Hello, I have built a board with TMS320R2811 on it. When I power it up oscillator works, and on RS pin I can see the watchdog reset as it is supposed to, so I assume that the core is alive. But I can not communicate with the DSP, through JTAG with XDS510PP+. I connected all the JTAG pins as they are supposed to (according to ezDSP R2812 schematics). I had no problems with my previous boards with 24xx DSP's on them. I have checked all connections and they are fine. Has anyone experienced similar problem? Mitja
TMS320R2811 JTAG communication
Started by ●December 7, 2005
Reply by ●December 7, 20052005-12-07
Issues with the XDS51PP emulator seem to be quite common from the number of times the subject appears to have come up. Try searching the archives of this group and also on TI's discussion groups. You will probably find a number of ideas and suggestions to try.
Reply by ●December 8, 20052005-12-08
On 6 Dec 2005 23:00:44 -0800, "Korenje" <korenje@yahoo.co.uk> wrote in comp.arch.embedded:> Hello, > > I have built a board with TMS320R2811 on it. When I power it up > oscillator works, and on RS pin I can see the watchdog reset as it is > supposed to, so I assume that the core is alive. But I can not > communicate with the DSP, through JTAG with XDS510PP+. I connected all > the JTAG pins as they are supposed to (according to ezDSP R2812 > schematics). I had no problems with my previous boards with 24xx DSP's > on them. I have checked all connections and they are fine. > Has anyone experienced similar problem? > > MitjaAre you powering the debugger with the separate wall wart, or are you depending on power being supplied from the JTAG header on the board? There is a mistake that is easy to make. The XDS510PP+ can be powered directly from the target board if and only if the board provides +5 volts on the JTAG header power pin. If you have 3.3 volts on the JTAG power pin, the debugger uses it to detect power on in the target, but can't run from it, and needs the plug-in supply. We made that mistake on the first spin of our first 2812 board, and it was quite a nuisance. We fixed it on the second spin. Fortunately we had a 5 volt supply on the board. -- Jack Klein Home: http://JK-Technology.Com FAQs for comp.lang.c http://www.eskimo.com/~scs/C-faq/top.html comp.lang.c++ http://www.parashift.com/c++-faq-lite/ alt.comp.lang.learn.c-c++ http://www.contrib.andrew.cmu.edu/~ajo/docs/FAQ-acllc.html
Thank you both for advice. Jack, I did route +5V to PD pin, though I admit it is probably very common mistake. I learned that by myself on earlier 24xx boards. Since I have check everything at least three times I am going to assume, that the one of the DSP's JTAG pins is faulty (maybe more), and I am going to replace the DSP. I just had to be sure that no one else experienced similar problem, since this is my first board with 28xx device. Thanks again Mitja
Reply by ●December 10, 20052005-12-10
On 8 Dec 2005 04:49:28 -0800, "korenje" <korenje@yahoo.co.uk> wrote in comp.dsp:> Thank you both for advice. > > Jack, I did route +5V to PD pin, though I admit it is probably very > common mistake. I learned that by myself on earlier 24xx boards. > > Since I have check everything at least three times I am going to > assume, that the one of the DSP's JTAG pins is faulty (maybe more), and > I am going to replace the DSP. > > I just had to be sure that no one else experienced similar problem, > since this is my first board with 28xx device. > > Thanks again > > MitjaDoes your board have an external watchdog circuit? Ours does, because it is in a safety critical device (medical). Without one, a single point failure such as a solder connection to the crystal stops both the DSP and the internal watchdog. If you do have an external watchdog, you must disable it somehow when using the JTAG. -- Jack Klein Home: http://JK-Technology.Com FAQs for comp.lang.c http://www.eskimo.com/~scs/C-faq/top.html comp.lang.c++ http://www.parashift.com/c++-faq-lite/ alt.comp.lang.learn.c-c++ http://www.contrib.andrew.cmu.edu/~ajo/docs/FAQ-acllc.html
