Everyone, I am creating a backpropagated multilayer perceptron ANN using a MEMs accelerometer to distinguish between automobile types. My question is.... Since most likely the ANN is going to "lock" onto the vibration of the engine would it be in my interest to convert the time data into frequency data for the input layer? Does it even matter? Obvioulsy for a person it is easier to look at in frequency but when about for a NN? Also, any suggestions on how many inputs I should have. I figured my largest frequency to be (at idle) 3000 rpm / 60 = 50 Hz. So a whole second of data only gives me 100 samples. Too many or too few? Any tips on figuring this out before I hit the trial and error stage? Thanks. --Ryan
Neural Network Discussion
Started by ●November 10, 2005
Reply by ●November 10, 20052005-11-10
First, if you are using a neural network, I'd recommend that you also try using a support vector machine on the same data to see which is better. See: http://www.csie.ntu.edu.tw/~cjlin/libsvm/ for a free svm implementation. The real art to using any machine learning approach, which includes neural networks and svms, is designing your input vector. There's no a priori way that I know of to guarantee that one input representation will out-perform another one. Though if you produce a fitness landscape (of sets of weights for the network) which is smaller and less "hilly", that will often lead to better performance after training because [in simple words] it's easier to find good solutions. What you probably need to do is research a wide range of possible input vector formats. And, you might find that you can improve performance dramatically by including more meaningful transformations of the original raw data into attributes included in the input vector. Hence, if you follow my suggestion you'll end up doing a lot of experimental work looking at various representations of your problem and seeing what the performance is. I.e. a fancier way of saying trial and error. The paper by Ross Quinlan on applying Decision Trees to chess end-games is I think quite illuminating. http://citeseer.ist.psu.edu/context/52186/0 [reference only] In it he ends up making up all sorts of attributes of chess boards to feed into his learning program to make it work well. Personally I think this exposes the limitations of input languages limited to zero-order logics rather than really attacking the problem of classifying chess end-games as won or lost. I.e. he really ends up partially solving the problem before getting his learning program to finish it off. But, you might find that doing similar leads to best performance. If you do take the experimental approach, please make sure that you follow proper experimental procedure for evaluating the performance of learning algorithms. E.g. use some form of cross-validation. The chapter on evaluating classifier performance in the book: "Elements of Statistical Learning" (http://www-stat.stanford.edu/~tibs/ElemStatLearn/) by Tibshirani, Hastie, and Friedman might be useful. There's another book "Introduction to Machine Learning" by Alpaydin http://www.amazon.com/gp/product/0262012111/103-1527503-7491050?v=glance&n=283155&n=507846&s=books&v=glance [apologies for the commercial link] which also covers experimental procedure. I'm not a real DSP person, so some of this may be a bit off-topic. But I hope there's at least something useful or vaguely helpful for you in this followup. Cheers, Ross-c
effimofunk wrote:> Everyone, > I am creating a backpropagated multilayer perceptron ANN using a MEMs > accelerometer to distinguish between automobile types. My question > is.... > > Since most likely the ANN is going to "lock" onto the vibration of the > engine would it be in my interest to convert the time data into frequency > data for the input layer? Does it even matter? Obvioulsy for a person it > is easier to look at in frequency but when about for a NN? Also, any > suggestions on how many inputs I should have. I figured my largest > frequency to be (at idle) > > 3000 rpm / 60 = 50 Hz. So a whole second of data only gives me 100 > samples. Too many or too few? Any tips on figuring this out before I hit > the trial and error stage? > > Thanks. > --RyanKeeping it in the time domain with an autocorrelation function may be better -- I'd experiment with both. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
> 3000 rpm / 60 = 50 Hz. So a whole second of data only gives me 100 > samples. Too many or too few? Any tips on figuring this out before I hit > the trial and error stage?Well one tip is to oversample - the engine noise does not only consist of the fundamental period, but is highly distorted. If you only sample the fundamental period, your automobile classification algorithm will have a hard time (try to listen and discern to idling automobiles situated on the road in front of your house while you are in the bedroom with windows closed and hiding under the blanket). I would suggest sampling at the standard audio frequencies of 44.1 or 48 kHz. Will the automobiles only be idling and stationary? Can you expect to have the engine ignition process on record as well? Regards, Andor
clemenr@wmin.ac.uk wrote:> First, if you are using a neural network, I'd recommend that you also > try using a support vector machine on the same data to see which is > better.Have to agree there. A colleague of mine whose research is in learning theory calls neural networks "neutral notworks". SVMs are a more rigorous, and justifiable, way to go. Ciao, Peter K.
