Does anyone know of a C/C++ library for taking an audio file and performing a speed change without changing the pitch? Thanks, Jeff Dodson
Speed Change without Pitch Change
Started by ●December 4, 2005
Reply by ●December 4, 20052005-12-04
> Does anyone know of a C/C++ library for taking an audio file and > performing a speed change without changing the pitch? >Jeff, The simple way to do it is just to repeat or cut out the small chunks of data depending if you are going faster or slower respectively. Divide your file into the frames of ~10ms long and operate frame by frame. A better way for doing the speed change is the same method however the signal is split into frq. subbands and each subband is processed separately. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
jeffdod wrote:> Does anyone know of a C/C++ library for taking an audio file and > performing a speed change without changing the pitch? > > Thanks, > > Jeff Dodsonlibsoundtouch (C++) springs to mind as one option, but there are others. Regards, Dan.
jeffdod wrote:> Does anyone know of a C/C++ library for taking an audio file and > performing a speed change without changing the pitch? > > Thanks, > > Jeff DodsonLook on http://www.dspdimension.com/ Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
