FFTW in Visual Studio C++
Started by karenying October 18, 2005
I want to use FFTW in visual Studio 6.0 , and I have downloaded
the  FFTW 3.0.1 static library files from
http://www.ece.cmu.edu/~franzf/fftw.org/.
However, I cannot run the program as expected ?
Did i do anything wrong ?
I did not download the
FFTW 3.0.1 VisualStudio 6.0 project files (require Intel C++ compiler
installed) because there is compliation error when i build it and i cannot
solve this bug ~~
What should I do ?? Please help me because I have been spent a lot of time
in managing FFTW~~ Otherwise, I have to give up ~~
Which library should be included in order to run a smooth and correct
version of FFTW ??
        Karen
This message was sent using the Comp.DSP web interface on
www.DSPRelated.com
Karen,
Include fftw3.h in your program.
Link your executable with fftw2.lib.
At run-time, make sure you have the FFTW DLL in your path.
This should work just fine.
If not, email me to dspengr@gmail.com
Thanks,
Anders
karenying wrote:
> I want to use FFTW in visual Studio 6.0 , and I have downloaded > the FFTW 3.0.1 static library files from > http://www.ece.cmu.edu/~franzf/fftw.org/. > However, I cannot run the program as expected ? > Did i do anything wrong ? > I did not download the > FFTW 3.0.1 VisualStudio 6.0 project files (require Intel C++ compiler > installed) because there is compliation error when i build it and i cannot > solve this bug ~~ > What should I do ?? Please help me because I have been spent a lot of time > in managing FFTW~~ Otherwise, I have to give up ~~ > > Which library should be included in order to run a smooth and correct > version of FFTW ?? > Karen > > > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Should link with fftw3.lib, nothing else.
