Newbie needs help optimizing quantized FIR LPF coefficients
Started by Tony ●October 26, 2004
Hi,
I want to implement a speed-critical FIR LPF (order about 50-60) in a
16bit MCU (MSP430), but it's MAC accumulator is only 32 bits, so it
could overflow with bad results if I don't scale down the coefficients
so the peak value is about 7000 (decimal). I've installed SciLab
hoping to find a way to optimize the coefficients, but I can't find
anything in Signals that directly relates. Is there a toolbox, or some
SciLab code somewhere, or MatLab code I could convert? Or some other
place to get a clue?
Tony (remove the "_" to reply by email)
On Tue, 26 Oct 2004 19:04:01 +1000, Tony <tony_roe@tpg.com.au> wrote:
>Hi, > >I want to implement a speed-critical FIR LPF (order about 50-60) in a >16bit MCU (MSP430), but it's MAC accumulator is only 32 bits, so it >could overflow with bad results if I don't scale down the coefficients >so the peak value is about 7000 (decimal). I've installed SciLab >hoping to find a way to optimize the coefficients, but I can't find >anything in Signals that directly relates. Is there a toolbox, or some >SciLab code somewhere, or MatLab code I could convert? Or some other >place to get a clue? > >Tony (remove the "_" to reply by email)
Hi, If I understand your question, can you not just multiply all your coefficients by a factor that's less than one? These will make all your coefficients smaller and reduce the amplitude of your filter's output. Now, please realize that reducing the coefficients (all by the same factor) will aggrevate the "quantized" nature of the coefficients and degrade your stopband attenuation. So you must carefully model (simulate) the effect of that increased quantization of the coefficients. If your new coefficients don't satisfy your desired stopband attenuation, you'll just have to increase the number of coefficients (increase the number of taps). Have you considered using a "cascade arrangement" of lower-order FIR filters? Will you be performing any decimation or interpolation in your system? [-Rick-]
Hi Tony,
Tony wrote:
>Hi, > >I want to implement a speed-critical FIR LPF (order about 50-60) in a >16bit MCU (MSP430), but it's MAC accumulator is only 32 bits, so it >could overflow with bad results if I don't scale down the coefficients >so the peak value is about 7000 (decimal). I've installed SciLab >hoping to find a way to optimize the coefficients, but I can't find >anything in Signals that directly relates. Is there a toolbox, or some >SciLab code somewhere, or MatLab code I could convert? Or some other >place to get a clue? > >Tony (remove the "_" to reply by email) > >
Where does the number 7000 come from? You make the problem sound worse than it is. Remember that overflows in additions are reversible by later subtractions. That is, a long string of additions whose final result does not exceed 32 bits will be correct, even if lots of overflowing occurs at the intermediate stages. As long as the overall gain of your filter does not exceed one at any frequency, the final result will be OK. If you are using a filter design tool, it most probably draws a frequency response plot for you. It should be easy to see from that if your filter meets the unity gain criteria. If not, scale everything down until is does. If you are way below unity, you might want to scale everything up to get better resolution in the fixed point calculations. Finally, it is a good idea to try the resulting filter in SciLab, to see if the quantisation you are left with is acceptable. It is usually easier to investigate this in a modelling tool, than in your target machine. Regards, Steve
On Tue, 26 Oct 2004 10:07:38 GMT, r.lyons@_BOGUS_ieee.org (Rick Lyons)
wrote:
>On Tue, 26 Oct 2004 19:04:01 +1000, Tony <tony_roe@tpg.com.au> wrote: > >>Hi, >> >>I want to implement a speed-critical FIR LPF (order about 50-60) in a >>16bit MCU (MSP430), but it's MAC accumulator is only 32 bits, so it >>could overflow with bad results if I don't scale down the coefficients >>so the peak value is about 7000 (decimal). I've installed SciLab >>hoping to find a way to optimize the coefficients, but I can't find >>anything in Signals that directly relates. Is there a toolbox, or some >>SciLab code somewhere, or MatLab code I could convert? Or some other >>place to get a clue? >> >>Tony (remove the "_" to reply by email) > >Hi, > If I understand your question, can you not just >multiply all your coefficients by a factor that's >less than one? These will make all your >coefficients smaller and reduce the amplitude >of your filter's output.
