I want to do some frame-based processing of an input signal with a C-code program on a hardware DSP. One of the things I really want is an FIR filter which gives an output signal with the same length (in terms of samples) as the input signal and is also time-aligned with the input (i.e no delay or offset). All of the FIR implementations I have seen either result in a shorter output, delay the output by m/2 samples (where m is the filter order), or truncate the last m/2 samples. Since we are talking about frame-based processing and not point-by-point processing, I think what I want should be possible. I expect that the filter will probably need to be acausal, but I only have experience with designing/implementing causal filters. Does anyone hvae any code that implements this sort of filter or can someone point me to a book, article, or webpage which describes how to do it in sufficient detail that I would be able to implement it myself? The MATLAB Signal Processing Toolbox command "filtfilt" comes very close to doing what I want. It actually does something significantly more complicated than what I need (and is thus significantly less efficient than I would like). But it's existence is essentially proof to me that what I want should be doable. Any advice would be greatly appreciated.
FIR filter with output same length as input which is also time-aligned with input
Started by ●November 10, 2005
Reply by ●November 10, 20052005-11-10
todd.leonhardt@gmail.com wrote:> I want to do some frame-based processing of an input signal with a > C-code program on a hardware DSP. One of the things I really want is > an FIR filter which gives an output signal with the same length (in > terms of samples) as the input signal and is also time-aligned with the > input (i.e no delay or offset). All of the FIR implementations I have > seen either result in a shorter output, delay the output by m/2 samples > (where m is the filter order), or truncate the last m/2 samples. > > Since we are talking about frame-based processing and not > point-by-point processing, I think what I want should be possible. I > expect that the filter will probably need to be acausal, but I only > have experience with designing/implementing causal filters. > > Does anyone hvae any code that implements this sort of filter or can > someone point me to a book, article, or webpage which describes how to > do it in sufficient detail that I would be able to implement it myself? > > The MATLAB Signal Processing Toolbox command "filtfilt" comes very > close to doing what I want. It actually does something significantly > more complicated than what I need (and is thus significantly less > efficient than I would like). But it's existence is essentially proof > to me that what I want should be doable. > > Any advice would be greatly appreciated. >If your frames are contiguous samples from a stream of data, then you should really save state between frames, or you will get chirps at frame boundaries. Find a way to live with the m/2 delay. If the data frames are standalone sequences that do not represent streams, read on. With a symmetric FIR filter of length 2L+1, the group delay is L. Convolving that with a vector of length K would yield a full convolution sequence of length K+2L. Assuming you are using a Matlab-style filter that gives you all of the input-on transient and none of the input-off transient; Drop L samples from the input-on transient and pad L zeros on the end of your input sequence. If all the above is true, this should nicely superimpose the input & output vectors. The beginning and ending of the sequence will show some warbling, but *if* you don't know what the signal was before or after, then this is about as good as you can do. I repeat. If the frames are chunks of a continuous signal -- keep the state and find a way to deal with the group delay. -- Mark Borgerding
Mark Borgerding wrote:> todd.leonhardt@gmail.com wrote: > >>I want to do some frame-based processing of an input signal with a >>C-code program on a hardware DSP. One of the things I really want is >>an FIR filter which gives an output signal with the same length (in >>terms of samples) as the input signal and is also time-aligned with the >>input (i.e no delay or offset). All of the FIR implementations I have >>seen either result in a shorter output, delay the output by m/2 samples >>(where m is the filter order), or truncate the last m/2 samples. >> >>Since we are talking about frame-based processing and not >>point-by-point processing, I think what I want should be possible. I >>expect that the filter will probably need to be acausal, but I only >>have experience with designing/implementing causal filters. >> >>Does anyone hvae any code that implements this sort of filter or can >>someone point me to a book, article, or webpage which describes how to >>do it in sufficient detail that I would be able to implement it myself? >> >>The MATLAB Signal Processing Toolbox command "filtfilt" comes very >>close to doing what I want. It actually does something significantly >>more complicated than what I need (and is thus significantly less >>efficient than I would like). But it's existence is essentially proof >>to me that what I want should be doable. >> >>Any advice would be greatly appreciated. >> > > > If your frames are contiguous samples from a stream of data, then > you should really save state between frames, or you will get chirps at > frame boundaries. Find a way to live with the m/2 delay. > > If the data frames are standalone sequences that do not represent > streams, read on. > > With a symmetric FIR filter of length 2L+1, the group delay is L. > Convolving that with a vector of length K would yield a full convolution > sequence of length K+2L. > > Assuming you are using a Matlab-style filter that gives you all of the > input-on transient and none of the input-off transient; Drop L samples > from the input-on transient and pad L zeros on the end of your input > sequence. > > If all the above is true, this should nicely superimpose the input & > output vectors. The beginning and ending of the sequence will show some > warbling, but *if* you don't know what the signal was before or after, > then this is about as good as you can do. > > I repeat. If the frames are chunks of a continuous signal -- keep the > state and find a way to deal with the group delay. > > > -- Mark BorgerdingAlternatively, if you find a non-causal filter, please post the code! :=) Regards, John
Reply by ●November 11, 20052005-11-11
