Hi. I need to calculate the cepstrum of a signal. I understand that the cepstrum of a signal is the fourier transform of the log of the fourier transform of a signal. I can easily calculate each of these operations individually, using the fftw3 library. However I have to unwrap the phase of the first FT, and I don't yet know how to do this. Can anyone either (i) point me in the direction of a freely available cepstrum calculating library, or phase unwrapping library usable on Linux, or (ii) convince me that phase unwrapping of a fourier transform of a signal is easy and with a bit of study I'll have no trouble doing it? Cheers, Ross-c
Code for cepstrum
Started by ●December 14, 2005
Reply by ●December 14, 20052005-12-14
Ross -- it's the complex cepstrum that you need, right? I ask because "cepstrum" is commonly used to refer to the FT of the log of the power spectrum, which is a bit simpler to compute -- no phase involved. cheers, jerry wolf
Thanks for the answer. (i) Hmmm..... I have to review some sources on the use of the cepstrum in pitch detection before I can say whether I need the complex cepstrum or not. The only source I have within arm's reach is Hess's 1983 book on Pitch Detection. This sort of suggests that the FT of the log of the power spectrum is what is used. However I'm confused in that the Wikipedia article on the cepstrum says that the cepstrum is the FT of the log of the FT, and that it is a common mistake to claim that the cepstrum is the *INVERSE* FT of the log of the FT. Hess describes the cepstrum as being the INVERSE FT of the power spectrum. So, I need to look into this further. But in reality since I'm currently in an "implement *everything*" mode, I'll probably end up implementing both. (ii) I was presuming that unwrapping the phase of a FT was a much more complex operation than unwrapping phase shift in FIR filters. After running into a DSP specialist colleague in the corridor, it appears that it's easy. I didn't realise that a discontinuity in the phase spectrum of a FT was just a discontinuity in phase between two adjacent FT (frequency) bins. So, I'm not sure if I need to unwrap phase or not. But if I need to, it looks like I can with no problem. Cheers, Ross-c
As I suspected. One doesn't need the complex cepstrum unless one is going to reconstitute the signal. For pitch estimation, you want the real cepstrum, commonly called just the cepstrum. See Rabiner & Schafer, secs. 7.1.2, 7.3.
Ross Clement (Email address invalid - do not use) wrote:> (i) Hmmm..... I have to review some sources on the use of the cepstrum > in pitch detection before I can say whether I need the complex cepstrum > or not. The only source I have within arm's reach is Hess's 1983 book > on Pitch Detection. This sort of suggests that the FT of the log of the > power spectrum is what is used. However I'm confused in that the > Wikipedia article on the cepstrum says that the cepstrum is the FT of > the log of the FT, and that it is a common mistake to claim that the > cepstrum is the *INVERSE* FT of the log of the FT. Hess describes the > cepstrum as being the INVERSE FT of the power spectrum. So, I need to > look into this further. But in reality since I'm currently in an > "implement *everything*" mode, I'll probably end up implementing both.The difference between an FFT and an IFFT after the log is only a constant, which I think only affects where you set the thresholds when doing pitch likelyhood estimation. What I would like to know is if the literature recommends using the real part of a complex FFT or a magnitude FFT (power spectrum), both of the log of a magnitude FFT, when doing pitch estimation. IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
Jerry Wolf wrote:> As I suspected. One doesn't need the complex cepstrum unless one is > going to reconstitute the signal.I've read about reconstituting a signal from its real cepstrum in order to create minimum-phase filters out of the signal. The phase of the spectrum is lost and somehow thus minimized when reconstituted. (Perhaps a chapter in O&S 1975 explains why.) IMHO. YMMV. -- rhn A.T nicholson d.O.t C-o-M
For pitch estimation it is common to take the log of the power spectrum which is obtained by summing the squares of the real and imaginary outputs of the first FFT. There is no need to square root the sum of squares, as it is more efficient to adjust after the log. John
