Hi How many data points does Spline and Cubic interpolation take to calculate a point?
Spline Interpolation and cubic interpolation
Started by ●November 29, 2005
Reply by ●November 29, 20052005-11-29
for 3rd order polynomial interpolation, it's usually 4 data points (and you're interpolating between the inner two data points). there are many different interpolation polynomials, even for a given order (such as 3). Lagrange interpolation will fit an Nth order polynomial through N+1 adjacent data points, and assuming that N+1 is even and we start counting the data points from "0" to "N", the interpolation is used for the space between data points (N-1)/2 to (N+1)/2. Hermite polynomial interpolation will fit an Nth order polynomial only to the two adjacent data points at indices (N-1)/2 to (N+1)/2, but will also match as many derivatives as possible at those two adjacent data points with the interpolation polynomials that go through those neighbors and *their* neighbors. that means that these derivatives of the Nth order Hermite at the (N-1)/2 point can only depend on data points 0 to N-1 and the derivatives at the (N+1)/2 point can only depend on data points 1 to N (and must be the same function of those N points). a 3rd order Hermite interpolation polynomial will match the 0th and 1st derivative at the 1st and 2nd point. the value of the polynomial (the "0th derivative") at x[1] *is* x[1] and the value of the 1st derivative at x[1] is (x[2]-x[0])/2 (assuming uniform spacing). similarly, the value of the polynomial (the "0th derivative") at x[2] is x[2] and the value of the 1st derivative at x[2] is (x[3]-x[1])/2. that way, both the polynomial value *and* slope matches the polynomial and slope of the neighboring interpolations. there are more (such as B-splines), but, for the most part, you need 4 points for 3rd order polynomial interpolation. r b-j
robert bristow-johnson wrote:> for 3rd order polynomial interpolation, it's usually 4 data points (and > you're interpolating between the inner two data points)....> a 3rd order Hermite interpolation polynomial will match the 0th and 1st > derivative at the 1st and 2nd point.This is for symmetric interpolation. At or beyond the ends of data sets, one could also try asymmetric or single ended interpolation polynomials: for instance, matching the 0th derivative at the left end and the 0th, 1st and 2nd at the right end of a segment; or even matching nothing at the left end, and the 0th thru 3rd derivative at the right end. I find this possibly useful at the ends of data sets instead of symmetric (linear phase windowed sinc, etc.) interpolation, especially when the assumption that the "real" phenomena is approximately continuous in several derivatives at or around the ends of the data set to be a more realistic assumption than that the phenomena is zero, reflected, repeated or cyclic. IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
Ron N. wrote:> robert bristow-johnson wrote: > > for 3rd order polynomial interpolation, it's usually 4 data points (and > > you're interpolating between the inner two data points). > ... > > a 3rd order Hermite interpolation polynomial will match the 0th and 1st > > derivative at the 1st and 2nd point. > > This is for symmetric interpolation.... yes, true. my preconceptions stem from doing this on audio signals and normally i expect this symmetry (or reversibility - the interpolation should work just the same if you played the audio backwards) to be sorta normative. but, you're right, it doesn't have to be. r b-j
