I have to design a simple low pass filter (for audio) to reject frequencies beyond 3.6kHz. The design of the filter is quite simple. However, I want to know what affect the sampling frequency of the audio will have on such a filter design. In other words, I can sample at 16kHz, filter the data and downsample to 8kHz (which is finally the sampling rate I want) OR I can sample at 8kHz and filter the data. (This will save me precious MIPS, which I am in great need of). I want to know what I am losing (if anything at all) if I sample at 8kHz instead of 16kHz. Bear in mind that this is audio (voice) data I am talking about, so I am not interested in frequencies above say 3.8kHz. Regards, Tanmay.
Filter design.
Started by ●December 1, 2005
Reply by ●December 1, 20052005-12-01
tanmay.zargar@gmail.com wrote:> I have to design a simple low pass filter (for audio) to reject > frequencies beyond 3.6kHz. The design of the filter is quite simple. > However, I want to know what affect the sampling frequency of the audio > will have on such a filter design. > > In other words, I can sample at 16kHz, filter the data and downsample > to 8kHz (which is finally the sampling rate I want) OR I can sample at > 8kHz and filter the data. (This will save me precious MIPS, which I am > in great need of). I want to know what I am losing (if anything at all) > if I sample at 8kHz instead of 16kHz. Bear in mind that this is audio > (voice) data I am talking about, so I am not interested in frequencies > above say 3.8kHz.There's a lot of voice information above 3.8 KHz, which is why it's easier to understand someone in person than over a telephone. To sample at 8KHz, you need an analog filter that removes /everything/ above 4KHz from the analog signal. It's easier to start rolling off below that, so you will sensibly do all the filtering with an analog filter (Switched capacitor chip?). Your other option is sloppier analog filtering, a higher sample rate at the outset, digital filtering, and decimation. There are more and less efficient ways to do that, and sampling originally at 24 or 32 KHz may be not much more compute intensive than 16 when you chose the efficient way. An upgraded processor may be cheaper than an added filter chip. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Hello Jerry,> There's a lot of voice information above 3.8 KHz, which is why it's > easier to understand someone in person than over a telephone. >I had good friends calling in on cell phones and I couldn't even recognize who was talking.> To sample at 8KHz, you need an analog filter that removes /everything/ > above 4KHz from the analog signal. It's easier to start rolling off > below that, so you will sensibly do all the filtering with an analog > filter (Switched capacitor chip?). ...Switched cap filters kind of fell from grace, too expensive. My take is that the industry tried too much skimming of the top tier. That kept prices high and many people shunned them. I used them in only one industrial design but only because I had no other choice. Doing this steep of an audio cut-off almost requires up-conversion to a few MHz, crystal filter, then back down to baseband. No big deal but the crystal filter will cost.> ... Your other option is sloppier analog > filtering, a higher sample rate at the outset, digital filtering, and > decimation. There are more and less efficient ways to do that, and > sampling originally at 24 or 32 KHz may be not much more compute > intensive than 16 when you chose the efficient way. > > An upgraded processor may be cheaper than an added filter chip. >That's what I would try as well. Regards, Joerg http://www.analogconsultants.com
Jerry, Admittedly this reference is old (Digital Telephony by Bellamy, 1982), but the analog filter template to meet then current CCITT recommendations for analog filtering prior to PCM voice coders had only 14 dB of attenuation at 4KHz for 8KHz sampling (attenuation relative to 0 dB at DC). I guess practicality got in the way of theory. Dirk Jerry Avins wrote: <clipped>> > To sample at 8KHz, you need an analog filter that removes /everything/ > above 4KHz from the analog signal. It's easier to start rolling off > below that, so you will sensibly do all the filtering with an analog > filter (Switched capacitor chip?). Your other option is sloppier analog > filtering, a higher sample rate at the outset, digital filtering, and > decimation. There are more and less efficient ways to do that, and > sampling originally at 24 or 32 KHz may be not much more compute > intensive than 16 when you chose the efficient way. > > An upgraded processor may be cheaper than an added filter chip. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF==AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
dbell wrote:> Jerry, > > Admittedly this reference is old (Digital Telephony by Bellamy, 1982), > but the analog filter template to meet then current CCITT > recommendations for analog filtering prior to PCM voice coders had only > 14 dB of attenuation at 4KHz for 8KHz sampling (attenuation relative to > 0 dB at DC). > > I guess practicality got in the way of theory. > > DirkThe theory of good enough is much more complex than the theory of perfection. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●December 2, 20052005-12-02
