I am trying to implement a multiple antenna (16 channels) beamforming system with 2.6GHz carrier freq. To capture the phase difference between channels, I need to downconvert the 2.6GHz RF to complex baseband using some I/Q mixers. I found out (from Marki) that a 2.6GHz I/Q mixer costs over $150, which is way above my budget limit... I wonder if there is any trick to avoid having mulitple mixers for such case? CJLam
Implement Beamforming at 2.6 GHz
Started by ●December 12, 2005
Reply by ●December 13, 20052005-12-13
clam wrote:> I am trying to implement a multiple antenna (16 channels) beamforming > system with 2.6GHz carrier freq. To capture the phase difference between > channels, I need to downconvert the 2.6GHz RF to complex baseband using > some I/Q mixers. I found out (from Marki) that a 2.6GHz I/Q mixer costs > over $150, which is way above my budget limit... I wonder if there is any > trick to avoid having mulitple mixers for such case?Check these: http://www.analog.com/en/prod/0,2877,ADL5350,00.html http://www.linear.com/pc/downloadDocument.do?navId=D7908 http://www.minicircuits.com/mixer.shtml Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
