Eric Jacobsen wrote:> On 2 Nov 2005 19:30:22 -0800, "Mark" <makolber@yahoo.com> wrote: > > >Question for you guys (that are smarter than I am).... > > Don't think that for a second... ;) > > >If the (random AWGN) noise were added near the front end of the radio > >(as is the normal case) and then the signal were hard limited (as is > >the normal case for an FM system)... would the hard limiter impact the > >SNR of the I and Q differently? I'm thinking the limiter removes much > >of the AM noise but does not reduce the FM (phase) noise. But I'm not > >clear if this translates into I and Q that way or even if the OP is > >hard limiting his signal before demodulation. > > No, it should affect I and Q the same. Remember, the definitions of > which is I and which is Q are more or less arbitrary. It is often up > to the receiver to sort out the phase ambiguity by using something > embedded in the signal, otherwise there's no way to tell which is I > and which is Q. The amps and noise sources can't tell either, until > they're actually separated by the mixer. > > > Eric Jacobsen > Minister of Algorithms, Intel Corp. > My opinions may not be Intel's opinions. > http://www.ericjacobsen.orgok thanks Mark
I and Q SNR in a IQ mixer
Started by ●October 31, 2005
Reply by ●November 4, 20052005-11-04
