Hello All! I obtained a matlab code which do the zero forcing equalization on an awgn channel, and plots the BER vs. SNR Please look at this small code if it is correct, my question is: where are the filter coefficients here or how can I obtain this, as I don't see them ??? Thanks for you effort, Reno N: number of symbols we transmit h: impulse response snrDB: SNR in dB, actually: snrdB_min = 1; snrdB_max = 10; snrdB = snrdB_min:1:snrdB_max; ----- function z = zf(N,h,snrdB) lg=length(h); y=sign(randn(1,N)); sk=filter(h,1,y); snr=10.^(snrdB/10); nu=normrnd(0,(1/sqrt(snr)),1,N); x=sk+nu; ykegalZF=filter(1,h,x); aklinZF=sign(ykegalZF(1:N)); PelinZF=sum(abs(y-aklinZF)/2); errorZF=PelinZF/N; %semilogy(RSBdB, PelinZF,'r*'); hold on; -------
Zero forcing EQ question
Started by ●December 8, 2005
Reply by ●December 9, 20052005-12-09
"August Reno" <a_reno@tiscali.it> wrote in message news:dna3i9$5d0$1@namru.matavnet.hu...> Hello All! > I obtained a matlab code which do the zero forcing equalization on > an awgn channel, and plots the BER vs. SNR > Please look at this small code if it is correct, my question is: > where are the filter coefficients here or how can I obtain this, as I > don't see them ??? > Thanks for you effort, > Reno > > > N: number of symbols we transmit > h: impulse response > snrDB: SNR in dB, actually: > snrdB_min = 1; snrdB_max = 10; > snrdB = snrdB_min:1:snrdB_max; > ----- > > function z = zf(N,h,snrdB) > > lg=length(h); > y=sign(randn(1,N)); > sk=filter(h,1,y); > snr=10.^(snrdB/10); > > nu=normrnd(0,(1/sqrt(snr)),1,N); > x=sk+nu; > ykegalZF=filter(1,h,x); > aklinZF=sign(ykegalZF(1:N)); > PelinZF=sum(abs(y-aklinZF)/2); > errorZF=PelinZF/N; > > %semilogy(RSBdB, PelinZF,'r*'); hold on;Just read the definition for "filter" and you'll see how the coefficients are used. The coefficients are "h" and are *inputs* to the function..... Fred
Thank you I figured it out! August "Fred Marshall" <fmarshallx@remove_the_x.acm.org> az al�bbiakat �rta a k�vetkez� h�r�zenetben: QrmdnfzrdvW0mgTenZ2dnUVZ_tudnZ2d@centurytel.net...> > "August Reno" <a_reno@tiscali.it> wrote in message > news:dna3i9$5d0$1@namru.matavnet.hu... >> Hello All! >> I obtained a matlab code which do the zero forcing equalization on >> an awgn channel, and plots the BER vs. SNR >> Please look at this small code if it is correct, my question is: >> where are the filter coefficients here or how can I obtain this, as I >> don't see them ??? >> Thanks for you effort, >> Reno >> >> >> N: number of symbols we transmit >> h: impulse response >> snrDB: SNR in dB, actually: >> snrdB_min = 1; snrdB_max = 10; >> snrdB = snrdB_min:1:snrdB_max; >> ----- >> >> function z = zf(N,h,snrdB) >> >> lg=length(h); >> y=sign(randn(1,N)); >> sk=filter(h,1,y); >> snr=10.^(snrdB/10); >> >> nu=normrnd(0,(1/sqrt(snr)),1,N); >> x=sk+nu; >> ykegalZF=filter(1,h,x); >> aklinZF=sign(ykegalZF(1:N)); >> PelinZF=sum(abs(y-aklinZF)/2); >> errorZF=PelinZF/N; >> >> %semilogy(RSBdB, PelinZF,'r*'); hold on; > > Just read the definition for "filter" and you'll see how the coefficients > are used. > The coefficients are "h" and are *inputs* to the function..... > > Fred >
