish to use the C6713DSK Device Cycle Accurate Simulator to profile all the functions in my program. If I try to run my program using the Device Cycle Accurate Sim. CCS stops responding, the Windows CPU Usage indicator shows 100% usage and I am forced to restart CCS. I have increased the maximum memory usage directive (MEM_USAGE_LIMIT) in my *.cfg file from 64 MB to 256 MB but it did not help. My first thought was that I was maybe profiling way too much information causing the simulator to saturate, but even when the profiler is disabled CCS still crashes. I have disabled the "Detect Reserved Memory Access" option from the target because I am not really familiar on how to write my own input files to simulate the input peripherals. Could this be causing this problem? Any ideas anyone? Thanks Andres This message was sent using the Comp.DSP web interface on www.DSPRelated.com
C6713 DSK Device Cycle Accurate Simulator crashes CCS
Started by ●October 17, 2005
Reply by ●October 18, 20052005-10-18
"entropyboy81" <moctezum@vt.edu> wrote in message news:rI6dnc5rD4LGisneRVn-ig@giganews.com...> I am working with a C6713DSK, using CCS 3.1 (platinum edition) and I wish > to use the C6713DSK Device Cycle Accurate Simulator to profile all the > functions in my program.Sorry to answer a question with a question, but is there a step by step guide anywhere on getting CCS 3.1 PE to work with the C6713DSK? I have so far been unsuccessful. Kind Regards, Howard
