Hello. I am using this code #include <dsk6713.h> #define GPIO_ENABLE_ADDRESS 0x01B00000 #define GPIO_DIRECTION_ADDRESS 0x01B00004 #define GPIO_VALUE_ADDRESS 0x01B00008 void main( void ) { int* GPIO_ENABLE_REGISTER,* GPIO_DIRECTION_REGISTER, * GPIO_VALUE_REGISTER ; GPIO_ENABLE_REGISTER = (int*)GPIO_ENABLE_ADDRESS ; GPIO_DIRECTION_REGISTER = (int*)GPIO_DIRECTION_ADDRESS ; GPIO_VALUE_REGISTER = (int*)GPIO_VALUE_ADDRESS ; *GPIO_ENABLE_REGISTER = 255 ; *GPIO_DIRECTION_REGISTER = 255 ; DSK6713_init(); while( 1 ) { *GPIO_VALUE_REGISTER = 255 ; DSK6713_waitusec(500000); *GPIO_VALUE_REGISTER = 0 ; DSK6713_waitusec(500000); } } It is not working, it is only working in the GPO[ 2 ] pin, and I think this is because it is also connected internally to the CLKOUT2. Why it is not working???? And also, I want to use my own delay functions because I want to make an application out of the DSK one day. Thanks a lot.
GPIO in C6713
Started by ●November 10, 2005
Reply by ●November 15, 20052005-11-15
I was going to try this but haven't had the time yet. I can't see anything particularly wrong with how you set things up and wondered if your DSP was little endian. My GPIO registers are 16 bit and if they're little endian (which I think mine is) I was going to attempt the same code but with values 0xFF00 instead of 0x00FF
kostbill wrote:> Hello. > > I am using this code > > #include <dsk6713.h> > > #define GPIO_ENABLE_ADDRESS 0x01B00000 > #define GPIO_DIRECTION_ADDRESS 0x01B00004 > #define GPIO_VALUE_ADDRESS 0x01B00008 > > void main( void ) > { > int* GPIO_ENABLE_REGISTER,* GPIO_DIRECTION_REGISTER, * > GPIO_VALUE_REGISTER ; > > GPIO_ENABLE_REGISTER = (int*)GPIO_ENABLE_ADDRESS ; > GPIO_DIRECTION_REGISTER = (int*)GPIO_DIRECTION_ADDRESS ; > GPIO_VALUE_REGISTER = (int*)GPIO_VALUE_ADDRESS ; > > *GPIO_ENABLE_REGISTER = 255 ; > *GPIO_DIRECTION_REGISTER = 255 ; > > DSK6713_init(); > > while( 1 ) > { > *GPIO_VALUE_REGISTER = 255 ; > DSK6713_waitusec(500000); > *GPIO_VALUE_REGISTER = 0 ; > DSK6713_waitusec(500000); > } > > } > > It is not working, it is only working in the GPO[ 2 ] pin, and I think > this is because it is also connected internally to the CLKOUT2. > > Why it is not working???? And also, I want to use my own delay functions > because I want to make an application out of the DSK one day. > > Thanks a lot.I'm not familiar with your DSK library, but I suspect you might be able to do things better if you used the Chip Select Library (CSL) that comes with Code Composer Studio, which I presume also came with your DSK. Check out the help files accompanying CCS on the topic "GPIO Module Description" and on the related pages. Cheers! --M
Reply by ●November 18, 20052005-11-18