Andor,>I would >suggest sampling at the standard audio frequencies of 44.1 or 48 kHz.I may oversample some but there are a few reasons that limit the amount of oversampling that I can achieve. 1) The maximum bandwidth of the accelerometers is 2500 Hz. 2) I expect a very small hum and therefore small acelleration so the wider I set the output bandwidth of the accelerometer the more noise I see in my ADC and hence the less precise quantization.>Will the automobiles only be idling and stationary?The automobile will be idling and stationary becuase that is how I feel I will get the best reults to start with. If it is not idling it would be hard to standardize the testing. If it were moving it just makes it even worse. So to start with I will leave it just purring....>Can you expect to >have the engine ignition process on record as well?I could, but again I am not sure I will. I plan on mounting these accelerometers directly to the engine so there should be quite a good characteristic frequency based on the engine type (i.e. inline 4, V6, V8, etc.) . --Ryan
"effimofunk" <rfrankel@ufl.edu> wrote in message news:Z8ydnQhdnsQ-ju7eRVn-vA@giganews.com...> Everyone, > I am creating a backpropagated multilayer perceptron ANN > using a MEMs > accelerometer to distinguish between automobile types. My > question > is.... > > Since most likely the ANN is going to "lock" onto the > vibration of the > engine would it be in my interest to convert the time data > into frequency > data for the input layer? Does it even matter? Obvioulsy > for a person it > is easier to look at in frequency but when about for a NN? > Also, any > suggestions on how many inputs I should have. I figured > my largest > frequency to be (at idle) > > 3000 rpm / 60 = 50 Hz. So a whole second of data only > gives me 100 > samples. Too many or too few? Any tips on figuring this > out before I hit > the trial and error stage? > > Thanks. > --RyanYou should consider posting (maybe cross-posting) this question to comp.ai.neural-nets. You'll probably get some good advice from there as well.
"effimofunk" <rfrankel@ufl.edu> wrote in message news:WqWdnYJzHbubBe7enZ2dnUVZ_tednZ2d@giganews.com...> Andor, > > >I would > >suggest sampling at the standard audio frequencies of 44.1 or 48 kHz. > > I may oversample some but there are a few reasons that limit the amount > of oversampling that I can achieve. > 1) The maximum bandwidth of the accelerometers is 2500 Hz. > 2) I expect a very small hum and therefore small acelleration so the > wider I set the output bandwidth of the accelerometer the more noise I see > in my ADC and hence the less precise quantization. > > >Will the automobiles only be idling and stationary? > The automobile will be idling and stationary becuase that is how I feel > I will get the best reults to start with. If it is not idling it would be > hard to standardize the testing. If it were moving it just makes it even > worse. So to start with I will leave it just purring.... > > >Can you expect to > >have the engine ignition process on record as well? > I could, but again I am not sure I will.What if it's Diesel ????? :)> > I plan on mounting these accelerometers directly to the engine so there > should be quite a good characteristic frequency based on the engine type > (i.e. inline 4, V6, V8, etc.) . > > --Ryan > > >
Reply by ●November 11, 20052005-11-11
effimofunk wrote: ...> So to start with I will leave it just purring.......> I plan on mounting these accelerometers directly to the engine so there > should be quite a good characteristic frequency based on the engine type > (i.e. inline 4, V6, V8, etc.) .Ryan, I don't understand your application. If you can completely control the behaviour of the vehicle, and you can mount the sensors yourself, why don't you just look at the make of the car instead of mounting the sensors? By the way, this accelerometer seems to be completely outpreformed by a $5 Radio Shack microphone (2.5kHz bandwidth?). I assume you want this application to run under other conditions as well - what are _those_ conditions? Or is this just for fun? Regards, Andor
Andor, The reason I am starting the way I am is to reduce the variations in parameter space associated with the problems you mentioned. If I cannot obtain reliable results by mounting it myself and controlling the vehicle I cannot expect to obtain good results with other features involved. As far as the radio shack microphone: The MEMs accelerometers can measure extremely low-levels of g-forces as well as having a footprint of about a mm^2. Enlarging the bandwidth of the filter does not help that much due to the excessive thermal noise that you let in (i.e. extending the bandwidth by a factor of 2 increases the noise floor of your system by 3dB). For this reason it is usually best to use the lowest sampling rate possible in these types of applications.>effimofunk wrote: >... >> So to start with I will leave it just purring.... >... >> I plan on mounting these accelerometers directly to the engine sothere>> should be quite a good characteristic frequency based on the enginetype>> (i.e. inline 4, V6, V8, etc.) . > >Ryan, I don't understand your application. If you can completely >control the behaviour of the vehicle, and you can mount the sensors >yourself, why don't you just look at the make of the car instead of >mounting the sensors? By the way, this accelerometer seems to be >completely outpreformed by a $5 Radio Shack microphone (2.5kHz >bandwidth?). > >I assume you want this application to run under other conditions as >well - what are _those_ conditions? Or is this just for fun? > >Regards, >Andor > >
