hi to all! while searching for video decoder i came through this site.actually i am looking for a video decoder if any1 can suggest me something. i am in need of a video decoder for which the input is continuous stream of data from a video camera and the output is frame by frame pictures in digital output format.the decoder should be compatible for both analog as well as digital input. thnx!
video decoder
Started by ●October 26, 2005
Reply by ●October 26, 20052005-10-26
suruchi81@gmail.com wrote:> > hi to all! > while searching for video decoder i came through this site.actually i > am looking for a video decoder if any1 can suggest me something. i amThere are quite a few video decoder chips available. I'd suggest you have a look at the Philips SAA7115 or the Conexant CX25836/7. Both these devices will digitise NTSC, PAL or SECAM and squirt out a BT.656 datastream. A google search for BT.656 will also be productive. Most video decoder chips are horribly complicated devices, although some have "automatic" modes that allow operation with the minimum amount of effort. Usually they're programmed using I2C or similar. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
suruchi81@gmail.com wrote:> hi to all! > while searching for video decoder i came through this site.actually i > am looking for a video decoder if any1 can suggest me something. i am > in need of a video decoder for which the input is continuous stream of > data from a video camera and the output is frame by frame pictures in > digital output format.the decoder should be compatible for both analog > as well as digital input. > thnx!The description of your needs is contradictory. The video our of most cameras is unencoded, frame by frame. It would help if you understood the formats you discuss and the terms you use. Keep talking. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 27, 20052005-10-27
suruchi81@gmail.com writes:> hi to all! > while searching for video decoder i came through this site.actually i > am looking for a video decoder if any1 can suggest me something. i am > in need of a video decoder for which the input is continuous stream of > data from a video camera and the output is frame by frame pictures in > digital output format.the decoder should be compatible for both analog > as well as digital input. > thnx!Hi suruchi81, We use the TI TVP5150 decoder in my project at work. We're also using the TI TMS320DM642, so the two make a good matching pair. TI also has example video drivers for this part, so it's hard to go wrong with this chip if you're using their platform. I don't know much about the Philips chip Mark mentioned - maybe it's better in some respects. -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Reply by ●October 28, 20052005-10-28
Randy Yates wrote:> > We use the TI TVP5150 decoder > I don't know much about the Philips chip Mark mentioned - maybe it's > better in some respects.The TVP5150 wasn't suitable for our application because it has a truly awful lock time (of the order of tens of fields). Not good if you're switching between non-genlocked sources. Otherwise, it looked fine and, as you say, has good software support from TI. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
