StpNrrs@aol.com wrote:> robert bristow-johnson wrote: > >>in article 1130629424.117822.102680@f14g2000cwb.googlegroups.com, >>maestro@ultrapiano.com at StpNrrs@aol.com wrote on 10/29/2005 19:43: >> >>[...]> > "this known neural bottleneck". Do you mean the disparity in the > amount of information that the ear sends the brain, at most a few > thousand haircells firing ten times per second, compared to the > 44100*16 bits per second required for high-fidelity digital audio > sound? The same 'known neural bottleneck' occurs in the eyes - about > 1000000*3*25 bits per second when your're looking at your computer > monitor. >Try this. Fill your monitor with approximately 8 point text, and see how much you can read with your peripheral vision. Not much, eh?
the computational neurophysics of perception
Started by ●October 29, 2005
Reply by ●October 30, 20052005-10-30
Bryan Hackney wrote:> StpNrrs@aol.com wrote: > > robert bristow-johnson wrote: > > > >>in article 1130629424.117822.102680@f14g2000cwb.googlegroups.com, > >>maestro@ultrapiano.com at StpNrrs@aol.com wrote on 10/29/2005 19:43: > >> > >> > [...] > > > > "this known neural bottleneck". Do you mean the disparity in the > > amount of information that the ear sends the brain, at most a few > > thousand haircells firing ten times per second, compared to the > > 44100*16 bits per second required for high-fidelity digital audio > > sound? The same 'known neural bottleneck' occurs in the eyes - about > > 1000000*3*25 bits per second when your're looking at your computer > > monitor. > > > > Try this. Fill your monitor with approximately 8 point text, and see how > much you can read with your peripheral vision. Not much, eh?I was being ironic... In fact I agree with you, there is obviously hardly any information going from the eyes and ears into the brain, compared with the number of bits/sec of digital sound and video. "robert bristow-johnson" seems to think that the auditory nerves are rather like internet broadband connections into the inner brain, and claims that this must cause an information bottleneck. He proposes the theory that the ears discard so much information from the original audio signal that the resultant input into the brain is very lossy and therefore noisy, and claims that the inner brain is using noise-reduction techniques on this input to produce the perception of hi-fi audio. The idea is basically nonsense, and I pointed out that the same situation is 1000s of times worse for the optical system, and therefore unworkable (as you also realise). It is misleading to think that a sound 'is' the 41000 16-bit samples per second of digital audio (and that visual information 'is' the 1000000 RGB pixels at 25 frames per second of digital video). The sense of sound occurs in the brain - if a tree falls in a forest, it causes pressure variations in the air but it does not itself make the sound. The ears sense variations in air-pressure, and when the brain recognises features and patterns in that information, it can identify a sound as similar to something it has heard before. The vast amount of understanding of sounds stored in the brain's memory is gained from a lifetime's experience of hearing, and compensates for the apparently 'low quality signal' that the ears give the brain.
steve sulis wrote:> FWIW, I recently suffered some inner-ear damage due to a virus ? > specialists don't definitively know yet. At 1st I was completely deaf > in the left ear. Gradually the sound is coming back. I now get the > following properties in my perception of sound :- > Low freqs(<1000Hz) + High freqs(>3KHz) are ok ( well, as good as they > ever were) > Mostly silence from 1KHz -> 2.2KHz, but strong peaks of response at a > few spot frequencies.Cochlear implants are sometimes effective in treating cases like yours. The damaged area of the ear is connected to the auditory system with miniature wires, and although the connections are initially random, the ear learns to make sense of them after a while. The brain's ability to compensate for internal damage is remarkable - stroke victims can often re-learn how to use their limbs if the part of the brain that deals with them has been damaged.> The weidest thing is hearing the same pure sinewave a different > frequencies depending on whether I use the right ear or left ear. The > difference is like C to F# in the same octave. > The above figures are not exact, but are roughly what I get.There are several possible reasons for that, perhaps the rate that the haircell synapses are firing, or the time it takes for the synapses to 'recharge their batteries', has been affected by the virus and is different in your damaged ear.> I had always imagined that perception of frequency would be invarient > from left to right ear, but now I know better.The following experiment gives a quite amazing result: take two simple tunes, the first consisting of ascending notes and the second consisting of descending notes. Make two further tunes, each consisting of alternate notes from the original tunes - these both sound like a sequence of random ups and downs without any meaningful 'tune' to either of them. If these two 'non-tunes' are played to the ears through stereo head-phones, the brain magically sorts them out and hears the two original melodies, and the listener hears the ascending tune as coming from one earphone and the descending tune as coming from the other! Furthermore, if the stereo head-phones are then reversed left/right, the listener hears the two melodies in the same ears (left or right) as before - the brain has learnt to sort out the sound in that particular way on the first hearing, and interprets what might otherwise be confusing information the same way on subsequent hearings. I suppose its something to do with the brain's response to perceiving two threatening noises simultaneously, one on the left and the other on the right. The brain seems to correctly decide where the sounds are coming from at a higher priority than correctly identifying what the sounds 'are'.
in article sx69f.38759$5e4.24448@tornado.texas.rr.com, Bryan Hackney at no@body.home wrote on 10/30/2005 11:29:> StpNrrs@aol.com wrote: >> robert bristow-johnson wrote: >> >>> in article 1130629424.117822.102680@f14g2000cwb.googlegroups.com, >>> maestro@ultrapiano.com at StpNrrs@aol.com wrote on 10/29/2005 19:43: >>> >>> > [...] >> >> "this known neural bottleneck". Do you mean the disparity in the >> amount of information that the ear sends the brain, at most a few >> thousand haircells firing ten times per second, compared to the >> 44100*16 bits per second required for high-fidelity digital audio >> sound? The same 'known neural bottleneck' occurs in the eyes - about >> 1000000*3*25 bits per second when your're looking at your computer >> monitor. >> > > Try this. Fill your monitor with approximately 8 point text, and see how > much you can read with your peripheral vision. Not much, eh?listen, man, i'm within 3 months of AARP eligibility. i'm lucky if i even read the approximately 8 point text. i sure as hell can't read street names in most maps. i used to be 20/15 but am close to getting reading glasses. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson wrote: ...> listen, man, i'm within 3 months of AARP eligibility. i'm lucky if i even > read the approximately 8 point text. i sure as hell can't read street names > in most maps. i used to be 20/15 but am close to getting reading glasses.Go to it, big boy! I'm 20/30 without my bifocals and 20/15 with them. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
