Hi, The autocorrelation of a signal X is generally bell-shaped with maximum value at the middle. I am just wondering, from what a threshold value we can assume practically that the signal autocorrelation is null? Assume that the maximum value of the autocorrelation is M. if the threshold cited above is equal to Per*M (where Per stands for percentage or ratio), then by identifying the x label at Per*M autocorrelation value a user can identify to what temporal shift, the signal samples can still be correlated Many thanks
Correlation Threshold Meaningful Value
Started by ●November 24, 2005
Reply by ●November 24, 20052005-11-24
newsnetstudent wrote:> Hi, > > The autocorrelation of a signal X is generally bell-shaped with maximum > value at the middle. I am just wondering, from what a threshold value we > can assume practically that the signal autocorrelation is null? > > Assume that the maximum value of the autocorrelation is M. if the > threshold cited above is equal to Per*M (where Per stands for percentage > or ratio), then by identifying the x label at Per*M autocorrelation value > a user can identify to what temporal shift, the signal samples can still > be correlatedThe shape of the autocorrelation vs. delay depends on the nature if the signal. It is cyclic with pure sinusoids and a spike with random (or long pseudorandom) sequences. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●November 25, 20052005-11-25
Jerry Avins wrote:> newsnetstudent wrote: > >> Hi, >> >> The autocorrelation of a signal X is generally bell-shaped with maximum >> value at the middle. I am just wondering, from what a threshold value we >> can assume practically that the signal autocorrelation is null? >> >> Assume that the maximum value of the autocorrelation is M. if the >> threshold cited above is equal to Per*M (where Per stands for percentage >> or ratio), then by identifying the x label at Per*M autocorrelation value >> a user can identify to what temporal shift, the signal samples can still >> be correlated > > > The shape of the autocorrelation vs. delay depends on the nature if the > signal. It is cyclic with pure sinusoids and a spike with random (or > long pseudorandom) sequences. > > JerryAnd it is "practically" null when it has less energy than your particular problem is sensitive to -- if you're trying to do communications this may be 10% of full value; if you're doing exceedingly sensitive measurements this may not occur until you're below 1 PPM. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
newsnetstudent wrote:> Hi, > > The autocorrelation of a signal X is generally bell-shaped with maximum > value at the middle. I am just wondering, from what a threshold value we > can assume practically that the signal autocorrelation is null? > > Assume that the maximum value of the autocorrelation is M. if the > threshold cited above is equal to Per*M (where Per stands for percentage > or ratio), then by identifying the x label at Per*M autocorrelation value > a user can identify to what temporal shift, the signal samples can still > be correlated > > Many thanksIn most practical situations the measured data will be contaminated by noise, which is more or less correlated with the signal. I know, all texts on statistical signal processing tell you that the contribution from the noise is a delta function, but that's the "true" autocorrelation sequence developed under quite strict theoretical conditions. In practice there will be a noise floor when you deal with measured data. Now, under these *practical* conditions I would try to find an estimate for the noise floor in the correlation sequence, and relate the threshold to that. Note that it might not be easy (or possible) to inspect the autocorrelation sequence to find that noise floor. Even if you find it, it needs not be easy to set a useful threshold. So you basically have to evalueat each situation/data set to determine how to set the correlation threshold. I know, it sounds a bit defaitistic, but these types of *subjective* evaluations occur all the time during data interpretation. That's why it is called data *interpretation*. Rune
