It suddenly happened that my DM642 board failed to run to the main(). While debugging, I found that c_int00 can't pass some assembly codes, which is to wait for the reset complete of VP1. I checked the register VP1_CTL, and found that VPRST field is 1, which means it can't finish the power on reset. but both VP0 and VP2 are OK, seeing their control registers. Does anyone know why?
trapped in the c_int00
Started by ●December 7, 2005
Reply by ●December 7, 20052005-12-07
Well you could obviously have a bad part. There also might be a conflict with the reset logic if you had some external drive on the video port control signals. I'd check those signals and see if something's driving them. Otherwise I'd say your part is dead. --RY
Reply by ●December 8, 20052005-12-08
Randy Yates wrote:> > be a conflict with the reset logic if you had some external > drive on the video port control signals. I'd check those > signals and see if something's driving them.I had that problem when trying to use a Conexant decoder with the video port. Essentially, the video port wouldn't come out of reset until I'd properly programmed the decoder. It seems Philips and TI decoders come out of reset into some sensible default state, but Conexant decoders enter a standby state with outputs tri-stated. If a previously working system has failed, then it could be a dodgy decoder, or maybe the decoder has got itself into a funny mode? hmq - you say that the program gets past the C entry point, but doesn't reach main(). I'm guessing that it stopping in the mdBindDev for your video port driver, in which case you will probably have source code for it, which might make debugging easier. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
