Hi all I would like your tips and help regarding my work. I would be thankful for your help, would some how return it if possible =EF=81=8A :-) . I would like to save time of digging all manuals with the tips from you. Recently I have been deputed on the work of writing driver for transferring data using PCI between BITTWARE PCI- CARD TSPC-425-7. (4 NOS OF ADSP TS101S) AND PMC SITE OF ADC ICS554. ???? can some one give info on what libraries to use specific for bittware board for PCI and PMC interface ???? I have noticed that 1=2E Bittware board has sharcFIN Asic for pci interface. 2=2E its said that dsp21K-sf Toolkit 7.31-7 has HIL and std i/o library . and ?? I guess there should also be some kind of board libraries which can be linked in with VDSP++ ?? 3=2E SharcFIN Developer's Kit and how does it help 4=2E in most of the test files given by the bittware there is mention of Tiger_Libs and TPCI_LIB. where can I get documentation for that. Thanks in anticipation
BittWare's PMC+ I/O BittWare's PMC+ I/O BittWare's PCI + PMC + DMA TRANSFER
Started by ●November 19, 2005
Reply by ●November 19, 20052005-11-19
sorry for appearance of unrelated asic text title in dsprelated. i have posted it from google edited from msword.
Reply by ●November 21, 20052005-11-21
Hi Reddy There are no short cuts when it comes to writing drivers esp. when researching manuals. My recommendation would be to go over the relevant documentation to understand the details of each of the boards involved. From your description, you have atleast 2 boards and a PC involved with multiple chips in the mix. Also, when you say you have been assigned to "writing driver for transferring data using PCI between BITTWARE PCI- CARD TSPC-425-7. (4 NOS OF ADSP TS101S) AND PMC SITE OF ADC ICS554.", I can interpret this in several ways...you need to be clear on what your driver needs to do. - does it need to move data from PMC card to PCI card to PC (run on Windows)? - does it need to move data from PMC card to PCI card only (run on DSP) I'd suggest that you use the dsp21k-toolkit as your starting point. It has a whole bunch of library functions which might just do the job for you - you'll have to write a wrapper based on your specific needs. If this doesn't do it (you'd have to read the documentation in detail before you can figure out if the toolkit won't work for your needs), then I'd suggest you use the developer's kit. At this stage - you are going to need the documentation even more. In short, running away from documentation esp. when you are writing a driver is bad. A good driver is one that pays attention to details. Cheers Bhaskar "PMReddy" <p.manohar.reddy@gmail.com> wrote in message news:1132420063.208573.57660@g49g2000cwa.googlegroups.com... Hi all I would like your tips and help regarding my work. I would be thankful for your help, would some how return it if possible ? :-) . I would like to save time of digging all manuals with the tips from you. Recently I have been deputed on the work of writing driver for transferring data using PCI between BITTWARE PCI- CARD TSPC-425-7. (4 NOS OF ADSP TS101S) AND PMC SITE OF ADC ICS554. ???? can some one give info on what libraries to use specific for bittware board for PCI and PMC interface ???? I have noticed that 1. Bittware board has sharcFIN Asic for pci interface. 2. its said that dsp21K-sf Toolkit 7.31-7 has HIL and std i/o library . and ?? I guess there should also be some kind of board libraries which can be linked in with VDSP++ ?? 3. SharcFIN Developer's Kit and how does it help 4. in most of the test files given by the bittware there is mention of Tiger_Libs and TPCI_LIB. where can I get documentation for that. Thanks in anticipation
Reply by ●November 23, 20052005-11-23
Hi Thanks for replying Last few days I was in to manuals and data sheets. I am basically in to moving data from PMC card to PCI card. 1)I am not able to find any specific command , or how about for finding (probing for ) the pmc card from the pci bittware board. 2)can you pls give some General details of PMC to PCI interface; like how to find address, configuration space details to be set from PCI card. What are the necessary steps to map a device into memory space? Any help appreciated - as well as any other PMC-PCI 'gems'! Regards P M Reddy
