Hello I am working on a speech enhancement algorithm. Part of my algorithm has to do with 10th order LPC-analysis that provides me with the real coefficients [a1,a2,.....,a10] for a 10th order polynomium A(z)=1+a1*(z^-1)+a2*(z^-2)+......+a10*(z^-10) Is there a way to do fast calculation of all the roots of A(z) such that they are written on the complex form x+j*y ?? Thank you in advance...
fastest way of calculating the roots of a polynomium??
Started by ●November 23, 2005
Reply by ●November 23, 20052005-11-23
Why do you want them? If it is to check for stability, that is normally done by checking the reflection coefficients which generated for a lattice filter implementation. Dirk
> Why do you want them? If it is to check for stability, that isIt is not to check for stability....It is because I am more interested in finding the roots than the LPC-coefficients. If I have the roots I can quickly calculate the LPC-coefficients if I want to....so I am looking for a _fast_ way of determining the roots of a 10th order polynomial...I see that matlab solves it as an eigenvalue-problem....Is this the fastest way?
John wrote:>>Why do you want them? If it is to check for stability, that is > > > It is not to check for stability....It is because I am more interested in > finding the roots than the LPC-coefficients. If I have the roots I can > quickly calculate the LPC-coefficients if I want to....so I am looking for a > _fast_ way of determining the roots of a 10th order polynomial...I see that > matlab solves it as an eigenvalue-problem....Is this the fastest way? > > >I have had a course on computerarithmetics, there we used iterative methods to gradually come closer to the root(s) up to some arbitrary small error (by using the output of one iteration as input for the next, and stop when 2 successive iterations differ very little (other stopping conditions may be better but its usable), the fastest algorithm we've seen was the Newton-Raphson method (maybe not the fastest that exists). More numerical algorithms can be found here (maybe not the most complete explanation, but it should get u started): http://mathworld.wolfram.com/topics/Root-Finding.html grtz Emile Vrijdags
John wrote:> > Why do you want them? If it is to check for stability, that is > > It is not to check for stability....It is because I am more interested in > finding the roots than the LPC-coefficients. If I have the roots I can > quickly calculate the LPC-coefficients if I want to....so I am looking for a > _fast_ way of determining the roots of a 10th order polynomial...I see that > matlab solves it as an eigenvalue-problem....Is this the fastest way?I have solved roots in polynomials by using Laguerre's method. It works reasonably well for 5th order polynomials, but requires a fair amount of fiddling to obtain a stable, robust method. Before embarking on implementing such a routine, you should consider why you want these roots. Do you *really* need them? Having spent a bit of time with these things recently, I find it hard to justify the effort without a very compelling reason. For the record: The reason why I did these things was that I wanted to represent IIR bandpass and bandstop filters as a sequence of 2nd order sections. I am still debugging the routines, three months after I started to implement them. Rune
In article <43847dd4$0$67257$157c6196@dreader2.cybercity.dk>, "John" <johnjohn@sucker.com> writes:>> Why do you want them? If it is to check for stability, that is > >It is not to check for stability....It is because I am more interested in >finding the roots than the LPC-coefficients. If I have the roots I can >quickly calculate the LPC-coefficients if I want to....so I am looking for a >_fast_ way of determining the roots of a 10th order polynomial...I see that >matlab solves it as an eigenvalue-problem....Is this the fastest way?Just went to a talk by Ron Shafer last night, and he talked about the problem of finding roots of very high degree polynomials (up to order 1 million) using a technique published in "Factoring Very High Degree Polynomials," IEEE Signal Processing Magazine, November 2003. You can get more info at http://www-dsp.rice.edu/software/fvhdp.shtml Regards, Karl Molnar
John wrote:>> Why do you want them? If it is to check for stability, that is > > It is not to check for stability....It is because I am more interested in > finding the roots than the LPC-coefficients. If I have the roots I can > quickly calculate the LPC-coefficients if I want to....so I am looking for a > _fast_ way of determining the roots of a 10th order polynomial...I see that > matlab solves it as an eigenvalue-problem....Is this the fastest way?No. See: http://www.dsp.rice.edu/software/fvhdp.shtml Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
In article <1132777446.921670.252430@o13g2000cwo.googlegroups.com>, "Randy Yates" <yates@ieee.org> writes:>Karl, > >I'm sorry I missed him. Was it a good meeting? > >--Randy >Randy, It was interesting - he spoke about the history and application of the cepstrum. As an added bonus, we also met Jim Kaiser. Karl
