"Bevan Weiss" <kaizen__@NOSPAM.hotmail.com> wrote in message news:NAtnf.7796$vH5.389817@news.xtra.co.nz...> clam wrote: >> I am trying to implement a multiple antenna (16 channels) beamforming >> system with 2.6GHz carrier freq. To capture the phase difference between >> channels, I need to downconvert the 2.6GHz RF to complex baseband using >> some I/Q mixers. I found out (from Marki) that a 2.6GHz I/Q mixer costs >> over $150, which is way above my budget limit... I wonder if there is any >> trick to avoid having mulitple mixers for such case? >> >> CJLam > > You need multiple baseband signals, as passband is simply too high speed > to deal with in any simple manner. > This means you must have however many mixers as you require baseband > signals, and each LO must be the same (or at least have some very well > defined phase offset from each other such that you can compensate for it > in the baseband processing). > You can surely find mixers for 2.4GHz cheaper than $150, is there anything > special about the mixer you need?Or you could do the beamforming in r.f. then you just need a bunch of spliiters, phase shifters, (variable gain amps or attenuators maybe) and combiners and only downconvert the beam outputs you need. 2.6 GHz isn't terribly critical for microstrip tolerances - why not build your own? Best of luck - Mike
Re: Implement Beamforming at 2.6 GHz
Started by ●December 13, 2005
