Are you breaking your 6th order filter into 3 second order sections (in series/cascade)? If not, that is the first step. If you are already doing that, as an alternative to throwing more bits at it, you could also try a different filter topology. I find that the "4-multiply normalized lattice-ladder" structure is much better in terms of stability. -- Jon Harris SPAM blocker in place: Remove 99 (but leave 7) to reply "Roman Rumian" <usun_torumian@agh.edu.pl> wrote in message news:do6tf9$vfc$1@news.agh.edu.pl...> Hi Vladimir, > > Vladimir Vassilevsky napisa�(a): > (...) >> Technically speaking, the single precision IEEE-754 float accuracy may not be >> sufficient for the certain aspects of audio processing. The 32-bit int may >> produce better results. > > thats interesting for me. I have problems with IIR filter stability (6th order > Butterworth highpass at 20 Hz and 48ksps sampling) on Motorola DSP56300 > (24-bit fixed point). Plan to change platform to SHARC Melody, but it seems > that should still use fixed point representation ? ! > > Best regards > > Roman Rumian
Audio processing -- fixed or floating point?
Started by ●December 18, 2005
Reply by ●December 20, 20052005-12-20
"john" <johns@xetron.com> schrieb im Newsbeitrag news:1134909175.895541.297360@g49g2000cwa.googlegroups.com...> Not being an audio person, I was wondering what some of the experts > here would say about that assertion. Is it really always better to use > floating point for audio processing such as SRC, mixing, eq, etc?I'd say that all current DAW (digitial-audio-workstation) applications for PCs or Macs do in fact already use floats instead of integer. One reason is the fact, that float-performance on all PC CPUs in the last couple of years was way ahead of integer. And obviously you will get quite a bit more precision this way. One of the posters mentioned "denormals" as a performance-problem. This was in fact a common thing which became aware with the introduction of P4 CPUs (if I remember correctly). All of the DAW-software-manufacturers and vendors of software-effects & instruments have since then done quite a lot of work that those denormals won't cause performance-issues any more... Some effect-manufacturers have even started to use 64bit floats for internal effect-processsing which is supposed to achieve even higher audio-quality. But there a lot of people in that field seem quite esotheric about how something has to sound ;-) lamenting on how everything was better in those old analog times ;-) Tobias
Tobias Erichsen wrote: ...> I'd say that all current DAW (digitial-audio-workstation) applications for > PCs or Macs do in fact already use floats instead of integer. > > One reason is the fact, that float-performance on all PC CPUs in the last > couple of years was way ahead of integer.> And obviously you will get quite a bit more precision this way.What makes that obvious? ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> schrieb im Newsbeitrag news:b62dnc6euJjbsDXeRVn-vA@rcn.net...> What makes that obvious?Well - the original poster was referring to 16bit integer applications and 32bit floating-point apps... so how would that not be obvious? Tobias
Tobias Erichsen wrote:> "Jerry Avins" <jya@ieee.org> schrieb im Newsbeitrag > news:b62dnc6euJjbsDXeRVn-vA@rcn.net... > > >>What makes that obvious? > > > Well - the original poster was referring to 16bit integer applications and > 32bit floating-point > apps... so how would that not be obvious?The difference is the bit count, not whether the binary point floats. That wasn't obvious to me from what you wrote. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