Yes, that's what I've done.
>Now, please realize that >reducing the coefficients (all by the same factor) >will aggrevate the "quantized" nature of the coefficients >and degrade your stopband attenuation. So you >must carefully model (simulate) the effect of that >increased quantization of the coefficients. >If your new coefficients don't satisfy your desired >stopband attenuation, you'll just have to increase >the number of coefficients (increase the number >of taps).
Yes, I realized that, and that was the purpose of my post. But I had vaguely hoped that there might be a method of "fiddling" the quantized coefficients to minimize the effect of the quantizing. From your post it would seem that's not the case, and I really just need to simulate the effect, and keep trying different combinations of sets of quantized filter coefficients until I get something acceptable.
>Have you considered using a "cascade arrangement" of >lower-order FIR filters? >Will you be performing any decimation or >interpolation in your system? > >[-Rick-]
The system is actually decimating 6:1 (because I couldn't find a multi-channel delta-sigma ADC that could sample slowly enough). Before addressing the quantizing issue I tried doing it in two stages, but after taking the overhead into account there was no benefit. Of course now that you've brought that back to mind, there may be a benefit after all as the two smaller FIRs may well not cause the overflow problem in the first place. Good thought!!! Tony Tony (remove the "_" to reply by email)
On Tue, 26 Oct 2004 18:25:59 +0800, Steve Underwood <steveu@dis.org>
wrote:
>Hi Tony, > >Tony wrote: > >>Hi, >> >>I want to implement a speed-critical FIR LPF (order about 50-60) in a >>16bit MCU (MSP430), but it's MAC accumulator is only 32 bits, so it >>could overflow with bad results if I don't scale down the coefficients >>so the peak value is about 7000 (decimal). I've installed SciLab >>hoping to find a way to optimize the coefficients, but I can't find >>anything in Signals that directly relates. Is there a toolbox, or some >>SciLab code somewhere, or MatLab code I could convert? Or some other >>place to get a clue? >> >>Tony (remove the "_" to reply by email) >> >> >Where does the number 7000 come from? You make the problem sound worse >than it is. Remember that overflows in additions are reversible by later >subtractions. That is, a long string of additions whose final result >does not exceed 32 bits will be correct, even if lots of overflowing >occurs at the intermediate stages.
I calculated the nett total result of the coefficient table times the worst-case input stream (trapezoidal mains frequency - an over-driven sine wave), assuming that the overflows you mentioned would be corrected.
> As long as the overall gain of your >filter does not exceed one at any frequency, the final result will be >OK. If you are using a filter design tool, it most probably draws a >frequency response plot for you. It should be easy to see from that if >your filter meets the unity gain criteria. If not, scale everything down >until is does.
That's what happened - I had to scale back (for the prototype FIR a peak coefficient of 7000 produced a gain sufficiently below unity that the fundamental sinusoidal component of my trapezoidal input should stay just below clipping).
> If you are way below unity, you might want to scale >everything up to get better resolution in the fixed point calculations.
That was the reason for the post - the coefficients are so heavily quantized after scaling back that I'm sure the performance is sub-optimum. I'd like a way to automatically optimize the many parameters, but failing that, a way to use SciLab to check the results of my manual work.
