I try to use wavread() function to open/read .wav reference files for AAC (MPEG-2 AAC) compliance test provided by ISO/MPEG (ISO/IEC 13818-4). But I got the error message "Data compression format (Format #65534) is not supported". However, there is no problem for Adobe Audition and Microsoft Windows Media Player to open and play them. I'd appreciate it if anybody could tell me the reason why Matlab cannot open them and the method to fix it. I'm using Matlab Version 7 and release R14.
Why can Matlab wavread() not read AAC .wav reference files?
Started by ●November 23, 2005
Reply by ●November 23, 20052005-11-23
larry_allen_ca@yahoo.com wrote:> I try to use wavread() function to open/read .wav reference files for > AAC (MPEG-2 AAC) compliance test provided by ISO/MPEG (ISO/IEC > 13818-4). But I got the error message "Data compression format (Format > #65534) is not supported". However, there is no problem for Adobe > Audition and Microsoft Windows Media Player to open and play them. I'd > appreciate it if anybody could tell me the reason why Matlab cannot > open them and the method to fix it. I'm using Matlab Version 7 and > release R14. >type help wavread in matlab to find the answer ;) ps: just open it with audition and save as a microsoft pcm wav file
The comments in wavread.m include: "% NOTE: This file reader only supports Microsoft PCM data format." That should be a clue that wavread.m provides only limited capabilities (PCM format) in reading .wav files. The RIFF (.wav) file format provides for many different data compression formats, but wavread.m doesn't handle such formats. The fact that Audition and WMP support AAC is useful, but irrelevant to MATLAB. You'll need to implement AAC decompression yourself or find another MATLAB implementation that does; a quick search of MATLAB Central fails to show any such. Good luck!
I have used the wavread() function hundred times if not thousands of times for several years. But I don't understand why I cannot use it to open MPEG-2 AAC reference compliance test sequences provided by ISO/IEC. Using Audition to save as Microsoft .wav or .pcm is an alternative solution to the problem. But it is not convenient since I'd like to use Matlab script to test hundreds of test sequences.
For my understanding, the RIFF .wav file format is just PCM data plus header (I've generated .wav files using C/C++ code myself). There is no any data compression. What are "different data compression formats"? I'm confused. And I still don't understand why wavread() function cannot open it!
Ah, that's where your understanding is incomplete. PCM is only one of many forms in which audio data may be stored in such a file. Other forms are A-law and mu-law 8-bit logarithmic compression, several ADPCM algorithms, A-law and mu-law 8-bit logarithmic compression, and others. I don't have a comprehensive reference for .WAV file format, but you could start with http://www.sonicspot.com/guide/wavefiles.html, and try googling for others. I don't know for a fact that AAC compression is present, or what kind of compression is used in the files you are attempting to read, but wavread()'s error message results from interpreting the Format (fmt) chunk in the file and finding a compression code (65534) that it can't handle. Perhaps you should seek further information on the file format for those files you wish to use.
larry_allen_ca@yahoo.com wrote:> I have used the wavread() function hundred times if not thousands of > times for several years. But I don't understand why I cannot use it to > open MPEG-2 AAC reference compliance test sequences provided by > ISO/IEC.There has to be code in the function to handle the type. I had to add my own code to wavread() and wavwrite() to get support for single precision IEEE floating point .wav files. The wavread() and wavwrite() functions are there in source form for you to debug and modify to handle the type that you are giving it. That presupposes that you know the format of what you are giving it and can program Matlab. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●December 8, 20052005-12-08
I misspoke when I assumed above that your .WAV file was AAC-compressed. I've recently learned that the symptom you reported, "Data compression format (Format #65534) is not supported", indicates that the file's format is WAVE_FORMAT_EXTENSIBLE, which apparently is a newer format for multi-channel data and data with >16 bits per sample. I don't know all the details, but I've found some info at: http://hul.harvard.edu/jhove/wave-hul.html http://www.ambisonic.net/mulchaud.html The more important information in previous replies, however, stands: wavread()'s capabilities for file format are very limited, and WAVE_FORMAT_EXTENSIBLE is beyond what it can do.
Jerry Wolf wrote:> I misspoke when I assumed above that your .WAV file was AAC-compressed. > I've recently learned that the symptom you reported, "Data compression > format (Format > #65534) is not supported", indicates that the file's format is > WAVE_FORMAT_EXTENSIBLE, which apparently is a newer format for > multi-channel data and data with >16 bits per sample. > > I don't know all the details, but I've found some info at: > http://hul.harvard.edu/jhove/wave-hul.html > http://www.ambisonic.net/mulchaud.html > > The more important information in previous replies, however, stands: > wavread()'s capabilities for file format are very limited, and > WAVE_FORMAT_EXTENSIBLE is beyond what it can do. >Matlab m files to read and write this are available from: http://acoustics.aau.dk/~sc/matlab/wavex.html I have only head about these today, and have yet to try them out. Hopefully they will work in Octave too, which is as close as I can get to matlab! Richard Dobson
