Hello I'm having some problems to make my code running on 2 x TS203 rev 1.2 and VisualDSP 4.0. My small code toggles FLAG0 output pin, here are my results : 1- When simulating using TS203 : OK : I can see register FLAGREG toggling according to the code. 2- When running on TS201 eval board with the same code (via JTAG) : OK : I can see both register FLAGREG and FLAG0 pin toggling according to the code. 3- When running on TS203 own board with the same code (via JTAG) : I cannot see the register FLAGREG nor FLAG0 pin toggling according to the code. The step by step debugger works fine, as well as the SDRAM (I performed successive write/read), but I cannot see the pin toggling, nor the register FLAGREG. FLAGREG is supposed to be 0000 at reset, I read FFFF once the code is transfered to the DSP via JTAG !? 4- I performed another test using TS201 processors in VisualDSP while my board features TS203. In this case I can see the register FLAGREG properly toggling but not the TS203 pin. It sounds like it is a VisualDSP registers definition for TS203 which does not match the real TS203 registers. Here is my small test code, working fine on TS201 eval board, as well as when simulating on TS203 : #include <defts203.h> #include <sysreg.h> #include <builtins.h> #define SET_FLAG(x) asm("FLAGREGST=%0;;"::"y"(x)) #define CLR_FLAG(x) asm("FLAGREGCL=%0;;"::"y"(x)) void main(void){ int i; SET_FLAG(FLAGREG_FLAG0_EN); while(1) { SET_FLAG(FLAGREG_FLAG0_OUT); for(i=0;i<10;i++); CLR_FLAG(~FLAGREG_FLAG0_OUT); for(i=0;i<10;i++); } } /* end main */ Please note I changed the following in the ADSP-TS203.xml file : I had to modify the syscon default value <Register Name="SYSCON" ResetValue="0x00009067" Core="Common" /> instead of <Register Name="SYSCON" ResetValue="0x00189067" Core="Common" /> because of the 32bits bus and not 64 (otherwise I can see only even address working), now odd/even address are ok on the sdram Any help would be greatly appreciated Jerome
Tigersharc TS203 and visualDSP 4 issue
Started by ●November 28, 2005
Reply by ●November 29, 20052005-11-29
jerome0613 wrote:> It sounds like it is a VisualDSP registers definition for TS203 which does > not match the real TS203 registers.Compare the defts203.h file to the TS203 user manual (or hardware reference manual, I can never remember which one defines the regs). If that looks good, take a look at the generated assembly code and see if it's doing what you think it should be doing. How are you looking at the flags when the system is running? -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Nothing is ever so bad that it can't get worse. - Calvin
I'm looking the flag outputs using a scope. It works now ... ! There was a confusion between DSPs IDs (0 and 1) and Device IDs in VisualDSP which seems to be JTAG IDs (1 and 0) ... I was looking flag on DSP0 instead of DSP1.>jerome0613 wrote: >> It sounds like it is a VisualDSP registers definition for TS203 whichdoes>> not match the real TS203 registers. > >Compare the defts203.h file to the TS203 user manual (or hardware >reference manual, I can never remember which one defines the regs). If >that looks good, take a look at the generated assembly code and see if >it's doing what you think it should be doing. > >How are you looking at the flags when the system is running? > >-- >Jim Thomas Principal Applications Engineer Bittware, Inc >jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 >Nothing is ever so bad that it can't get worse. - Calvin >
jerome0613 wrote:> I'm looking the flag outputs using a scope. > > It works now ... !Thanks for letting everyone know. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