Mark, Thanks for your advice. The frames are contiguous samples from a sensor. However, I plan on extracting relevant info/parameters on a frame-by-frame basis, at least to start with, so I'm not overly concerned with discontinuities at frame boundaries. I quickly tested your advice in MATLAB regarding taking the full-blown convolution and chopping m/2 samples off both the beginning and end of the output. This seems to work very well except at the edges. I might be able to live with that and I also think I might be able to make it work a litlte better if I make some intelligent assumptions regarding the filter's initial state. But your point about keeping the state is well taken. It would obviously work much better if I saved some information from the previous frame. Thanks for your advice, Todd
John, Implementing a non-causal filter is not an oxymoron if you are doing frame-based processing (as opposed to point-by-point "hard" realtime processing). Here is my pseudocode for implementing a noncausal filter: x = input signal X = FFT{x} A = desired magnitude response of filter (could have A = FFT{h}, where h are filter coefficients) y = output signal y = IFFT{X * A} So I found one and there's the code .... ;-) I guess I was just wondering if there was an easy way to implement this type of filtering in the time-domain and if so what the advantages/disadvantages are. I think Mark basically answered my question. -Todd
Reply by ●November 12, 20052005-11-12
Todd Leonhardt wrote:> John, > > Implementing a non-causal filter is not an oxymoron if you are doing > frame-based processing (as opposed to point-by-point "hard" realtime > processing). Here is my pseudocode for implementing a noncausal > filter: > > x = input signal > X = FFT{x} > A = desired magnitude response of filter > (could have A = FFT{h}, where h are filter coefficients) > y = output signal > > y = IFFT{X * A} > > So I found one and there's the code .... ;-) > > I guess I was just wondering if there was an easy way to implement this > type of filtering in the time-domain and if so what the > advantages/disadvantages are. I think Mark basically answered my > question. > > -Todd >Todd, I could not resist that comment and I am sure it did not cause any offence. I think we differ as to what we mean by acausal. I take an 'acausal' filter to be one in which the output is derived in part at least from signal samples that have yet to arrive. The term comes up in textbooks because it is easiest to define t=0 as the centre of the impulse response. If I had an acausal filter (a very long one) I think I could make a lot of money on the stock market, hence my request :=) Unfortunately I don't think your pseudo-code qualifies because it does not even begin processing until all the samples in one batch have arrived. By the way, I don't think it makes any sense to talk about causality or non-causality in regard to processing that is not real-time, but of course this may depend on your definition. Regards, John
John Monro wrote: ...> I think we differ as to what we mean by acausal. > I take an 'acausal' filter to be one in which the output is derived in > part at least from signal samples that have yet to arrive. The term > comes up in textbooks because it is easiest to define t=0 as the centre > of the impulse response. If I had an acausal filter (a very long one) I > think I could make a lot of money on the stock market, hence my request :=) > > Unfortunately I don't think your pseudo-code qualifies because it does > not even begin processing until all the samples in one batch have arrived. > > By the way, I don't think it makes any sense to talk about causality or > non-causality in regard to processing that is not real-time, but of > course this may depend on your definition.John, I have seen "acausal" loosely applied to off-line processing when the center of the (usually symmetric) impulse is assigned the value t=0. This simplifies the mathematics in many instances, but it has the unfortunate effect of allowing the unwary to believe that latency has been eliminated. It is easy to see how its formal definition (output before input) and its metaphoric use (t=0 later than the first element) can together create confusion. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> John Monro wrote: > > ... > >> I think we differ as to what we mean by acausal. >> I take an 'acausal' filter to be one in which the output is derived in >> part at least from signal samples that have yet to arrive. The term >> comes up in textbooks because it is easiest to define t=0 as the >> centre of the impulse response. If I had an acausal filter (a very >> long one) I think I could make a lot of money on the stock market, >> hence my request :=) >> >> Unfortunately I don't think your pseudo-code qualifies because it does >> not even begin processing until all the samples in one batch have >> arrived. >> >> By the way, I don't think it makes any sense to talk about causality >> or non-causality in regard to processing that is not real-time, but of >> course this may depend on your definition. > > > John, > > I have seen "acausal" loosely applied to off-line processing when the > center of the (usually symmetric) impulse is assigned the value t=0. > This simplifies the mathematics in many instances, but it has the > unfortunate effect of allowing the unwary to believe that latency has > been eliminated. It is easy to see how its formal definition (output > before input) and its metaphoric use (t=0 later than the first element) > can together create confusion. > > JerryJerry, I thought I could indulge in a little pedantry, especially since Mark had pretty well answered Todd's query. Actually something useful did occur to me, and I hope Todd is still following this thread. Todd, why not tack extra samples onto each frame, taking these from the end of the previous frame and the start of the next frame? If the impulse response is N samples long and you add N/2 signal samples to each end then this will eliminate the 'end effect,' as far as the original frame is concerned. I am of course describing what is done with the 'overlap/save' method of doing fast convolution, and this technique is well documented. Regards, John
Reply by ●November 13, 20052005-11-13
John Monro wrote:> Jerry, > I thought I could indulge in a little pedantry, especially since Mark > had pretty well answered Todd's query. > Actually something useful did occur to me, and I hope Todd is still > following this thread. Todd, why not tack extra samples onto each > frame, taking these from the end of the previous frame and the start of > the next frame? If the impulse response is N samples long and you add > N/2 signal samples to each end then this will eliminate the 'end > effect,' as far as the original frame is concerned. > > I am of course describing what is done with the 'overlap/save' method of > doing fast convolution, and this technique is well documented.I don't see that you were any more pedantic than I was. I merely wanted to enter a caveat; that the formal meaning of "causal" and the colloquial way it is used to to mean a shifted time reference can lead the unwary to believe that latency can be circumvented. I don't think I contradicted you in any way. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