>Finally, it is a good idea to try the resulting filter in SciLab, to see >if the quantisation you are left with is acceptable. It is usually >easier to investigate this in a modelling tool, than in your target machine. >Regards, >Steve
So I installed SciLab today, and looked in the Signals macro section, but nothing jumped out at me that looked like the answer to my prayers. How would I "try the resulting filter in SciLab"? Is this the kind of thing for which I should write a dedicated script (Newbie, remember?)? Are the SciLab demos/help enough for this topic, or is there some 3rd party reference I need? Tony (remove the "_" to reply by email)
Tony wrote:
> Hi, > > I want to implement a speed-critical FIR LPF (order about 50-60) in a > 16bit MCU (MSP430), but it's MAC accumulator is only 32 bits, so it > could overflow with bad results if I don't scale down the coefficients > so the peak value is about 7000 (decimal). I've installed SciLab > hoping to find a way to optimize the coefficients, but I can't find > anything in Signals that directly relates. Is there a toolbox, or some > SciLab code somewhere, or MatLab code I could convert? Or some other > place to get a clue? > > Tony (remove the "_" to reply by email)
The MSP430 hardware multiplier includes a sum extend register that extends the accumulator to 48 bits, so you should be able to do a 16-bit FIR with tens of thousands of taps without overflow. See http://focus.ti.com/lit/an/slaa042/slaa042.pdf for details. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"Tony" <tony_roe@tpg.com.au> wrote in message
news:u84sn01nced6u122qkapassmf8o85evmku@4ax.com...
I don't know if this addresses your situation, but it may. It depends on the DSP: Some FIR implementations, particularly in FPGAs, attempt to reduce the number of multiplies by replacing them with shifts and adds. So, what's done is to replace the coefficients with sums of powers of 2 - effectively truncating the coefficients to a small number of bits. Of course, the shifts are done in the "wiring" so add no operational load - so it's a matter of whether adds are "cheaper" in some way than multiplies. 0.625 would be a perfect case: 0.5 + 0.125, etc. So, you attempt to find the "best" result for quantized coefficients over the universe of possible coefficient values - truncated to some number of bits. There's a lot of literature and there are some discussions in comp.dsp about this approach. Fred
Tony wrote:
> [snip] > > So I installed SciLab today, and looked in the Signals macro section, > but nothing jumped out at me that looked like the answer to my > prayers. How would I "try the resulting filter in SciLab"? Is this the > kind of thing for which I should write a dedicated script (Newbie, > remember?)? Are the SciLab demos/help enough for this topic, or is > there some 3rd party reference I need? >
You might try posting your Scilab specific questions to comp.soft-sys.math.scilab . They can be quite helpful for well described questions/problems. A. Fellow Newbie ;}
Tony wrote:
> > So I installed SciLab today, and looked in the Signals macro section, > but nothing jumped out at me that looked like the answer to my > prayers. How would I "try the resulting filter in SciLab"? Is this the > kind of thing for which I should write a dedicated script (Newbie, > remember?)? Are the SciLab demos/help enough for this topic, or is > there some 3rd party reference I need? > > Tony (remove the "_" to reply by email)
You need a dedicated script, AFAIK. Make your filter vector, quantized to 7000 points or whatever. Then make a polynomial out of it and use SciLab's Horner function, or make a ratio of polynomials and fling out a bode plot -- keeping in mind that I've only tried the latter two for filters that are much smaller than yours. You did see my post about the extension register in the MSP430 multiply unit, yes? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Tue, 26 Oct 2004 12:02:05 -0700, Tim Wescott
<tim@wescottnospamdesign.com> wrote:
>Tony wrote: > >> >> So I installed SciLab today, and looked in the Signals macro section, >> but nothing jumped out at me that looked like the answer to my >> prayers. How would I "try the resulting filter in SciLab"? Is this the >> kind of thing for which I should write a dedicated script (Newbie, >> remember?)? Are the SciLab demos/help enough for this topic, or is >> there some 3rd party reference I need? >> >> Tony (remove the "_" to reply by email) > >You need a dedicated script, AFAIK. Make your filter vector, quantized >to 7000 points or whatever. Then make a polynomial out of it and use >SciLab's Horner function, or make a ratio of polynomials and fling out a >bode plot -- keeping in mind that I've only tried the latter two for >filters that are much smaller than yours.
Thanks - I'll try that.
>You did see my post about the extension register in the MSP430 multiply >unit, yes?
No I didn't. Where was it? The extension register didn't look too useful to me (for signed arithmetic), as it slowed down the loop a lot. Sure would like a way to load MACS and OP2 in less than 4 clocks each, too, but the register-indirect modes didn't seem to work. Tony (remove the "_" to reply by email)
