Hey everybody, I'm currently working on a sound-source localization project and was hoping you could offer me some help. First, I have two microphones which I am running to two amplifiers (one for each signal). I want to read these signals with my PC sound card's line-in and signal process using MATLAB. Can I simply connect a Y-cable to combine the two amp outputs into a single, stereo input into my line-in (and then use software to seperate it into right and left channels for processing)? Second, assuming I get the system set up and working statically, how exactly does one go about running such a process (record-->process-->repeat) in real-time? I'd really appreciate it if anyone could give me a pretty basic overview of the vital concepts and components of setting up said real-time system. Thanks a lot for the help.
Combining Signals for Sound Card Line-In
Started by ●November 6, 2005
Reply by ●November 7, 20052005-11-07
Polar wrote:> Hey everybody, > > I'm currently working on a sound-source localization project and was > hoping you could offer me some help. > > First, I have two microphones which I am running to two amplifiers (one > for each signal). I want to read these signals with my PC sound card's > line-in and signal process using MATLAB. Can I simply connect a Y-cable > to combine the two amp outputs into a single, stereo input into my > line-in (and then use software to seperate it into right and left > channels for processing)?A stereo signal is two channels of mono. What's to separate?> Second, assuming I get the system set up and working statically, how > exactly does one go about running such a process > (record-->process-->repeat) in real-time? I'd really appreciate it if > anyone could give me a pretty basic overview of the vital concepts and > components of setting up said real-time system.You write the program as a loop, and make it lean enough so the loop can execute in the allotted time. A more detailed answer would require a more detailed question from you. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> wrote in message news:BPCdnRSD15KxSvPeRVn-tA@rcn.net...> Polar wrote: >> Hey everybody, >> >> I'm currently working on a sound-source localization project and was >> hoping you could offer me some help. >> >> First, I have two microphones which I am running to two amplifiers (one >> for each signal). I want to read these signals with my PC sound card's >> line-in and signal process using MATLAB. Can I simply connect a Y-cable >> to combine the two amp outputs into a single, stereo input into my >> line-in (and then use software to seperate it into right and left >> channels for processing)? > > A stereo signal is two channels of mono. What's to separate?The OP probably just means he would make the recording of both channels at once as a single stereo file and then separate it into two mono files with sound editor software. If so, then yes, that should be no problem. You just need to make sure you get the right Y-cable, i.e. one that combines 2 mono sources into stereo, rather than one that mixes 2 mono sources to mono. I happen to have one sitting on my desk here that has 2 RCA jacks on one end and a stereo (aka tip-ring-sleave) 1/8" jack (i.e. like most headphones) on the other. Something like that would be perfect.>> Second, assuming I get the system set up and working statically, how >> exactly does one go about running such a process >> (record-->process-->repeat) in real-time? I'd really appreciate it if >> anyone could give me a pretty basic overview of the vital concepts and >> components of setting up said real-time system. > > You write the program as a loop, and make it lean enough so the loop can > execute in the allotted time. A more detailed answer would require a more > detailed question from you.You could try looking for some open-source recording software or libraries. Someone else may have a specific recommendation, but failing that, try http://www.google.com/search?hl=en&q=open+source+audio+record.