"Jerry Wolf" <sl_jerry1@hotmail.com> wrote in message news:1134570017.351854.16430@g49g2000cwa.googlegroups.com...> Ross -- it's the complex cepstrum that you need, right? > > I ask because "cepstrum" is commonly used to refer to the FT of the log > of the power spectrum, which is a bit simpler to compute -- no phase > involved. > > cheers, > jerry wolf >Watch out for a bias which esists after you take logs. This only involves the first Cepstrum coefficient C0 and I believe the bias is Eulers number downwards (negative). You have to add Eulers number to unbias. Ing
Reply by ●December 15, 20052005-12-15
I don't know if this helps at all. Here is an older message I wrote to Rune Allnor: Fred *************************** I made some diagrams out of the O&S first ed. book and substituted "s" for the "square" operator. The "Convolutional System" is what you're dealing with. What interests me below is that the Z Transforms go forward/inverse (in that order) in both Figures 5 and 6. It's because in the input case the first transformation is from convolutional to multiplicative and in the output case the second transformation is from multiplicative to convolutional. Of course an L linear stage is implied between Figures 5 and 6. I guess this simply says that a multiplicative system can directly be dealt with using complex log and complex exponential but a convolutional system needs to be: 1) transformed first so that it becomes a multiplicative system. Then we can do the log operation. 2) transformed back so that it becomes an additive/linear system. Then we can apply a linear filter. 3) transformed next so that it becomes a multiplicative system again. Then we can apply the exponent operation. 4) transformed back so that it becomes a convolutional system once more - in other words getting back to the domain of interest. I'm used to doing linear filtering in the frequency domain using multiplication just as well as doing it in the time domain with convolution. So, it appears that the middle transform operation pair is unnecessary if you do the filtering in the frequency domain. Why bother computing the complex cepstrum at all? Am I missing something here. Oh, they probably call that a "trick" later on! I just haven't read enough. Note in Fig 1 that they are applying a linear filter in the time domain and are using the operational symbols "+" for input and output even though it's a convolutional process in the time domain. The "+"s mean that the inputs add and the outputs add as in superposition. I'm sure you've already gone through all this and that's why you're looking at phase unwrapping programs. s + + + + o +-----------+ +-------+ +-----------+ x(n) | | x^(n)| | y^(n)| | y(n) ----->| Ds |----->| L |----->| Ds^-1 |-----> | | | | | | +-----------+ +-------+ +-----------+ Fig 1 Canonic Representation of homomorphic systems x + + + + x +-----------+ +-------+ +-----------+ x(n) | complex | | | | complex | y(n) ----->| log |----->| L |----->|exponential|-----> | | | | | | +-----------+ +-------+ +-----------+ Fig 2 Multiplicative System with Ds = Complex Log * + + + + * +-----------+ +-------+ +-----------+ x(n) | | x^(n)| |y^(n) | | y(n) ----->| D* |----->| L |----->| D*^-1 |-----> | | | | | | +-----------+ +-------+ +-----------+ Fig 3 Convolutional System Abstract Representation * + + + + * +-----------+ +-------+ +-----------+ X(z) | complex | X^(z)| |Y^(z) | complex | Y(z) ----->| log |----->| L |----->| exp |-----> | | | | | | +-----------+ +-------+ +-----------+ Fig 4 Convolutional System Z Transform Domain Representation as a Canonic Homomorphic System * x x + + + +-----------+ +-------+ +-----------+ x(n) | | X(z) |complex|X^(z) | | x^(n) ----->| z[] |----->| log |----->| z^-1[] |-----> complex cepstrum > to "L" | | | | | | +-----------+ +-------+ +-----------+ Fig 5 Convolutional System Representation for D* as in Fig 3 + + + x x * +-----------+ +-------+ +-----------+ y^(n) | | Y^(z)|complex| Y(z) | | y(n) ----->| z[] |----->| exp |----->| z^-1[] |-----> | | | | | | +-----------+ +-------+ +-----------+ Fig 6 Convolutional System Representation for D*^-1 as in Fig 3
Reply by ●December 16, 20052005-12-16
