On Fri, 30 Jul 2004 13:17:06 -0700, "Jon Harris" <goldentully@hotmail.com> wrote:>"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message >news:10gkscd310g4q40@corp.supernews.com... >> Peter Choi wrote:[snip DSP-FPGA comparison] My last product had a large FPGA to do some heavy grunt high speed datapath work. It also does some light-weight DSP work ... with a small risc microprocessor implemented inside the same FPGA. :) Regards, Allan.
DSP vs Firmware
Started by ●July 29, 2004
Reply by ●July 31, 20042004-07-31
Fred Marshall wrote:> "Jon Harris" <goldentully@hotmail.com> wrote in message > news:2mvo7uFrdqosU1@uni-berlin.de... > >>"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message >>news:10gkscd310g4q40@corp.supernews.com... >> >>The places where FPGAs do seem to get used for DSP are in very high sample > > rate > >>applications, where traditional DSPs just aren't fast enough (e.g. RF). > > In this > >>case, the data width is usually quite small as well, which decreases the >>required FPGA logic, and the algorithms are often simple, like a static > > FIR > >>filter. > > > Also in video processing ..... where the two approaches tend to compete a > bit more. If there are complex algorithms involved then a high-powered DSP > might be indicated. Otherwise, a lot of video can nicely be done in an > FPGA. > > Come to think of it, I don't hear much about the TMS320C6000 series here in > comp.dsp. Any experience here? > > 66MHz FPGA designs do well in video applications and have likely gone up in > speed in the last 5 years since we were doing those designs. > > I'm not familiar with the applications of FPGAs in cell phones .... but I'm > pretty sure that the big FPGAs wouldn't fit! > > Fred > >Speeds have gone up. FPGA's do very nicely in custom imager applications where you need DSP-lite and lots of shoving data around -- the application that I'm thinking of has two separate SDRAM banks to achieve the necessary speed; you may be able to do this with pairs of DSP chips, but it'd be slightly ridiculous. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●August 8, 20042004-08-08
"Peter Choi" <choi@mecca.ca> wrote in message news:6UsOc.137453$Mr4.108053@pd7tw1no...> Hello, > > Oh I didn't know FPGA uses more power than a DSP. I thought FPGA woulduse> less since you build only the necessary logic for it.Most of the current fpga's are sram. Newer generations use less power. Have a read of the datasheets for fpgas and dsp chips for min and max power use. Also fpga's can't unlike some dsp's / mcu's turn parts of themselves off or hibernate etc if you require very low power use. This may be of interest, it does come from a dsp vendor though. http://focus.ti.com/lit/an/spra879/spra879.pdf or http://64.233.161.104/search?q=cache:PrqtozvFQAQJ:focus.ti.com/lit/an/spra879/spra879.pdf+choosing+DSP+FPGA+ASIC&hl=en http://www.eetuk.com/bus/news/OEG20040426S0012 Other things can get some pretty high speed dsps - 1GHz unless your design is highly parallel its more likely to be faster on a dsp than a fpga Have a try at doing a design on both dsp and fpgas. Can get dsp eval boards from the chip manufacturers and others http://www.analog.com/processors/index.html http://dspvillage.ti.com/docs/dspvillagehome.jhtml freescale (was motorola) http://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=012795 If you want an fpga board to test on xilinx has a spartan3 starters kit for US$99 http://www.xilinx.com/products/spartan3/s3boards.htm A useful tool for generating digital filters for fpgas is http://www.winfilter.20m.com/ still need to know vhdl(also does some nice plots) Alex