Remember that the non-linearity of A-law and u-law compression limits the instantaneous signal to noise on the telephone network to about 30dB. 14dB of attenuation, added to the filtering of higher frequencies usually occuring in telephone networks for other reasons, generally proves adequate to keep the overall mess due to aliasing down in the noise. It would take a signal with masses of energy above 4kHz and little below 4kHz to cause the aliases to show up badly. The spectrum of speech is never like that. Regards, Steve dbell wrote:>Jerry, > >Admittedly this reference is old (Digital Telephony by Bellamy, 1982), >but the analog filter template to meet then current CCITT >recommendations for analog filtering prior to PCM voice coders had only >14 dB of attenuation at 4KHz for 8KHz sampling (attenuation relative to >0 dB at DC). > >I guess practicality got in the way of theory. > >Dirk > > >Jerry Avins wrote: > ><clipped> > > >>To sample at 8KHz, you need an analog filter that removes /everything/ >>above 4KHz from the analog signal. It's easier to start rolling off >>below that, so you will sensibly do all the filtering with an analog >>filter (Switched capacitor chip?). Your other option is sloppier analog >>filtering, a higher sample rate at the outset, digital filtering, and >>decimation. There are more and less efficient ways to do that, and >>sampling originally at 24 or 32 KHz may be not much more compute >>intensive than 16 when you chose the efficient way. >> >>An upgraded processor may be cheaper than an added filter chip. >> >>Jerry >>-- >>Engineering is the art of making what you want from things you can get. >>����������������������������������������������������������������������� >> >> > > >
Jerry Avins wrote:> To sample at 8KHz, you need an analog filter that removes /everything/ > above 4KHz from the analog signal. It's easier to start rolling off > below that, so you will sensibly do all the filtering with an analog > filter (Switched capacitor chip?). Your other option is sloppier analog > filtering, a higher sample rate at the outset, digital filtering, and > decimation. There are more and less efficient ways to do that, and > sampling originally at 24 or 32 KHz may be not much more compute > intensive than 16 when you chose the efficient way.The efficient way Jerry's talking about here is "don't calculate filter output samples you're going to discard." This is easy with a FIR. Your analog anti-aliasing filter can start rolling off at 3.6KHz even if you sample at 16K (or higher). That'll get you a little more rejection than if the analog filter were to start rolling off at Nyquist. There's a pretty good tutorial on decimating filters (aka multi-rate filter) on http://dspguru.com - check the FAQ section. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 When you know how things work, the world is one big sandbox. - Avins
On the system that I am working with right now, I cannot afford to sample at 16kHz (in fact any frequency higher than 8kHz) since I am running out of MIPS. So I HAVE to sample at 8kHz and sadly I do not have very good analog pre-filtering for this sampling rate. Change of processor/clock rates/bus speeds is also not an option. Now I know that there is going to be 'some' energy in the signal at frequencies higher than 4kHz before sampling it (at 8kHz). This energy at frequencies higher than 4kHz will cause aliasing after sampling. I have implemented a simple first-order Butterworth low pass filter with a cut off of 3.6kHz. I don't think that this filter will help since the aliasing damage is already done. I just need to figure out how much the damage is. Is there a way to measure the distortion due to aliasing (say by viewing the spectrum of the signal before sampling)?
<tanmay.zargar@gmail.com> wrote in message news:1133541474.384256.324670@g43g2000cwa.googlegroups.com... ......Is there a way to measure the distortion due to aliasing> (say by viewing the spectrum of the signal before sampling)? >Listening to the result is good. Otherwise, you should be able to calculate it in some limited sense. Example: A sinusoid at 3kHz, a sinusoid at 4.5kHz and a sinusoid at 7kHz all of equal amplitude with sampling at 8kHz. The 4.5kHz will fold into 3.5kHz, the 7kHz will fold into 1kHz. With no filtering, they will still have equal amplitudes. With filtering, they will have different amplitudes that you can compute. Then, you might express the result in terms of sort of a signal to noise ratio if that suits you. But, how are you going to judge whether one number is OK and another is not OK? Listening perhaps? Fred
tanmay.zargar@gmail.com wrote: ...> I have implemented a simple first-order Butterworth low pass filter with > a cut off of 3.6kHz.A single chip will get you a 4th order filter: http://www.national.com/ds/LM/LMF100.pdf> I don't think that this filter will help since the > aliasing damage is already done. I just need to figure out how much the > damage is. Is there a way to measure the distortion due to aliasing > (say by viewing the spectrum of the signal before sampling)?Where is the filter? There is no damage while the signal is still analog. There is no help if the filter comes after. An anti-alias filter doesn't remove aliases; it removes components that would become aliases if allowed to remain. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
